Manage Grafana library panels
Enterprise Open source
You can adjust library panel configuration at any time.
Before you begin
To view and manage a library panel:
  1. Hover over the Dashboard option on the left menu, then click Library panels.
    You can see a list of previously defined library panels.
    Screenshot of the edit panel
  2. Search for a specific library panel if you know its name.
    You can also filter the panels by folder or type.
