Menu
Send custom signals with Faro SDK
After you add it to your application, Faro Web SDK sends the following signals to the collector endpoint:
- Unhandled errors and rejections
- Web Vitals performance measurements
- Logs committed through the
console
object
Although the default signals address many use cases, you might need to manually capture some errors, send custom measurements from your application, integrate log transportation into your logging mechanism, and so on. The following topics address how to use Faro Web SDK to:
Getting started with your metrics, logs, and traces in Grafana Cloud
Learn to use the best open source observability software (Grafana, Prometheus, Loki, and Tempo) without the overhead of managing and scaling your own stack.
Kubernetes monitoring, out-of-the-box with Grafana Cloud
In this webinar you’ll learn how Grafana offers developers and SREs a simple and quick-to-value solution for monitoring their Kubernetes infrastructure.
Unify your data with Grafana plugins: Datadog, Splunk, MongoDB, and more
In this webinar, learn how to leverage Grafana's plugin ecosystem for access to 80+ data sources, including plugins for Datadog, Splunk, MongoDB, and more.
