- Documentation
- Learning Hub
- Section 2 of 4 Metrics Drilldown
The exploration workflow
Slide 4 of 9
Grafana Metrics Drilldown follows a five-step pattern for investigating infrastructure metrics.
The workflow
Why this workflow matters
This pattern guides you from broad exploration to specific findings. You don’t need to know exactly what you’re looking for when you start. The workflow helps you discover problems and patterns as you navigate.
