Skip to main content
Add query editor help
Query editors support the addition of a help component to display examples of potential queries. When the user clicks on one of the examples, the query editor is automatically updated. This helps the user to make faster queries.
  1. In the src directory of your plugin, create a file QueryEditorHelp.tsx with the following content:
    import React from 'react';
    import { QueryEditorHelpProps } from '@grafana/data';
    export default (props: QueryEditorHelpProps) => {
    return <h2>My cheat sheet</h2>;
  2. Configure the plugin to use QueryEditorHelp:
    import QueryEditorHelp from './QueryEditorHelp';
    export const plugin = new DataSourcePlugin<DataSource, MyQuery, MyDataSourceOptions>(DataSource)
    .setConfigEditor(ConfigEditor)
    .setQueryEditor(QueryEditor)
    .setQueryEditorHelp(QueryEditorHelp);
  3. Create a few examples of potential queries:
    import { QueryEditorHelpProps, DataQuery } from '@grafana/data';
    const examples = [
    title: 'Addition',
    expression: '1 + 2',
    label: 'Add two integers',
    title: 'Subtraction',
    expression: '2 - 1',
    label: 'Subtract an integer from another',
    return (
    <div>
    <h2>Cheat Sheet</h2>
    {examples.map((item, index) => (
    <div className="cheat-sheet-item" key={index}>
    <div className="cheat-sheet-item__title">{item.title}</div>
    {item.expression ? (
    <div
    className="cheat-sheet-item__example"
    onClick={(e) => props.onClickExample({ refId: 'A', queryText: item.expression } as DataQuery)}
    <code>{item.expression}</code>
    </div>
    ) : null}
    <div className="cheat-sheet-item__label">{item.label}</div>
    </div>
    </div>
