Searching...
See everything announced at ObservabilityCON 2026: AI that monitors your AI, faster log search, lower telemetry costs, and more.
DownloadsContact Us
Logo
  • Pricing
  • Docs
Sign inSign up
This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/ai-tools.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/ai-tools/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Menu
Documentationbreadcrumb arrow Grafana Cloudbreadcrumb arrow AI tools
AI tools
Infrastructure-level AI capabilities that enhance your Grafana workflows rather than standing alone as products.
Explore
Introduction to Grafana AI
Learn about Grafana AI capabilities and the products that make up the AI suite.
MCP servers
Connect AI agents to Grafana through the fully hosted Cloud MCP Server or the self-managed open source MCP Server.
Machine learning
Forecast metrics, detect anomalies, and run automated investigations with Sift to alert on dynamic thresholds and surface likely causes.
LLM plugin
Enable large language model features across Grafana Cloud.
gcx CLI
AI-native CLI that gives you and your AI coding agent structured access to your Grafana stack and resources.
Was this page helpful?
Email docs@grafana.com
Help and support
Community
video icon
Video
In this webinar, we’ll demo how to get started using the LGTM Stack: Loki for logs, Grafana for visualization, Tempo for traces, and Mimir for metrics.
video icon
Video
Start with Grafana Assistant
Learn how Grafana Assistant helps teams get answers faster using AI—without writing PromQL. Join this webinar to discover prompting best practices and security FAQs.
video icon
Video
Building advanced Grafana dashboards
In this webinar, we’ll demo how to build and format Grafana dashboards.
Technical documentation Plugin catalog
Choose a product
  • Grafana Cloud
  • What's new from Grafana Labs
  • Learn and build
  • Get started
    • Set up your account
    • Learn
      • What is observability?
        • What is Prometheus?
        • Introduction to time series
        • Time series dimensions
      • Metrics and visualizations
      • Visualize existing observability data
      • Store, query, and alert on data
      • Dashboard overview
      • Histograms and heatmaps
      • Find and use dashboards
      • Find and use plugins
    • Migrate
      • Manually migrate to Grafana Cloud
      • Migrate to Grafana Cloud using the Grafana Cloud Migration Assistant
  • Correlate telemetry signals
    • Get started
      • What are telemetry signals?
      • How products use signals
      • Quick start
    • Workflows
      • Respond to an alert
      • Troubleshoot an error
      • Investigate slow performance
      • Find slow code from a trace
    • Use signals together
      • Key concepts
      • Why correlation matters
      • Setup correlation
      • Navigation
      • Troubleshooting
    • Query and visualize your data
      • Use Grafana Assistant to explore telemetry
      • Use Drilldown apps
      • Visualize and query
        • Query your telemetry
        • Learn about query languages
    • Reference
      • Get help
  • Visualize data
    • Dashboards
      • Use dashboards
      • Build dashboards
        • Create dashboards
          • Dashboard controls
          • Dashboard groupings
        • Create dashboards from templates and suggestions
        • Filter and Group by
        • Import dashboards
        • Modify dashboard settings
        • Manage dashboard links
        • Dashboard URL variables
        • Manage library panels
        • Manage version history
        • Annotate visualizations
        • JSON model
        • Best practices
      • Manage dashboards
      • Search dashboards
      • Manage playlists
      • Reporting
        • Settings
      • Sharing
        • Shared dashboards
      • Variables
        • Add variables
        • Cross-dashboard variables
        • Built-in variables
        • Advanced variable configurations
        • Variable syntax
        • Inspect variables
      • Assess dashboard usage
      • Troubleshoot dashboards
    • Panels and visualizations
      • Visualizations
        • Time series
        • Alert list
        • Annotations list
        • Bar chart
        • Bar gauge
        • Candlestick
        • Canvas
        • Dashboard list
        • Flame graph
        • Gauge
        • Geomap
        • Heatmap
        • Histogram
        • Logs
        • News
        • Node graph
        • Pie chart
        • Stat
        • State timeline
        • Status history
        • Table
        • Text
        • Traces
        • Trend
        • XY chart
      • Panel overview
      • Panel editor
      • The panel inspect view
      • Query and transform data
        • Write expression queries
        • SQL expressions
        • Share query results
        • Transform data
        • Troubleshoot queries
        • Calculation types
      • Configure panel options
      • Configure standard options
      • Configure a legend
      • Configure tooltips
      • Configure data links and actions
      • Configure value mappings
      • Configure thresholds
      • Configure field overrides
    • Explore
      • Get started with Explore
      • Query editor in Explore
      • Query management in Explore
      • Query inspector in Explore
      • Correlations Editor in Explore
      • Logs in Explore
      • Traces in Explore
    • Simplified exploration
      • Metrics Drilldown
        • About metrics and telemetry
        • Get started
        • Drill down your metrics
      • Logs Drilldown
        • Access or Install
          • Configure
        • Get started
        • View logs
          • Table
          • JSON
        • Labels and fields
        • Log patterns
        • Sorting and ordering
        • Troubleshooting
      • Traces Drilldown
        • Access or install
        • Concepts
          • Traces and telemetry
          • Trace structure
          • Tempo and AI
          • Glossary
        • Get started
          • Investigation walkthrough
        • Determine your use case
        • Investigate trends and spikes
          • Choose span data
          • Choose a RED metric
          • Analyze tracing data
          • Add filters
          • Save and load queries
          • View exemplars
        • UI reference
      • Profiles Drilldown
        • Access or install
          • Profile settings
        • Concepts
          • What is profiling?
