Manage access to Grafana Adaptive Metrics using role-based access control
Use role-based access control (RBAC) to manage permissions for users in Adaptive Metrics.
The following table shows the role names, descriptions, and associated actions that you can assign to users.
Role | Description | Associated actions |
Admin | Overall read and write access in Adaptive Metrics | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.recommendations:read grafana‑adaptive‑metrics‑app.recommendations:apply grafana-adaptive-metrics-app.rules:read grafana‑adaptive‑metrics‑app.rules:write grafana‑adaptive‑metrics‑app.rules:delete grafana‑adaptive‑metrics‑app.exemptions:read grafana‑adaptive‑metrics‑app.exemptions:write grafana‑adaptive‑metrics‑app.config:read grafana‑adaptive‑metrics‑app.config:write
Config Editor | Edit access to Adaptive Metrics plugin configuration | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.config:read grafana‑adaptive‑metrics‑app.config:write
Config Reader | Read access to Adaptive Metrics plugin configuration | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.config:read
Exemptions Editor | Edit access to recommendation exemptions | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.exemptions:read grafana‑adaptive‑metrics‑app.exemptions:write
Exemptions Reader | Read access to recommendation exemptions | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.exemptions:read
Plugin Access | Access to the Adaptive Metrics plugin | plugins.app:access (with plugins:id:grafana‑adaptive‑metrics‑app scope)grafana‑adaptive‑metrics‑app.plugin:access
Rules Editor | Read and write access to recommendations and rules | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.recommendations:read grafana‑adaptive‑metrics‑app.recommendations:apply grafana‑adaptive‑metrics‑app.rules:read grafana‑adaptive‑metrics‑app.rules:write grafana‑adaptive‑metrics‑app.rules:delete
Rules Reader | Read access to recommendations and rules | grafana‑adaptive‑metrics‑app.plugin:access grafana‑adaptive‑metrics‑app.recommendations:read grafana‑adaptive‑metrics‑app.rules:read
Note
You can assign users to multiple roles.
For a description of supported role-based actions in Adaptive Metrics, refer to Grafana Adaptive Metrics action definitions in the Grafana documentation.
Assign users to a role
You can assign users to a role in the Grafana Cloud UI or using the HTTP API.
Refer to Assign fixed roles in the UI using the role picker and RBAC API in the Grafana documentation for more information.
