ClickHouse integration for Grafana Cloud
ClickHouse is an open-source column-oriented database management system that allows generating analytical data reports in real-time. This integration helps you monitor a ClickHouse cluster metrics and error logs, with an accompanying dashboard to visualize it.
This integration supports ClickHouse 22.6.8.35+.
This integration includes 4 useful alerts and 4 pre-built dashboards to help monitor and visualize ClickHouse metrics and logs.
Before you begin
ClickHouse supports multi-file configurations using either a /etc/clickhouse-server/config.xml
or /etc/clickhouse-server/config.yaml
. This example shows config.xml
snippets required to collect metrics and logs.
Prometheus metrics are generated using the ClickHouse Prometheus instrumentation that must be configured under the Global Server Settings, within the config.xml
file. Some ClickHouse installations have these commented out, else include this snippet:
<prometheus>
<endpoint>/metrics</endpoint>
<port>9363</port>
<metrics>true</metrics>
<events>true</events>
<asynchronous_metrics>true</asynchronous_metrics>
<status_info>true</status_info>
</prometheus>
ClickHouse error logs are scraped using a Promtail agent that targets the default /var/log/clickhouse-server/clickhouse-server.err.log
path. Logs are enabled by including the target path inside the <errorlog>
file. Some ClickHouse installations have the error log set by default, which would be located at the top of the config.xml
file.
<logger>
<errorlog>/var/log/clickhouse-server/clickhouse-server.err.log</errorlog>
</logger>
For more information please check ClickHouse logger settings.
After editing the config.xml
file, restart the ClickHouse server:
sudo service clickhouse-server restart
Install ClickHouse integration for Grafana Cloud
- Find ClickHouse and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send ClickHouse metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your ClickHouse setup.
Simple mode
These snippets are configured to scrape a single ClickHouse instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_clickhouse" {
targets = [{
__address__ = "localhost:9363",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_clickhouse" {
targets = discovery.relabel.metrics_integrations_integrations_clickhouse.output
job_name = "integrations/clickhouse"
Logs snippets
linux
local.file_match "logs_integrations_integrations_clickhouse" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/clickhouse-server/clickhouse-server.log",
instance = constants.hostname,
job = "integrations/clickhouse",
loki.process "logs_integrations_integrations_clickhouse" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.multiline {
firstline = "^([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))"
max_lines = 0
max_wait_time = "3s"
stage.regex {
expression = `(?P<timestamp>([\d]{4}).([\d]{1,2}).([\d]{1,2}) (([\d]+):([\d]+):([\d]+).([\d]+))) \[ (?P<thread_id>\d+) \] \{(?P<query_id>.*)\} <(?P<level>.+?)> (?P<message>(?s:.*))$`
stage.labels {
values = {
level = null,
loki.source.file "logs_integrations_integrations_clickhouse" {
targets = local.file_match.logs_integrations_integrations_clickhouse.targets
forward_to = [loki.process.logs_integrations_integrations_clickhouse.receiver]
Advanced mode
To instruct Grafana Alloy to scrape your ClickHouse instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your ClickHouse instance, you must use a discovery.relabel component to discover your ClickHouse Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your ClickHouse Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this ClickHouse instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple ClickHouse servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
Advanced logs snippets
linux
path_targets = [{
stage.multiline {
max_lines = 0
stage.regex {
expression = "(?P<timestamp>([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))) \\[ \\d+ \\] \\{.*\\} <(?P<level>.+)> (?P<message>(?s:.*))$"
stage.labels {
values = {
level = null,
To monitor your ClickHouse instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The ClickHouse instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
On Linux, you will also need to add the alloy
user to the clickhouse
group to get logs. Run the following command to configure the user as required:
sudo usermod -a -G clickhouse alloy
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
<prometheus>
<port>9363</port>
</prometheus>
file.