          • Continuous profiling
          • Understand profiling types
          • Flame graphs
        • Get started
        • Choose a view
          • Use Flame graph AI
  • Developer resources
    • Contribute to Grafana
      • Contributor License Agreement (CLA)
    • Developer tools
    • Grafana APIs
      • HTTP API
        • API Structure
        • Migrate to new APIs
        • Authentication
        • Dashboard HTTP API
        • Folder HTTP API
        • Playlist HTTP API
        • Resource History API
        • Secrets Management HTTP API
        • Stars HTTP API
        • Legacy Grafana HTTP API
          • Admin HTTP API
          • Alerting Provisioning HTTP API
          • Annotations HTTP API
          • Correlations HTTP API
          • Dashboard Permissions HTTP API
          • Dashboard Versions HTTP API
          • Data source HTTP API
          • Data source LBAC rules HTTP API
          • Data source permissions HTTP API
          • Folder Permissions HTTP API
          • Folder/Dashboard Search HTTP API
          • Library Element HTTP API
          • Licensing HTTP API
          • Organization HTTP API
          • Other HTTP API
          • Preferences API
          • Query and Resource Caching HTTP API
          • Query History HTTP API
          • RBAC HTTP API
          • Reporting API
          • Service account HTTP API
          • Shared Dashboards HTTP API
          • Short URL HTTP API
          • Snapshot API
          • SSO Settings API
          • Team HTTP API
          • Team Sync HTTP API
          • User HTTP API
        • Examples
          • API Tutorial: Create Service Account tokens and dashboards for an organization
          • cURL examples
      • Grafana Cloud API
      • Grafana Cloud tracing API
      • Grafana Cloud Synthetic Monitoring API
  • As code
    • Observability as code
      • Grafana CLI
        • grafanactl CLI (deprecated)
          • Use grafanactl
      • Foundation SDK
        • Foundation SDK key concepts
        • Automate dashboard provisioning with CI/CD
      • Git Sync
        • Key concepts
        • Usage limitations
        • Set up Git Sync
          • Setup prerequisites
          • Set up Git Sync as code
          • Set up Git Sync with Terraform
          • Instantaneous pulling and dashboard previews
        • Add non-provisioned resources
          • Copy individual dashboards
          • Migrate existing dashboards
        • Work with provisioned repositories
        • Work with provisioned dashboards
        • Permissions and access control
        • Git repository protection
        • Deployment scenarios
          • Single instance
          • Across environments
          • Regional replication
          • Testing sandboxes
          • High availability
          • Shared instance
      • On-prem file provisioning
        • Set up file provisioning
    • Infrastructure as code
      • Terraform
        • Create and manage a Grafana Cloud stack using Terraform
        • Create and manage dashboards using Terraform and GitHub Actions
        • Manage Grafana IRM in Grafana Cloud using Terraform
        • Manage Knowledge Graph in Grafana Cloud using Terraform
          • Get started
          • Configure the Knowledge Graph stack
          • Notification alerts
          • Suppressed assertions
          • Custom model rules
          • Prometheus rules
          • Log configurations
          • Thresholds
          • Trace configurations
          • Profile configurations
        • Manage secrets in Grafana Cloud using Terraform
        • Manage Fleet Management in Grafana Cloud using Terraform
        • Manage Frontend Observability in Grafana Cloud with Terraform
        • Manage Cloud Provider Observability in Grafana Cloud using Terraform
        • Install plugins in Grafana Cloud using Terraform
        • Manage saved queries
      • Ansible
        • Manage stack using Ansible
      • Grafana Operator
        • Manage resources with the Grafana Operator
        • Manage dashboards with ArgoCD
      • Grizzly (deprecated)
  • Grafana Learn
  • Instrument and send data
  • Connect or send data
    • Work with demo data
  • Instrumentation Hub
    • Set up Instrumentation Hub
    • SDK injection
  • Metrics
    • Prometheus metrics
      • Prometheus ingestion errors
      • Query metrics using HTTP APIs
      • Native histograms
      • Configuration examples
        • Integration methods
        • Linux host using Prometheus and node_exporter
        • Linux host
        • Open source projects
          • Apache projects
          • Application frameworks
          • Blockchain
          • Cloud infrastructure
          • Communication
          • Content management
          • Data processing
          • Databases
          • Development tools
          • DevOps tools
          • Infrastructure
          • Messaging
          • Observability
          • Security
          • Specialized apps
          • Web & Networking
    • Send or visualize Graphite metrics
      • Graphite data ingestion
      • Graphite HTTP API
      • Graphite aggregation
      • Graphite FAQ
    • Send or visualize InfluxDB metrics
      • Push metrics from Influx Telegraf to Prometheus
    • Label handling and limits
    • Send or visualize Datadog Metrics
      • Datadog metrics supported features
    • Troubleshoot write issues
    • Send metrics without an integration
  • Logs
    • Collect logs with Grafana Alloy
    • Collect logs with the OpenTelemetry Collector
    • Loki limits
    • Send PostgreSQL logs to Grafana Cloud with Grafana Alloy
    • Authenticate to query Cloud Logs
    • Query acceleration with bloom filters
    • Needle-in-a-haystack searches
    • Cloud Logs Export
      • Per stream export
      • Export to Amazon S3
      • Export to Azure Blob
      • Export to Google Cloud
      • Monitor Cloud Logs Export
      • Validate Cloud Logs Export Data
      • Alerting
      • Query exported logs
      • Delete exported log data
      • Disable Cloud Logs Export
    • Delete unwanted information in log lines
  • Traces
    • Introduction
      • Trace structure
      • Tempo architecture
      • Tempo and AI
      • Glossary
    • Set up tracing
      • Instrument applications
      • Set up traces with Grafana Alloy
      • Locate URL, user, and password
      • Add a Cloud Access Policy
      • Verify ingestion
      • Retry on failures
    • Best practices
    • Configure tracing options
      • Metrics-generator in Grafana Cloud Traces
      • Sampling strategies
      • Reduce trace size
      • Configure and use exemplars
      • Metrics summary API (deprecated)
    • Use traces in Grafana
    • Investigate traces with Grafana Assistant
    • Query tracing data
      • TraceQL cookbook
    • Troubleshoot
    • MCP server
    • Request trace deletion
  • Profiles
    • Introduction
      • When to use continuous profiling
      • Flame graphs
    • Send profile data
    • View and analyze profiling data
    • Flame graph AI
    • Integrate profiles with Grafana Cloud k6
    • Show usage line by line
    • How profiles and traces work together
    • Use Traces to profiles
    • Symbolization
    • Use recording rules
  • OpenTelemetry
    • Send OTLP data
    • OTLP format considerations
    • Promote resource attributes
    • Loki 3 native OTLP log format
  • Grafana Alloy
    • Introduction
      • Why Alloy
      • How Alloy works
      • Telemetry flow
      • OpenTelemetry in Alloy
      • Requirements
    • Get started
      • Components
        • Configure components
        • Build data pipelines
        • Component controller
        • Custom components
        • Community components
      • Expressions
        • Types and values
        • Component exports
        • Operators
        • Function calls
      • Alloy syntax
      • Modules
      • Clustering
    • Set up
      • Supported platforms
      • Install
        • Linux
        • macOS
        • Windows
        • Docker
        • Kubernetes
        • Standalone
        • Ansible
        • Chef
        • OpenShift
        • Podman
        • Puppet
      • Migrate
        • Migrate from Agent Static
        • Migrate from Agent Operator
        • Migrate from Agent Flow
        • Migrate from OpenTelemetry Collector
        • Migrate from Prometheus
        • Migrate from Promtail
      • Run
        • Linux
        • macOS
        • Windows
        • Standalone
      • OpenTelemetry Engine
        • CLI
        • Alloy Engine extension
        • Helm chart
        • Service installations
        • Custom builds
