This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Environment variables
Often, scripts need only minor tweaks to be reusable in different contexts. Rather than creating several separate scripts for these different contexts or environments, you can use environment variables to make parts of your script tweakable.
You can use environment variables for two main purposes:
- Passing environment variables to the k6 Script
- Configuring k6 Options with environment variables
Passing environment variables to the k6 script
In k6, the environment variables are exposed through a global __ENV variable, a JS object.
For reference, see the script example below:
import http from 'k6/http';
import { sleep } from 'k6';
export default function () {
const res = http.get(`http://${__ENV.MY_HOSTNAME}/`);
sleep(1);
}The recommended option to pass environment variables to your testing script is to use one or more
-e / --env CLI flags
(this command works the same for all platforms):
k6 run -e MY_HOSTNAME=test.k6.io script.js⚠ The
-eflag does not configure optionsThis flag just provides variables to the script, which the script can use or ignore. For example,
-e K6_ITERATIONS=120does not configure the script iterations.Compare this behavior with
K6_ITERATIONS=120 k6 run script.js, which does set iterations.
A second option to pass environment variables is to source them from the local system.
MY_HOSTNAME=test.k6.io k6 run script.jsset "MY_HOSTNAME=test.k6.io" && k6 run script.js$env:MY_HOSTNAME="test.k6.io"; k6 run script.js⚠️ Warning
By default, passing system environment variables doesn’t work for k6 archive, k6 cloud run, and k6 inspect.
This is a security measure to avoid the risk of uploading sensitive data to k6 Cloud.
To override this mode, specify
–include-system-env-vars.
Configure k6 options with environment variables
You can also configure k6 options with environment variables. Consider this script:
const res = http.get('https://test.k6.io');
sleep(1);
}By default, a local run of this script will execute a single iteration with one virtual user(VU). To modify the default behavior, pass k6 options as environment variables. For example, this snippet configures the script to run 10 virtual users for a duration of 10 seconds:
K6_VUS=10 K6_DURATION=10s k6 run script.jsset "K6_VUS=10 K6_DURATION=10s" && k6 run script.js$env:K6_VUS=10 ; $env:K6_DURATION="10s" ; k6 run script.jsAs the preceding example shows, you need to prefix K6_ in the environment variable name for k6 to evaluate it as an option parameter.
However, be aware that not all options are supported as environment variables.
You can confirm whether one is by checking the
documentation for each option.
Note that when you define options in multiple places, there’s an order of precedence that determines the option to use. To ensure you’re always working with the highest precedence, use command-line flags instead of environment variables:
k6 run -e MY_HOSTNAME=test.k6.io --duration 10s --vus 10 script.js