<logger>
</logger>
Configuration snippets for Kubernetes Helm chart
To scrape your Clickhouse instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <>
in the provided snippets with your desired configuration values.
Metrics snippets
alloy-metrics:
extraConfig: |-
discovery.kubernetes "metrics_clickhouse" {
role = "endpoints"
selectors {
role = "endpoints"
label = "<endpoints label>=<endpoints label value>"
discovery.relabel "metrics_clickhouse" {
targets = discovery.kubernetes.metrics_clickhouse.targets
rule {
source_labels = ["__meta_kubernetes_endpoint_port_name"]
regex = "<clickhouse service listening port>"
action = "keep"
rule {
source_labels = ["__meta_kubernetes_pod_label_clickhouse_cluster"]
target_label = "clickhouse_cluster"
rule {
source_labels = ["__meta_kubernetes_pod_name"]
prometheus.scrape "metrics_clickhouse" {
targets = discovery.relabel.metrics_clickhouse.output
honor_labels = true
forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
Logs snippets
podLogs:
extraDiscoveryRules: |-
rule {
source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_label_<your_clickhouse_pod_label_name>"]
separator = ":"
regex = "<your_clickhouse_namespace>:<your_clickhouse_pod_label_value>"
replacement = "clickhouse"
target_label = "integration"
extraLogProcessingStages: |-
stage.match {
selector = "{integration=\\"clickhouse\\"}"
stage.multiline {
firstline = \`^([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))\`
max_lines = 0
max_wait_time = "0s"
stage.regex {
expression = \`(?P<timestamp>([\\d]{4}).([\\d]{1,2}).([\\d]{1,2}) (([\\d]+):([\\d]+):([\\d]+).([\\d]+))) \\[ \\d+ \\] \\{.*\\} <(?P<level>.+)> (?P<message>(?s:.*))$\`
stage.template {
source = "instance"
template = "{{ .namespace }}-{{ .container }}"
stage.labels {
values = {
instance = "pod",
level = "",
stage.static_labels {
values = {
clickhouse_cluster = "<your_clickhouse_cluster_name>",
Prometheus metrics are generated using the ClickHouse Prometheus Instrumentation that must be configured under the Global Server Settings, within the config.xml
<prometheus>
<port>9363</port>
</prometheus>
file.
<logger>
</logger>
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send ClickHouse metrics and logs to your Grafana Cloud instance.
Post-install configuration for the ClickHouse integration
This integration supports metrics and logs from a ClickHouse instance. The Grafana Agent config is stored in /etc/grafana-agent.yaml
Enable the integration by adding the snippets above to your agent configuration file.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
andinstance
label values must match formetrics
andlogs
scrape configs in your agent configuration file.job
label must be set tointegrations/clickhouse
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your ClickHouse Node. Please replace the default<your-instance-name>
value according to your environment - it should be set manually. Note that if you uselocalhost
for multiple nodes, the dashboards will not be able to filter correctly by instance.