      • Deploy
      • Estimate resource usage
    • Configure
      • Clustering
        • Configure Alloy
        • Distribute workload
      • Kubernetes
      • Proxy layer
      • Linux
      • macOS
      • Windows
      • Load remote configuration
    • Access and permissions
      • Linux
      • Kubernetes
      • Windows
    • Collect and forward data
      • Choose a component
      • Collect Alloy telemetry
      • Collect Datadog traces and metrics
      • Collect Kubernetes logs
      • Collect Azure Event Hubs logs
      • Collect Prometheus metrics
      • Collect Prometheus native histograms
      • Collect OpenTelemetry data
      • Collect OpenTelemetry data and forward to Grafana
      • Collect ECS or Fargate OpenTelemetry data
    • Monitor metrics and logs
      • Monitor Docker
      • Monitor Linux
      • Monitor Windows
      • Monitor log files
      • Monitor TCP logs
      • Monitor syslog messages
      • Monitor structured logs
      • Monitor Kubernetes logs
    • Tutorials
      • Send logs to Loki
      • Send metrics to Prometheus
      • First components and the standard library
      • Logs and relabeling basics
      • Process Logs
    • Troubleshoot
      • Monitor the controller
      • Monitor components
      • Import mixin dashboards
      • Generate a support bundle
      • Profile resource consumption
      • Debug
    • Reference
      • Command-line interface
        • convert
        • fmt
        • gql
        • run
        • otel
        • otel-supervisor
        • tools
        • Environment variables
        • validate
      • Configuration blocks
        • argument
        • declare
        • export
        • foreach
        • http
        • import.file
        • import.git
        • import.http
        • import.string
        • livedebugging
        • logging
        • remotecfg
        • tracing
      • Components
        • beyla
          • beyla.ebpf
        • database_observability
          • database_observability.mysql
          • database_observability.postgres
          • database_observability.sql_server
        • discovery
          • discovery.aws
          • discovery.azure
          • discovery.consul
          • discovery.consulagent
          • discovery.digitalocean
          • discovery.dns
          • discovery.docker
          • discovery.dockerswarm
          • discovery.ec2
          • discovery.eureka
          • discovery.file
          • discovery.gce
          • discovery.hetzner
          • discovery.http
          • discovery.ionos
          • discovery.kubelet
          • discovery.kubernetes
          • discovery.kuma
          • discovery.lightsail
          • discovery.linode
          • discovery.marathon
          • discovery.nerve
          • discovery.nomad
          • discovery.openstack
          • discovery.ovhcloud
          • discovery.process
          • discovery.puppetdb
          • discovery.relabel
          • discovery.scaleway
          • discovery.serverset
          • discovery.triton
          • discovery.uyuni
        • faro
          • faro.receiver
        • local
          • local.file
          • local.file_match
        • loki
          • loki.echo
          • loki.enrich
          • loki.process
          • loki.relabel
          • loki.rules.kubernetes
          • loki.secretfilter
          • loki.source.api
          • loki.source.awsfirehose
          • loki.source.azure_event_hubs
          • loki.source.cloudflare
          • loki.source.docker
          • loki.source.file
          • loki.source.gcplog
          • loki.source.gelf
          • loki.source.heroku
          • loki.source.journal
          • loki.source.kafka
          • loki.source.kubernetes
          • loki.source.kubernetes_events
          • loki.source.podlogs
          • loki.source.syslog
          • loki.source.windowsevent
          • loki.write
        • mimir
          • mimir.alerts.kubernetes
          • mimir.rules.kubernetes
        • otelcol
          • otelcol.auth.basic
          • otelcol.auth.bearer
          • otelcol.auth.google
          • otelcol.auth.headers
          • otelcol.auth.oauth2
          • otelcol.auth.sigv4
          • otelcol.connector.count
          • otelcol.connector.host_info
          • otelcol.connector.servicegraph
          • otelcol.connector.signaltometrics
          • otelcol.connector.spanlogs
          • otelcol.connector.spanmetrics
          • otelcol.encoding.jsonlog
          • otelcol.encoding.text
          • otelcol.exporter.awss3
          • otelcol.exporter.datadog
          • otelcol.exporter.debug
          • otelcol.exporter.faro
          • otelcol.exporter.file
          • otelcol.exporter.googlecloud
          • otelcol.exporter.googlecloudpubsub
          • otelcol.exporter.kafka
          • otelcol.exporter.loadbalancing
          • otelcol.exporter.loki
          • otelcol.exporter.otlp
          • otelcol.exporter.otlphttp
          • otelcol.exporter.prometheus
          • otelcol.exporter.splunkhec
          • otelcol.exporter.syslog
          • otelcol.extension.jaeger_remote_sampling
          • otelcol.processor.attributes
          • otelcol.processor.batch
          • otelcol.processor.cumulativetodelta
          • otelcol.processor.deltatocumulative
          • otelcol.processor.discovery
          • otelcol.processor.filter
          • otelcol.processor.groupbyattrs
          • otelcol.processor.interval
          • otelcol.processor.k8sattributes
          • otelcol.processor.memory_limiter
          • otelcol.processor.metric_start_time
          • otelcol.processor.probabilistic_sampler
          • otelcol.processor.redaction
          • otelcol.processor.resourcedetection
          • otelcol.processor.span
          • otelcol.processor.tail_sampling
          • otelcol.processor.transform
          • otelcol.receiver.awscloudwatch
          • otelcol.receiver.awsecscontainermetrics
          • otelcol.receiver.awss3
          • otelcol.receiver.cloudflare
          • otelcol.receiver.datadog
          • otelcol.receiver.faro
          • otelcol.receiver.file_stats
          • otelcol.receiver.filelog
          • otelcol.receiver.fluentforward
          • otelcol.receiver.googlecloudpubsub
          • otelcol.receiver.influxdb
          • otelcol.receiver.jaeger
          • otelcol.receiver.kafka
          • otelcol.receiver.loki
          • otelcol.receiver.nginx
          • otelcol.receiver.opencensus
          • otelcol.receiver.otlp
          • otelcol.receiver.prometheus
          • otelcol.receiver.solace
          • otelcol.receiver.splunkhec
          • otelcol.receiver.syslog
          • otelcol.receiver.tcplog
          • otelcol.receiver.vcenter
          • otelcol.receiver.zipkin
          • otelcol.storage.file
        • prometheus
          • prometheus.echo
          • prometheus.enrich
          • prometheus.exporter.apache
          • prometheus.exporter.azure
          • prometheus.exporter.blackbox
          • prometheus.exporter.cadvisor
          • prometheus.exporter.cloudwatch
          • prometheus.exporter.consul
          • prometheus.exporter.databricks
          • prometheus.exporter.dnsmasq
          • prometheus.exporter.elasticsearch
          • prometheus.exporter.gcp
          • prometheus.exporter.github
          • prometheus.exporter.kafka
          • prometheus.exporter.memcached
          • prometheus.exporter.mongodb
          • prometheus.exporter.mssql
          • prometheus.exporter.mysql
          • prometheus.exporter.oracledb
          • prometheus.exporter.postgres
          • prometheus.exporter.process
          • prometheus.exporter.redis
          • prometheus.exporter.self
          • prometheus.exporter.snmp
          • prometheus.exporter.snowflake
          • prometheus.exporter.squid
          • prometheus.exporter.static
          • prometheus.exporter.statsd
          • prometheus.exporter.unix
          • prometheus.exporter.windows
          • prometheus.operator.podmonitors
          • prometheus.operator.probes
          • prometheus.operator.scrapeconfigs
          • prometheus.operator.servicemonitors
          • prometheus.receive_http
          • prometheus.relabel
          • prometheus.remote_write
          • prometheus.scrape
        • pyroscope
          • pyroscope.ebpf
          • pyroscope.enrich
          • pyroscope.java
          • pyroscope.receive_http
          • pyroscope.relabel
          • pyroscope.scrape
          • pyroscope.write
        • remote
          • remote.http
          • remote.kubernetes.configmap
