Nginx integration for Grafana Cloud
NGINX is open source software for web serving, reverse proxying, caching, load balancing, media streaming, and more. It started out as a web server designed for maximum performance and stability. In addition to its HTTP server capabilities, NGINX can also function as a proxy server for email (IMAP, POP3, and SMTP) and a reverse proxy and load balancer for HTTP, TCP, and UDP servers.
This integration includes 2 pre-built dashboards to help monitor and visualize Nginx metrics and logs.
Before you begin
For this integration to work, you must first configure a custom JSON access log in the NGINX configuration, as well as enable the Stub Status Module and configure the nginx-prometheus-exporter.
First, to enable the logging, place the following configuration within the http
block, by the # Logging Settings
line:
log_format json_analytics escape=json '{'
'"msec": "$msec", ' # request unixtime in seconds with a milliseconds resolution
'"connection": "$connection", ' # connection serial number
'"connection_requests": "$connection_requests", ' # number of requests made in connection
'"pid": "$pid", ' # process pid
'"request_id": "$request_id", ' # the unique request id
'"request_length": "$request_length", ' # request length (including headers and body)
'"remote_addr": "$remote_addr", ' # client IP
'"remote_user": "$remote_user", ' # client HTTP username
'"remote_port": "$remote_port", ' # client port
'"time_local": "$time_local", '
'"time_iso8601": "$time_iso8601", ' # local time in the ISO 8601 standard format
'"request": "$request", ' # full path no arguments if the request
'"request_uri": "$request_uri", ' # full path and arguments if the request
'"args": "$args", ' # args
'"status": "$status", ' # response status code
'"body_bytes_sent": "$body_bytes_sent", ' # the number of body bytes exclude headers sent to a client
'"bytes_sent": "$bytes_sent", ' # the number of bytes sent to a client
'"http_referer": "$http_referer", ' # HTTP referer
'"http_user_agent": "$http_user_agent", ' # user agent
'"http_x_forwarded_for": "$http_x_forwarded_for", ' # http_x_forwarded_for
'"http_host": "$http_host", ' # the request Host: header
'"server_name": "$server_name", ' # the name of the vhost serving the request
'"request_time": "$request_time", ' # request processing time in seconds with msec resolution
'"upstream": "$upstream_addr", ' # upstream backend server for proxied requests
'"upstream_connect_time": "$upstream_connect_time", ' # upstream handshake time incl. TLS
'"upstream_header_time": "$upstream_header_time", ' # time spent receiving upstream headers
'"upstream_response_time": "$upstream_response_time", ' # time spent receiving upstream body
'"upstream_response_length": "$upstream_response_length", ' # upstream response length
'"upstream_cache_status": "$upstream_cache_status", ' # cache HIT/MISS where applicable
'"ssl_protocol": "$ssl_protocol", ' # TLS protocol
'"ssl_cipher": "$ssl_cipher", ' # TLS cipher
'"scheme": "$scheme", ' # http or https
'"request_method": "$request_method", ' # request method
'"server_protocol": "$server_protocol", ' # request protocol, like HTTP/1.1 or HTTP/2.0
'"pipe": "$pipe", ' # "p" if request was pipelined, "." otherwise
'"gzip_ratio": "$gzip_ratio"'
access_log /var/log/nginx/json_access.log json_analytics;
To use country mapping, you must enable the GeoIP2 module, and add the relevant geoip_country_code
configuration to the access log, replacing the last few lines of the previous snippet with the following, starting at "gzip_ratio"
'"gzip_ratio": "$gzip_ratio", '
'"geoip_country_code": "$geoip_country_code"'
geoip_country /etc/nginx/GeoLite2-Country.mmdb {
$geoip_country_code default=US source=$remote_addr country iso_code;
Then, to enable scraping metrics from your NGINX instance, enable the Stub Status Module in your NGINX configuration.
server {
listen 127.0.0.1:8080;
server_name localhost;
location /stub_status {
stub_status on;
# Optionally restrict access to IP addresses if needed
# allow 127.0.0.1;
# deny all;
The nginx-prometheus-exporter should then be configured to scrape NGINX. Adjust the stub_status
module as required for your environment.
Install Nginx integration for Grafana Cloud
- Find Nginx and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Nginx metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards to your Grafana Cloud instance, and you can start monitoring your Nginx setup.