Additionally, to gather logs from a Linux host using the Grafana Agent, add the Grafana Agent user as an owner of your ClickHouse instance logs. For example, if you are running on Debian and the default clickhouse group is being used:
sudo usermod -a -G clickhouse grafana-agent
- job_name: integrations/clickhouse
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets: ['localhost:9363']
static_configs:
- targets:
- localhost
labels:
instance: '<your-instance-name>'
job: integrations/clickhouse
__path__: /var/log/clickhouse-server/clickhouse-server.log
pipeline_stages:
- multiline:
firstline: '^([\d]{4}).([\d]{1,2}).([\d]{1,2}) (([\d]+):([\d]+):([\d]+).([\d]+))'
- regex:
expression: '(?P<timestamp>([\d]{4}).([\d]{1,2}).([\d]{1,2}) (([\d]+):([\d]+):([\d]+).([\d]+))) \[ (?P<thread_id>\d+) \] \{(?P<query_id>.*)\} <(?P<level>.+?)> (?P<message>(?s:.*))$'
- labels:
level:
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the ClickHouse integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
static_configs:
- targets:
- localhost
labels:
pipeline_stages:
- multiline:
- regex:
- labels:
level:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
relabel_configs:
static_configs:
global:
scrape_interval: 60s
Dashboards
The ClickHouse integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- ClickHouse latency
- ClickHouse logs
- ClickHouse overview
- ClickHouse replica
ClickHouse Overview Dashboard 1
ClickHouse Overview Dashboard 2
ClickHouse Latency Dashboard
Alerts
The ClickHouse integration includes the following useful alerts:
Alert | Description |
ClickHouseRejectedInserts | Critical: ClickHouse has too many rejected inserts. |
ClickHouseReplicasInReadOnly | Critical: ClickHouse has too many replicas in read only state. |
ClickHouseReplicationQueueBackingUp | Warning: ClickHouse replica max queue size backing up. |
ClickHouseZookeeperSessions | Critical: ClickHouse has too many Zookeeper sessions. |
Metrics
The most important metrics provided by the ClickHouse integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- ClickHouseAsyncMetrics_OSMemoryTotal
- ClickHouseAsyncMetrics_ReplicasMaxQueueSize
- ClickHouseMetrics_HTTPConnection
- ClickHouseMetrics_InterserverConnection
- ClickHouseMetrics_MemoryTracking
- ClickHouseMetrics_MySQLConnection
- ClickHouseMetrics_PostgreSQLConnection
- ClickHouseMetrics_ReadonlyReplica
- ClickHouseMetrics_TCPConnection
- ClickHouseMetrics_VersionInteger
- ClickHouseMetrics_ZooKeeperRequest
- ClickHouseMetrics_ZooKeeperSession
- ClickHouseMetrics_ZooKeeperWatch
- ClickHouseProfileEvents_AsyncInsertQuery
- ClickHouseProfileEvents_DiskReadElapsedMicroseconds
- ClickHouseProfileEvents_DiskWriteElapsedMicroseconds
- ClickHouseProfileEvents_FailedInsertQuery
- ClickHouseProfileEvents_FailedSelectQuery
- ClickHouseProfileEvents_InsertQuery
- ClickHouseProfileEvents_NetworkReceiveBytes
- ClickHouseProfileEvents_NetworkReceiveElapsedMicroseconds
- ClickHouseProfileEvents_NetworkSendBytes
- ClickHouseProfileEvents_NetworkSendElapsedMicroseconds
- ClickHouseProfileEvents_Query
- ClickHouseProfileEvents_RejectedInserts
- ClickHouseProfileEvents_ReplicatedPartChecks
- ClickHouseProfileEvents_ReplicatedPartFetches
- ClickHouseProfileEvents_ReplicatedPartMerges
- ClickHouseProfileEvents_ReplicatedPartMutations
- ClickHouseProfileEvents_SelectQuery
- ClickHouseProfileEvents_ZooKeeperWaitMicroseconds
- up
Changelog
# 1.1.0 - August 2024
* Add Asserts support
* Update mixin:
- Add resolve delay for alerts
- Fix dashboards' legends
- Fix network panels
* Fix logs regex in the instructions
# 1.0.1 - July 2024
* Update instructions with the correct ClickHouse Prometheus instrumentation documentation link.
# 1.0.0 - November 2023
* Added Grafana Agent Operator configuration snippet to support Clickhouse in kubernetes cluster.
* Added cluster selector to dashboard for kubernetes support.
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels.
# 0.1.2 - September 2023
# 0.1.1 - August 2023
* Add regex filter for logs datasource.
# 0.1.0 - July 2023
* Update logs
* Move logs panel to separate dashboard.
* Update agent logs snippet to extract level label and collect all logs.
# 0.0.2 - May 2023
* Update legends for latency metrics.
# 0.0.1 - February 2023
* Initial release.
Cost
By connecting your ClickHouse instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