          • remote.kubernetes.secret
          • remote.s3
          • remote.vault
      • Compatible components
      • Standard library
        • array
        • coalesce
        • constants
        • convert
        • encoding
        • file
        • json_path
        • string
        • sys
      • HTTP endpoints
        • GraphQL API
      • Release information
        • Backward compatibility
        • Release cadence
        • Maintenance
    • Data collection
    • Release notes
  • Fleet Management
    • Introduction
      • Architecture
      • Glossary
    • Get started
      • Grafana Alloy
      • OpenTelemetry Collector
    • Set up
      • Collector onboarding
        • Standalone Alloy installations
        • Standalone OpenTelemetry Collector installations
        • Kubernetes
        • Troubleshoot
      • Configuration pipelines
        • Use an integration template
        • Create a custom Alloy pipeline
        • Create a custom OTel pipeline
        • Self-monitoring pipelines
        • Configuration deployment strategies
        • Pipeline attribute injection
        • Pipeline export injection
        • Terraform
        • GitOps
      • Connectivity options
        • AWS PrivateLink
        • Azure Private Link
        • GCP Private Service Connect
        • IP allowlists
        • Self-managed
      • Role-based access control (RBAC)
    • Streamline your workflows
    • Manage your fleet
      • Collectors
        • Check fleet status
        • Collector limits
        • Troubleshoot
          • Alerts
          • Internal metrics
          • Internal logs
          • Remote config errors
      • Pipelines
        • Check pipeline operation
        • Sync pipelines from Git
        • View pipeline history
        • Pipeline limits
        • Troubleshoot
    • Reference
      • Collector HTTP API
      • Pipeline HTTP API
      • Tenant HTTP API
  • Private connectivity
    • AWS PrivateLink
      • Configure AWS PrivateLink
      • Configure Azure Private Link
      • Configure GCP Private Service Connect
  • Observe and act
  • Observability home page
  • Monitor applications
    • Application Observability (Classic)
      • Introduction
      • Set up
        • Added resource attributes
        • Required metrics and labels
        • Uninstrumented services
        • Assess instrumentation quality
      • Host hours pricing
      • Optimize costs
      • Integrate with Frontend Observability
      • User manual
        • Service inventory
        • Service map
        • Service overview
        • Service profiles
        • Group and filter data
        • Link from RED metrics
        • Automatic baseline
        • Service overview annotations
        • Root cause analysis
        • Configuration
        • Per-service configuration
      • Release notes
        • 1.83
        • 1.82
        • 1.81
        • 1.80
        • 1.79
        • 1.78
        • 1.77
        • 1.76
        • 1.75
        • 1.74
        • 1.73
        • 1.72
        • 1.71
        • 1.70
        • 1.69
        • 1.68
        • 1.67
        • 1.66
        • 1.65
        • 1.64
        • 1.63
        • 1.62
        • 1.61
        • 1.60
        • 1.59
        • 1.58
        • 1.57
        • 1.56
        • 1.55
        • 1.54
        • 1.53
        • 1.52
        • 1.51
        • 1.50
        • 1.49
        • 1.48
        • 1.47
        • 1.46
        • 1.45
        • 1.44
        • 1.43
        • 1.42
        • 1.41
        • 1.40
        • 1.39
        • 1.38
        • 1.37
        • 1.36
        • 1.35
        • 1.34
        • 1.33
        • 1.32
        • 1.31
        • 1.30
        • 1.29.0
        • 1.28.0
        • 1.27.1
        • 1.27.0
        • 1.26.0
        • 1.25.0
        • 1.24.0
        • 1.23.1
        • 1.23.0
        • 1.22.1
        • 1.22.0
        • 1.21.0
        • 1.20.0
        • 1.19.1
        • 1.19.0
        • 1.18.0
        • 1.17.1
        • 1.17.0
        • 1.16.2
        • 1.16.1
        • 1.16.0
        • 1.15.0
        • 1.14.0
        • 1.13.0
        • 1.12.1
        • 1.12.0
        • 1.11.0
        • 1.10.0
        • 1.9.0
        • 1.8.0
        • 1.7.0
        • 1.6.1
        • 1.6.0
        • 1.5.0
        • 1.4.1
        • 1.4.0
        • 1.3.1
        • 1.3.0
        • 1.2.0
        • 1.1.0
        • 1.0.1
        • 1.0.0
        • 0.18.1
        • 0.18.0
        • 0.17.0
        • 0.16.1
        • 0.16.0
        • 0.15.0
        • 0.14.2
        • 0.14.1
        • 0.14.0
        • 0.13.0
        • 0.12.1
        • 0.12.0
        • 0.11.0
        • 0.10.0
        • 0.9.0
        • 0.8.0
        • 0.7.0
        • 0.6.0
        • 0.5.0
        • 0.4.0
      • Introduction
      • Set up
        • Instrumentation
        • Activate
      • Host-hours pricing
      • Optimize costs
      • Services catalog
        • Performance
        • Instrumentation quality
      • Service detail
        • Service overview
        • Metrics
        • Logs
        • Traces
        • Profiles
        • Quality report
        • Properties
      • Configure
    • Frontend Observability
      • Introduction
        • What you can do
        • How it works
        • Who it's for
        • Supported environments
        • Transports
        • Metas
        • Next steps
      • Quickstart
      • Get started
        • JavaScript
        • React
        • Next.js
        • Upgrading
          • Upgrading Faro
          • Upgrade to v2.0.0
      • Instrument
        • JavaScript
        • Error tracking
        • React
          • React Router v7 data router
          • React Router v7 no data router
          • React Router v6 data router
          • React Router v6 no data router
          • Upgrade to data router
          • React Router v4/v5
          • ErrorBoundary support
          • SSR support
          • Component profiling
        • Send custom signals
          • Logs
          • Events
          • Measurements
        • OpenTelemetry tracing
        • Console instrumentation
        • Tracing
        • Session tracking
        • View tracking
        • Page tracking
        • Performance instrumentation
        • Web Vitals
        • User actions
        • Navigation instrumentation
      • Configure
        • Source map uploads
          • Upload with bundlers
          • Upload with the CLI
          • Upload with cURL
          • Troubleshooting
        • Link errors to commits
        • Exclude endpoints
        • Sampling
        • Dynamic service name override
        • Process Faro telemetry data
        • Error fingerprinting
        • Auto-inject the SDK
        • Data proxy
        • Filter bots
        • Composable frontends
        • Track CSP violations
      • Visualize and explore data
        • Application performance
        • HTTP insights
        • User sessions
        • Application errors
        • Errors overview
        • Geolocation insights
        • Geolocation visualizations
        • User actions in Frontend Observability
        • Custom tabs
      • Integrate
        • Integrate with Application Observability
      • Create alerts
        • Alerts
      • Settings and policies
        • Data privacy
        • CNIL compliance
        • Create SLOs
      • References
        • Release notes
          • 1.13
          • 1.12
          • 1.11
          • 1.10
          • 1.9
          • 1.8
          • 1.7
          • 1.6
          • 1.5
          • 1.4
          • 1.3
          • 1.2
          • 1.1
          • 1.0
    • OpenLIT Observability
      • Introduction
      • Setup
      • GenAI
        • Observability
          • Setup
          • Configuration
        • Evaluations
          • Setup
          • Configuration
        • Agent Observability
      • VectorDB Observability
        • Setup
        • Configuration
      • MCP Observability
        • Setup
        • Configuration
      • GPU Observability
        • Setup
        • Configuration
    • Session Replay
      • How it works
      • Quickstart
      • Instrument
      • View session replays
      • Troubleshoot
      • Data privacy
  • Monitor infrastructure
    • Database Observability
      • Introduction
      • Set up
        • Requirements
        • MySQL
          • Self-managed
          • Amazon Aurora
          • Amazon RDS
          • Google Cloud SQL
          • Azure Flexible Server
        • PostgreSQL
          • Self-managed
          • Amazon Aurora
          • Amazon RDS
          • Google Cloud SQL
      • Monitor
        • View query performance
        • Find application queries
        • Link traces and queries
      • Investigate