Advanced mode
To instruct Grafana Alloy to scrape your Nginx instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
discovery.relabel "metrics_integrations_integrations_nginx" {
targets = [{
__address__ = "localhost:9113",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_nginx" {
targets = discovery.relabel.metrics_integrations_integrations_nginx.output
job_name = "integrations/nginx"
To monitor your NGINX instance, you must use a discovery.relabel component to discover your nginx-prometheus-exporter endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your NGINX Prometheus exporter metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this NGINX instance.
If you have multiple NGINX servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
local.file_match "logs_integrations_integrations_nginx" {
path_targets = [{
__address__ = "localhost",
__path__ = "<path to json nginx access log>",
host = "<http_hostname>",
instance = constants.hostname,
job = "integrations/nginx",
loki.source.file "logs_integrations_integrations_nginx" {
targets = local.file_match.logs_integrations_integrations_nginx.targets
forward_to = [loki.write.grafana_cloud_loki.receiver]
To monitor your Nginx instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Nginx instance address__path__
: The path to the log file.instance
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Nginx instance.
loki.source.file sends logs to Loki.
linux
path_targets = [{
__address__
sets theinstance
windows
path_targets = [{
__address__
sets theinstance
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
line:
server {
stub_status on;
# allow 127.0.0.1;
# deny all;
Finally, deploy the nginx-prometheus-exporter to your cluster and then be configured to scrape NGINX. Adjust the stub_status
Update the provided configuration for the Kubernetes Monitoring Helm Chart to discover your nginx-prometheus-exporter endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configuration snippets for Kubernetes Helm chart
To scrape your NGINX instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <>
in the provided snippets with your desired configuration values.
Metrics snippets
podLogs:
extraDiscoveryRules: |-
rule {
source_labels = ["__meta_kubernetes_pod_label_<nginx_label>"]
regex = "<nginx_label_value>"
replacement = "nginx"
target_label = "integration"
rule {
source_labels = ["integration", "__meta_kubernetes_namespace", "__meta_kubernetes_pod_container_name"]
separator = "-"
regex = "nginx-(.*-.*)"
rule {
source_labels = ["integration"]
regex = "nginx"
replacement = "integrations/nginx"
target_label = "job"
line:
# Logging Settings
server {
stub_status on;
# allow 127.0.0.1;
# deny all;
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Nginx metrics and logs to your Grafana Cloud instance.
Post-install configuration for the Nginx integration
After enabling the JSON-formatted access log generation, instruct Grafana Agent to scrape it.
To scrape it, add the provided snippet to your agent configuration file.
The agent must have local access to the log file. Alternatively, it may be configured to fetch logs from Kubernetes using a kubernetes_sd_config
Make sure to change the host
label to a value that reflects your environment. It will be used to filter this instance in the dashboard.
- job_name: integrations/nginx
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: [ 'localhost:9113' ]
static_configs:
- targets:
- localhost
labels:
host: <http_hostname>
__path__: <path to json nginx access log>
instance: '<your-instance-name>'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Nginx integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
- targets:
- localhost
labels:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The Nginx integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- NGINX Logs
- NGINX Overview
Metrics
The most important metrics provided by the Nginx integration, which are used on the pre-built dashboards, are as follows:
- nginx_connections_accepted
- nginx_connections_active
- nginx_connections_handled
- nginx_connections_reading
- nginx_connections_waiting
- nginx_connections_writing
- nginx_http_requests_total
- nginx_up
- up
Changelog
# 1.1.2 - November 2024
- Add missing metrics scrape snippet
# 1.1.1 - November 2024
- Update status panel check queries
# 1.1.0 - October 2024
* Update mixin to latest
* Add metric dashboard based on nginx-prometheus-exporter
* Update Alloy scrape config
# 1.0.1 - August 2024
* Update queries to use `$__interval` instead of hardcoded time ranges
# 1.0.0 - June 2024
* Update all `cluster` queries to be conditional
* Remove news panel
* Update installation instructions
* Add missing job label to Alloy snippet
# 0.0.5 - September 2023
# 0.0.4 - August 2023
# 0.0.3 - July 2023
* Update mixin to latest version:
- Add cluster variable to support Kubernetes clusters
* Added Grafana Agent Operator configuration snippet to support nginx in a Kubernetes cluster.
# 0.0.2 - September 2022
- Update queries to use $__rate_interval
# 0.0.1 - May 2021
* Initial release
Cost
By connecting your Nginx instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
