Products
LGTM+ Stack
Key Capabilities
Observability Solutions
Open Source
Community resources
Dashboard templates
Prometheus exporters
end-to-end integrations
monitor infrastructure
visualize any data
Learn
Community and events
Resources
The actually useful free plan
10k series Prometheus metrics
500VUh k6 testing
100+ pre-built solutions
3 active AI users
visualize any data
| Level | Focus | Question Answered |
| Level 1 | Infrastructure | “Is my server healthy?” |
| Level 2 | Services | “Which service is the problem?” |
| Level 3 | Transactions | “Why is this request slow?” |
| Level 4 | Custom logic | “What’s happening in my code?” |
Data sources give you Level 1 flexibility. Connect anything to Grafana.
Integrations are faster. Data sources are more flexible. Both build your infrastructure foundation.
Before we dive into data sources, let’s zoom out and understand where they fit in the bigger picture.
Observability isn’t one thing. It’s a hierarchy of needs. At the foundation, Level 1, you need infrastructure visibility. Can you see if your servers, databases, and networks are healthy? This is the base everything else builds on.
At Level 2, you shift focus to services. Which service is causing the problem?
At Level 3, you dig into individual transactions. Why is this specific request slow?
And at Level 4, you add custom instrumentation for application-specific questions.
Here’s the key insight: data sources give you Level 1 flexibility. While integrations give you pre-built monitoring for common systems, data sources let you connect anything.
Already running Prometheus? Connect it. Have data in a JSON API? Query it. Need to pull from a cloud provider? Data sources make it possible.
Data sources and integrations are complementary. Integrations are faster to deploy. Data sources are more flexible. Both help you build that critical Level 1 foundation.