        • Explain plans
        • Query samples
        • Wait events
        • Table schemas
      • Optimize
        • Slow queries
      • Configure
        • Configuration page
        • Alloy collection
        • Multiple databases
        • Telemetry status
      • Reference
        • PostgreSQL configuration
        • MySQL configuration
        • Telemetry
        • Labels
      • Troubleshoot
        • Alloy components
        • Explain plans
        • MySQL
        • PostgreSQL
      • Release notes
      • Home page
      • AWS observability
        • CloudWatch metrics
          • How collection works
          • Manage AWS accounts
          • Configure metrics scrape
          • Configure metric streams
            • Configure with CloudFormation
            • Configure with Terraform
            • Troubleshoot metric streams
          • Preconfigured dashboards and alerts
            • EC2 dashboard
            • RDS dashboard
          • Query tag data
          • Services
          • Reference
            • Metric cost calculation
            • Troubleshoot scrape jobs
        • AWS logs
          • Logs with Lambda
            • Configure CloudWatch logs
            • Configure ALB access logs
          • Logs with Firehose
            • Configure logs with Firehose
      • Azure observability
        • Configure metrics with Alloy
        • Configure Azure metrics serverless
          • Configure with Cloud Provider
          • Manage credentials
        • Configure logs with Azure Functions
        • Configure logs with Alloy
        • Supported resource types
        • Azure metric delays
        • Troubleshoot metrics collection
      • GCP observability
        • Metrics
          • Configure metrics
        • Logs
          • Configure logs
        • Dashboards and alerts
          • View and refine dashboards
          • Install and use alerts
      • RBAC roles and permissions
      • Dashboards and views settings
        • Customize service dashboards
        • Customize drilldown metrics
      • Analyze cloud resources
      • Analyze alerts and build dashboards
    • Kubernetes Monitoring
      • Release notes
      • Introduction
      • Configure Kubernetes Monitoring
        • Activate
        • Configure with Helm chart
          • Configure with wizard
          • Configure manually
          • Helm chart
            • Customize Helm chart
            • Collector reference
            • Version migration
          • Application metrics
        • Configure with other methods
          • OTel with Prometheus exporters
          • OTel with OTel receivers
          • Amazon EKS Cluster
          • remote_write
            • Helm and kube-prometheus-stack
            • Helm and Prometheus
            • Prometheus ConfigMap
            • Prometheus Operator
            • Prometheus Operator installation
          • Kube-Prometheus Helm stack migration
            • Reduce active series usage
            • Import recording and alerting rules
            • Enable multi-cluster support (optional)
          • Helm and Terraform
          • Helm and Ansible
        • Manage configuration
        • Control access
        • Troubleshoot
        • Upgrade
      • Explore your infrastructure
      • Triage your infrastructure
        • Manage availability
        • Manage stability
        • Review infrastructure conditions
        • Use Assistant health checks
        • Find usage spikes
        • CPU throttling
        • Out-of-memory issues
        • Pod count insights
        • Application latency
        • Troubleshoot with built-in tools
      • Optimize resource usage and efficiency
        • Monitor resource usage
        • Predict and analyze trends
        • CPU requests and limits for containers
        • Monitor energy use
      • Manage costs
        • Costs
        • Savings
      • Respond to alerts
      • Monitor jobs
      • Monitor non-standard workloads
    • Grafana integrations
      • Install and manage integrations using Terraform
      • Troubleshoot installations
        • On Linux using Alloy
        • On macOS using Alloy
        • On Windows using Alloy
      • Get started
      • Integrations reference
        • Aerospike
        • AI Observability
        • Alloy Health
        • Anthropic
        • Apache ActiveMQ
        • Apache Airflow
        • Apache Cassandra
        • Apache CouchDB
        • Apache Hadoop
        • Apache HBase
        • Apache HTTP server
        • Apache Mesos
        • Apache Solr
        • Apache Spark
        • Apache Tomcat
        • Apollo Server
        • Asterisk
        • AWX
        • Beyla
        • Caddy
        • Catchpoint
        • Ceph
        • Cert Manager
        • Cilium Enterprise
        • Claude Code
        • ClickHouse
        • Cloudflare
        • Cloudflare Workers
        • CockroachDB
        • Confluent Cloud integration
        • Consul
        • CoreDNS
        • Couchbase
        • Databricks
        • Discourse
        • dnsmasq
        • Docker Desktop
        • Docker
        • ElasticSearch
        • Envoy
        • etcd
        • F5 BIG-IP
        • Gitea
        • GitHub
        • GitLab
        • Go
        • HAProxy
        • HCP Consul
        • HCP Vault
        • Home Assistant
        • IBM DB2
        • IBM MQ
        • InfluxDB
        • Istio
        • Jenkins
        • Jira
        • JVM
        • Kafka
        • Linux Server
        • macOS
        • Memcached
        • Metrics Endpoint
        • Microsoft IIS
        • Microsoft SQL Server
        • MinIO
        • MongoDB Atlas
        • MongoDB
        • MySQL
        • Neon
        • Netflow
        • Nginx
        • Node.js
        • Nomad
        • NSQ
        • OpenAI Codex
        • OpenAI
        • OpenLDAP
        • OpenSearch
        • OpenStack
        • OpenTelemetry
        • OracleDB
        • PgBouncer
        • Pinecone
        • PostgreSQL
        • Presto
        • RabbitMQ
        • Raspberry Pi
        • rclone
        • Redis Enterprise
        • Redis
        • Ruby Rack
        • SAP HANA®
        • Self-hosted Grafana Loki
        • Self-hosted Mimir
        • SNMP
        • Snowflake
        • Spring Boot
        • Squid
        • Supabase
        • Temporal Cloud
        • TensorFlow Serving
        • Traefik
        • Varnish Cache
        • Vault
        • Velero
        • vSphere
        • Wildfly
        • Windows Active Directory
        • Windows
        • WSO2 Enterprise Integrator
        • WSO2 Streaming Integrator
    • Introduction
    • Pricing
    • Get started
      • Grafana Cloud setup
      • OpenTelemetry
      • Use the SDK
      • Coding agents
      • Claude Platform
    • Observe and troubleshoot
      • Analytics
      • Agents
      • Conversations
      • Cost and performance
      • Model prices
      • Coding agents
    • Evaluate and improve
      • Evaluations
      • Evaluation settings
      • Experiments
      • Run an experiment
    • Protect agents
      • Guards
    • Instrumentation
      • Framework integrations
      • Dependencies and workflows
      • Configure SDK
      • Migrate SDK
    • Data privacy and security
      • Data handling
      • Security and access
      • PII and secrets redaction
      • CLI usage statistics
    • API and SDKs
      • Generation ingest
      • Evaluation
      • Guards
      • Experiments
      • SDKs
        • Python
        • Node.js
        • Go
        • Java
        • .NET
  • Alert and measure reliability
    • Alerting
      • Introduction
        • Alert rules
          • Queries and conditions
          • Labels and annotations
        • Alert rule evaluation
          • No Data and Error states
          • Stale alert instances
          • Alert rule state and health
          • Evaluation within a group
        • Notifications
          • Contact points
          • Notification policies
          • Grouping
        • Templates
      • Configure alert rules
        • Configure Grafana-managed alert rules
        • Create and link alert rules to panels
        • Import to Grafana-managed rules
        • Configure data source-managed alert rules
        • Create recording rules
          • Create Grafana-managed recording rules
          • Create data source-managed recording rules
          • Migrate recorded queries
        • Rule sequences
        • Template annotations and labels
          • Template reference
          • Examples
          • Template language
        • Improve alert rule quality with Alert Advisor
      • Configure notifications
        • Configure contact points
