This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Interact with elements on your webpage
You can use page.locator() and pass in the element’s selector you want to find on the page. page.locator() will create and return a
Locator object, which you can later use to interact with the element.
To find out which selectors the browser module supports, check out Selecting Elements.
Note
You can also use
page.$()instead ofpage.locator(). You can find the differences betweenpage.locator()andpage.$in the Locator API documentation.
import { browser } from 'k6/browser';
export const options = {
scenarios: {
ui: {
executor: 'shared-iterations',
options: {
browser: {
type: 'chromium',
thresholds: {
checks: ['rate==1.0'],
export default async function () {
const page = await browser.newPage();
try {
await page.goto('https://test.k6.io/my_messages.php');
// Enter login credentials
await page.locator('input[name="login"]').type('admin');
await page.locator('input[name="password"]').type('123');
await page.screenshot({ path: 'screenshots/screenshot.png' });
} finally {
await page.close();
}The preceding code creates and returns a Locator object with the selectors for both login and password passed as arguments.
Within the Locator API, various methods such as type() can be used to interact with the elements. The type() method types a text to an input field.
