Products
LGTM+ Stack
Key Capabilities
Observability Solutions
Open Source
Community resources
Dashboard templates
Prometheus exporters
end-to-end integrations
monitor infrastructure
visualize any data
Learn
Community and events
Resources
The actually useful free plan
10k series Prometheus metrics
500VUh k6 testing
100+ pre-built solutions
3 active AI users
visualize any data
A data source is:
| Without data sources | With data sources |
| No data to visualize | Connect to 150+ supported systems |
| Siloed monitoring tools | Unified dashboards |
| Multiple logins | Single pane of glass |
Here’s something fundamental to understand about data sources: when you use them, your data stays where it lives. Grafana Cloud can store data through integrations or when you send telemetry directly, but data sources are different. They’re connections to external systems where your data already lives.
A data source is a connection to an external system like a database, a metrics store, a cloud service, or an API. When you add a panel to a dashboard, you’re really saying “go to this data source, run this query, and show me the results.”
The magic is that you can have multiple data sources in the same dashboard. Prometheus metrics alongside MySQL application data alongside CloudWatch AWS stats.
Different sources, unified view. That’s Grafana’s superpower.