          • Alertmanager
          • Amazon SNS
          • Discord
          • Email
          • Google Chat
          • Grafana IRM
          • Jira
          • Microsoft Teams
          • MQTT
          • Opsgenie
          • PagerDuty
          • Slack
          • Telegram
          • Webhook
        • Configure notification policies
        • Configure mute timings and active time intervals
        • Configure silences
        • Configure inhibition rules
        • Template notifications
          • Manage templates
          • Examples
          • Template language
          • Use images
        • Import Alertmanager configuration
        • Alert enrichment
      • Monitor alerts
        • Alerts overview page
        • View alert rules
        • View alert state
        • View alert state history
        • View notification history
        • View active notifications
        • Declare incidents from firing alerts
        • View alerting insights
      • Additional configuration
        • Configure RBAC
          • Manage access using roles
          • Manage access using folders or data sources
          • Configure silence access
        • Configure Alertmanagers
          • Use mimirtool
        • Provision Alerting resources
          • Use Terraform to provision
          • Use mimirtool to upload rules
          • Export alerting resources
          • Use the HTTP API to manage alerting resources
        • Meta monitoring
        • Performance considerations and limitations
      • Guides
        • Best practices
        • Handle connectivity errors
        • Handle missing data
        • When SLOs reduce alert noise
        • Alerting on forecasts
      • Examples
        • Multi-dimensional alerts
        • Table data
        • Trace-based alerts
        • Dynamic labels
        • Dynamic thresholds
        • High-cardinality alerts
        • Tutorials
    • Service Center
      • Overview
      • Create a service
      • Discover services
      • Provision using Terraform
      • Find and organize services
      • Respond to service issues
    • SLO
      • Introduction
      • Best practices
      • Create SLOs
      • SLI Examples
        • Availability
        • Latency
        • Multidimensional
        • Time-based
      • SLO dashboard
      • SLO performance
      • SLO reports
      • Maintenance windows
      • Manage SLOs
      • Troubleshooting
        • Configure burn-rate notifications
        • RBAC
        • Provision using HTTP API
        • Additional data sources
    • Label management
  • Manage on-call and incidents
    • Introduction
      • Routing and escalation
    • Get started
    • Set up
      • Migrate
        • Migrate with the migration tool
        • Migrate manually
        • Migrate from OnCall OSS
      • Manage access
        • Roles and permissions
        • Teams
      • Admin settings
      • User profile
    • Connect integrations
      • Alert sources
        • Alertmanager
        • Amazon SNS
        • AppDynamics
        • Datadog
        • ElastAlert
        • Fabric
        • Grafana Alerting
        • Inbound email
        • Jira
        • Kapacitor
        • Direct paging
        • New Relic
        • Pingdom
        • PRTG
        • Sentry
        • ServiceNow
        • Stackdriver
        • UptimeRobot
        • Zabbix
        • Zendesk
      • Chat and collaboration
        • Slack
        • Microsoft Teams
        • Telegram
        • Google Workspace
        • OpenAI
        • Zoom
      • Development and operations
        • GitHub
        • Jira
        • StatusPage
      • Custom webhook integrations
        • Incoming webhooks
          • OnCall webhooks
          • Incident webhooks
        • Outgoing webhooks
    • Configure escalation and routing
      • Escalation chains
      • Alert grouping
      • Routing rules
      • Labels
        • Configure labels
        • Service dependencies
      • Alert templates
        • Advanced templates
    • Configure schedules
      • Create schedules
      • Schedules as code
      • Import schedules
      • Schedule examples
      • Shift swaps and overrides
        • Add overrides
        • Manage shift swaps
        • Automate shift swaps
    • Notify responders
      • Notification channels
      • Notification rules
      • Phone and SMS
    • Respond to alerts
    • Manage incidents
      • Customize incident response
        • Incident response settings
        • Incident channels
        • Incident announcements
        • Incident briefings
        • Private incidents
      • Declare incident
      • Collaborate
        • Add participants
        • Status updates
        • Manage tasks
      • Incident timeline
      • Investigate
      • Resolve and learn
    • Measure and improve
      • Alert group insights
      • Incident insights
    • Guides
      • Best practices
        • Integrations
        • Labels strategy
        • Alert routing
        • Alert groups
        • Escalation chains
        • On-call schedules
        • Incidents
        • Teams and access control
      • Jira issue sync
      • Twilio SMS and call routing
    • Reference
      • OnCall API
        • Alert groups API
        • Alerts API
        • Escalation chains API
        • Escalation API
        • Escalation policies API
        • OnCall organizations API
        • OnCall teams API
        • OnCall users API
        • Integrations API
        • OnCall shifts API
        • OnCall user groups API
        • Outgoing webhooks API
        • Personal notification rules API
        • Resolution notes API
        • Routes API
        • Schedules API
        • Shift swap API
        • Slack channels API
      • Incident API
        • Get started
        • Authentication
        • Client libraries and SDKs
        • Reference
      • Incident API errors
      • Rate limits
      • Incident query syntax
      • Data retention
  • Test and validate
    • Agentic testing
      • Introduction
      • Create browser tests
      • Secrets management
    • Performance testing
      • Introduction
      • Get started
        • Run your first tests
        • Run cloud tests from the CLI
        • Run your first browser tests
      • Author and run tests
        • Use the test builder
        • Use the script editor
        • Script Authoring mode
        • Use the browser recorder
        • Use the CLI
        • Use k6 extensions
        • Authenticate on the CLI
        • Schedule a test
        • Send notifications
        • About test scenarios
        • Create and manage secrets
        • Use load zones
        • Set up Private Load Zones
          • Troubleshoot
        • Use k6 versions in Grafana Cloud
        • Cloud scripting extras
          • Cloud options
          • Cloud tags
          • Cloud execution context variables
          • Cloud environment variables
      • Analyze test results
        • Inspect test results
          • Inspect checks
          • Inspect logs
          • Inspect thresholds
          • Inspect request data
          • Inspect metrics
        • Inspect browser results
        • Get Cloud Insights
          • Configure
          • Reference
        • Correlate results in Grafana
        • Correlate results with Grafana Cloud Traces
        • Collect profiles with Grafana Pyroscope
        • Compare tests
        • Manage test results
        • Export test results
      • Manage projects and users
        • Manage projects
        • Manage labels and cost attribution
        • Stack limits
        • Manage project limits and quotas
        • Configure RBAC
          • Manage roles and permissions
        • Configure LBAC
        • Manage static IP addresses
        • Usage reports
        • Audit trails
      • Troubleshoot
      • Reference pages
        • Cloud IPs
        • Cloud REST API
          • Labels
          • Load zones
          • Projects
          • Schedules
          • Load tests
          • Authorization
          • Test runs
          • Metrics
          • Deprecated REST API
            • Organizations
            • Projects
            • Tests
            • Test Runs
            • Test Run Metrics
            • Cloud test status codes
            • Error Reference
        • Test result metrics
        • Query types
          • Aggregation methods for metric queries
        • Migrate from app.k6.io to Grafana Cloud k6
    • Synthetic Monitoring
      • Introduction
      • Get started
        • Create your first check
        • Create a MultiHTTP check
        • Create a k6 scripted check
        • Create a k6 browser check
      • Set up
        • Grafana Cloud
        • Grafana OSS and Enterprise
        • Private probes
        • Provision Synthetic Monitoring resources
      • Create checks
        • Check types
          • Ping check
          • HTTP check
          • DNS check
          • TCP check
          • Traceroute check
          • MultiHTTP check
          • k6 scripted check
          • k6 browser check
        • Public probes
        • Manage k6 versions
        • Organize checks in folders
        • Write resilient check scripts
      • Analyze results
        • Check metrics
        • Uptime and reachability
        • Visualize check execution
        • Custom labels
        • Troubleshoot a failing check
      • Configure alerts
        • Configure per-check alerts
        • Configure custom alerts
        • Configure legacy alerts
      • Manage users and teams
      • Migrate to un-prefixed labels
      • System labels
      • Knowledge graph integration
      • Cloud REST API
  • Connect to data sources
    • Manage data sources
    • Get started with an existing data source
    • Data sources
      • Concepts
      • Alertmanager
      • Amazon CloudWatch
        • Configure
        • AWS authentication
        • Query editor
        • Template variables
        • Annotations
        • Alerting
        • Troubleshooting
      • Azure Monitor
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Elasticsearch
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Google Cloud Monitoring
        • Configure
        • Google authentication
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Graphite
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • InfluxDB
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Jaeger
        • Configure
        • Query editor
        • Troubleshooting
      • Loki
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • MySQL
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • OpenTSDB
        • Configure
        • Query editor
        • Alerting
        • Annotations
        • Troubleshooting
      • Parca
        • Configure
        • Query editor
        • Troubleshooting
      • PostgreSQL
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Prometheus
        • Configure
          • Azure authentication (deprecated)
          • AWS authentication (deprecated)
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Pyroscope
        • Configure
        • Trace to profiles
        • Query profile data
        • Troubleshooting
      • Tempo
        • Configure Tempo
          • Trace to logs
          • Trace to metrics
          • Trace to profiles
          • Additional settings
          • Provision
          • Trace correlations
          • Search traces
          • Write TraceQL queries
          • TraceQL query examples
        • Service Graph and Service Graph view
        • Span filters
        • Troubleshooting
      • TestData
        • Configure
        • Query editor
        • Annotations
        • Alerting
        • Troubleshooting
      • Zipkin
        • Configure
        • Query editor
        • Troubleshooting
      • General troubleshooting
    • Private data source connect (PDC)
      • Configure private data source connect (PDC)
      • PDC over Tailscale
      • Optimize data source connections
      • PDC scalability and security
      • Connect the PDC agent via AWS PrivateLink
      • Connect the PDC agent via Azure Private Link
      • Connect the PDC agent via GCP Private Service Connect
      • PDC agent CLI reference
      • PDC agent metrics
      • Troubleshoot PDC
    • Multi-stack data sources
  • Optimize data
    • Adaptive Metrics
      • Introduction
      • Review and apply recommendations
        • Understand recommended rules
      • Create rules
        • Define aggregation rules
        • Understand aggregation delay
      • Create exemptions
      • Monitor
      • Manage as code
        • Adaptive Metrics API
        • Adaptive Metrics Terraform provider
        • Configure segmentation
        • Recommendation configurations
        • Enable auto-apply
        • Manage access to Grafana Adaptive Metrics
      • Troubleshoot discarded raw samples
      • Troubleshoot your aggregated metrics query
    • Adaptive Profiles
      • Introduction
      • Boost services
      • Guides
        • Troubleshoot Adaptive Profiles boosts
      • Monitor
    • Adaptive Logs
      • Introduction
      • Create drop rules
      • Manage as code
        • Adaptive Logs API
      • Create exemptions
        • Pause Adaptive Logs
      • Archive logs
      • Monitor
        • Configure RBAC
        • Turn off Pause Adaptive Logs
        • Set up fleet-managed Adaptive Logs
        • Configure segments
    • Adaptive Traces
      • Introduction
      • Get started
      • Query dropped traces
        • Investigate anomalies
        • Use diversity sampling
        • Use volumetric sampling
      • Create policies
      • Monitor
        • Configure RBAC
      • Guides
        • Policy evaluation example
        • Best practices for policies
        • Onboard a group of services
        • Drop low-value traces to reduce noise
        • Focus on value, not volume
        • Optimize egress costs
      • Manage as code
        • Adaptive Traces API
      • Reference
        • Policy types
  • AI tools
  • Introduction to Grafana AI
  • Machine learning
    • Forecasting
      • View, query, and alert on forecasts
      • Detect anomalies outside the forecast
      • Forecasting examples
      • Model options
      • Configure holidays
    • Detect outliers in a group
      • View, query, and alert on outliers
      • Outlier detection examples
    • Sift
      • Sift configuration
      • Sift investigations
      • Sift analyses
        • Error pattern logs
        • HTTP error series
        • Kube crashes
        • Log query
        • Metric query
        • Noisy neighbors
        • Recent deployments
        • Resource contention
      • Sift panel
      • Configure RBAC
      • Provision via Terraform
      • Usage limits
  • MCP servers
    • OSS MCP server
      • Introduction
      • Clients
        • Claude Desktop
        • Cursor
        • Codex CLI
        • VS Code Copilot
        • Claude Code
        • Gemini CLI
        • Windsurf
        • Zed
      • Set up
        • Install with uvx
        • Install with Docker
        • Install the binary
        • Deploy with Helm
        • Client configuration examples
      • Reference
        • MCP tools
      • Configure
        • Authentication
        • Transports and addresses
        • Enable and disable tools
        • Client TLS
        • Server TLS
        • Multi-organization and headers
        • Command-line flags
        • Health check
      • Guides
        • Query metrics with Prometheus
        • Query logs with Loki
        • Search and inspect dashboards
        • Manage alert rules
        • Generate deeplinks
        • Run a panel query
        • Incident
        • Query metrics with InfluxDB
      • Developer
        • Go SDK
        • Observability
        • Build and test
      • Usage statistics
      • Troubleshooting
        • Grafana version
    • Cloud MCP Server
    • Register an OAuth client
  • LLM plugin
    • Enable LLM features
  • gcx CLI
    • Introduction to gcx
    • Install gcx
    • Authenticate gcx
    • Configure gcx
    • Migrate your gcx configuration
    • Usage statistics
    • Keychain credential storage
    • User guides
      • Dashboards as code
      • Explore and modify resources
      • Manage resources
      • Lint resources
      • Diagnose missing telemetry
      • Manage Assistant Watchers
    • CLI reference
  • Platform
  • Security and account management
    • Account management
      • Manage account using Cloud Portal
      • Usage Insights dashboards
      • Availability by region
      • URL formats by region
      • Grafana Cloud Stack
        • Stack architecture recommendations
        • Manage stacks
        • Administer hosted Grafana
        • Manage database configuration
          • Configure Loki settings
            • Configure Loki settings - API
      • Connect your Slack workspace
      • Support options
      • Authentication and authorization
        • Multi-factor authentication (MFA)
        • User roles and permissions
          • Plan your RBAC rollout strategy
          • Basic and fixed roles permissions
          • RBAC permission actions and scopes
          • Create custom roles
          • Assign RBAC roles
          • Manage RBAC roles
          • Configure RBAC in Grafana
          • Provisioning RBAC with Grafana
          • Provisioning RBAC with Terraform
          • RBAC for app plugins
          • Plugin role definitions
        • Grafana Cloud Access Policies
          • Create access policies and tokens
          • Using an access policy token
          • Manage data source credentials
          • IP range based access control
          • Label-based access control (LBAC)
        • Service accounts
          • Migrate API keys
      • Manage secrets
        • Configure AWS keeper
        • Troubleshoot AWS keeper
      • List of Grafana Cloud IP addresses to add to your allowlist
  • Pricing and usage
    • Host hours
    • Volume discounts
    • Usage limits
    • Plans and stack tiers
    • Metrics
    • Logs
    • Traces
    • Profiles
    • Users
    • IRM
    • Knowledge graph
    • Performance Testing
      • k6 calculator
    • Assistant
  • Cost Management and Billing
    • Introduction
    • Set up
      • Configure RBAC for Cost Management and Billing
      • Configure access for FOCUS API
      • Set up alerts
    • Monitor usage
      • Metrics
      • Assistant
    • Attribute costs
      • Set up cost attribution
      • Understand attribution labels
      • View attribution reports
    • Create usage alerts
      • Create usage and cost alerts
      • Create anomaly alerts
      • Manage usage and cost alerts
    • Manage invoices
      • Find and read your invoice
        • Reconcile invoices
    • FOCUS
      • Download through the API
      • Download in the application
    • Analyze and reduce costs
      • Metrics
        • Usage groups
          • Configure usage groups
            • Create a new configuration
            • Update an existing configuration
            • Delete an existing configuration
        • Prometheus
          • Historical cardinality
          • Live cardinality management dashboards
          • Grafana Explore
          • Prometheus API
          • Native histograms cardinality API
        • Graphite
      • Logs
        • Log Volume Explorer
        • Grafana Explore
        • Query limit policies
      • Reduce costs
        • Metrics costs
          • Adjust your DPM
          • Client-side filtering
          • Graphite metrics
        • Logs costs
          • Fair use query costs
        • Traces costs
        • Profiles costs
        • Application Observability costs
        • Frontend Observability costs
        • Synthetic Monitoring costs
        • Performance Testing costs
        • IRM costs
        • Database Observability costs
  • Assistant
    • Introduction
    • Pricing
    • Get started
      • Grafana Cloud
      • Self-managed Grafana
    • Configure
      • Assistant rules
      • MCP servers
      • IRM webhooks
      • Slack integration
      • Investigation alerts
      • Pages
      • Install a Page as an app
      • Terraform
      • Sandbox images
    • Privacy and security
      • Data privacy
      • Data security
      • Manage access (RBAC)
    • Assistant capabilities
      • Workspace
      • Pages
      • Learn mode
      • Assistant CLI
      • Create Skills
      • Automations
      • Infrastructure memory
      • Assistant Watchers
      • Assistant Investigations
      • Assistant Search
      • Knowledge Graph mode
      • Managed Sandboxes
    • Prompting guides
      • Onboard and learn
      • Query data
      • Manage dashboards
      • k6 script authoring
      • Navigate Grafana resources
      • Manage alerts
      • Incident response
      • Fleet management
      • Fix a review finding
    • SDK
      • TypeScript SDK
      • Plugin extensions
      • HTTP API
        • Conversations
        • Rules
        • Skills
        • Quickstarts
        • MCP servers
        • Automations
        • Token limits
  • Workflows
    • Introduction
    • Get started
    • Build workflows
      • Start from a blueprint
      • Create workflows
      • Configure triggers
      • Use expressions
      • Load incident data
      • Load alert group data
    • Manage and monitor
      • Manage access
      • Manage secrets
      • Observe runs
      • Troubleshoot
    • Manage as code
      • Build with an AI agent
      • Use gcx
      • Use the API
      • Use Terraform
    • Reference
      • Step and trigger types reference
      • Event payloads
      • API reference
  • Mobile app
    • Get started
    • Install and sign in
    • Configure push notifications
    • Settings and accounts
    • IRM on mobile
      • Manage schedules and shifts
      • Respond to alert groups
      • Declare and respond to incidents
    • Assistant on mobile
    • Dashboards on mobile
    • Troubleshooting
  • Knowledge graph
    • Introduction
      • Insights
    • Get started
      • Prerequisites
      • Troubleshoot data issues
      • Datasets
        • Kubernetes dataset
        • Host Monitoring dataset
        • Application Observability dataset
          • Application Observability metrics
        • AWS dataset
        • Azure dataset
        • GCP dataset
        • Dataset for additional frameworks
    • Use cases
      • Monitor services
      • Identify unhealthy infrastructure
      • Investigate incidents
      • Explore dependencies
      • Track changes
    • Explore features
      • Entity catalog
        • Service overview
        • Entity details
      • Entity graph
      • RCA workbench
      • Grafana Assistant
    • Configure
      • Entities and relations
      • Custom RED metrics mapping
      • Custom resource metrics mapping
      • Pre-defined dashboards
      • Logs correlation (deprecated)
      • Telemetry correlation
        • Logs
        • Traces
        • Profiles
      • Service graph relationships
      • Client-side metric generation
      • Thresholds
      • Alerts
        • Amends
        • Failure alerts
        • Existing alerts
      • Health targets
      • AI-suggested SLOs
      • Notifications
        • Create notification rules
      • Explore SLO breach
      • Traces metrics generation
      • Suppress insights
      • Retained labels
    • Advanced configuration
      • Map metrics
        • Amends
        • Failure
        • Resource utilization and saturation
      • Enable metrics collection
        • Knowledge graph rules
          • Express
          • Flask
          • gRPC
          • Loopback
          • Spring Boot
        • Data stores
          • MongoDB
          • MySQL
          • PostgreSQL
          • Redis
        • Infrastructure
          • Istio
          • Node
        • Messaging frameworks
          • Kafka
          • RabbitMQ
        • Run times
          • GoLang
          • Java
          • NodeJS
        • Metric counts
    • Reference
      • Environment and region
      • Understand how the knowledge graph processes data
      • Default insights
      • Insights categories
      • Causality
      • Notifications
      • Knowledge graph data source
  • Release life cycle
  • Copyright notice
  • Rolling release channels
Scroll for more
Read this in Grafana Cloud
Is this page helpful?
Still have questions?
Ask your questions. Let AI do the heavy lifting.
Ask AI icon
Newsletter icon
Get every update
Subscribe to our newsletter
By submitting, you agree to our Privacy policy
  • Overview
  • Pricing
  • What's in the free tier?
  • AI Assistant
  • Dashboards & Visualization
  • Performance & Load Testing
  • Incident Response & Management
  • AI Investigations
  • What’s New
  • Grafana Cloud Status
Solutions
  • AI Observability
  • Full-Stack Observability
  • Infrastructure & Cloud Observability
  • Digital Experience Monitoring
  • Scaled Prometheus
  • Cost Management & Optimization
  • Site Reliability
  • Log Management
  • Migrate to OpenTelemetry
Integrations
  • All Integrations
  • All Plugins
  • AWS
  • Google Cloud
  • Microsoft Azure
  • Kubernetes
  • Datadog
  • New Relic
Open Source
  • Our Projects
  • GitHub
  • Downloads
  • Dashboard Templates
Learn
  • Documentation
  • Blog
  • Community
  • Events
  • Observability Survey & Reports
Company
  • About Grafana Labs
  • Careers
  • Partnerships
  • Newsroom
  • Success Stories
  • Contact Us
  • Getting Help
  • Professional Services
  • Hey AI
Compare
  • Datadog vs. Grafana Cloud
  • Dynatrace vs. Grafana Cloud
  • Elasticsearch vs. Grafana Cloud
  • New Relic vs. Grafana Cloud
  • PagerDuty vs. Grafana Cloud
  • Splunk vs. Grafana Cloud
Grafana Labs x unique logomark
Donut take our word for it. Try Grafana Cloud today.
Grafana Cloud StatusLegal & SecurityTerms of ServicePrivacy PolicyTrademark Policy
Copyright 2026 © Grafana Labs
