Extend configurations
The .config/
directory holds the preferred configuration for the different tools used to develop, test, and build a Grafana plugin. Although you can make changes, we recommend against doing so. Instead, follow the guidance in this topic to customize your tooling configs.
Do not edit the .config/
directory or extend the tooling configurations. If you attempt to do so, then you may experience issues such as failure to compile or load in Grafana. Instead of changing the files directly, follow the instructions in this topic to make advanced configurations.
Extend the ESLint config
Edit the .eslintrc
file in the project root to extend the ESLint configuration:
Example:
// Eslint configuration provided by @grafana/create-plugin
"extends": "./.config/.eslintrc",
"rules": {
"react/prop-types": "off"
The following example can be used to disable deprecation notices.
"overrides": [
"files": ["src/**/*.{ts,tsx}"],
"rules": {
"deprecation/deprecation": "off"
Extend the Prettier config
Edit the .prettierrc.js
file in the project root to extend the Prettier configuration:
Example:
module.exports = {
// Prettier configuration provided by @grafana/create-plugin
...require('./.config/.prettierrc.js'),
semi: false,
Extend the Jest config
There are two files in the project root that belong to Jest: jest-setup.js
and jest.config.js
jest-setup.js
: This file is run before each test file in the suite is executed. It sets up Jest DOM for the testing library and applies some polyfills. For more information, refer to the Jest documentation.
jest.config.js
: This is the Jest config file that extends the Grafana config. For more information, refer to the Jest configuration documentation.
ESM errors with Jest
If you see SyntaxError: Cannot use import statement outside a module
when running Jest or npm run test
see Troubleshooting.
Extend the TypeScript config
To extend the TS configuration, edit the tsconfig.json
file in the project root:
Example:
// TypeScript configuration provided by @grafana/create-plugin
"extends": "./.config/tsconfig.json",
"compilerOptions": {
"preserveConstEnums": true
Extend the Webpack config
Follow these steps to extend the Webpack configuration that lives in .config/
1. Create a new Webpack configuration file
Create a webpack.config.ts
file in the project root. This file extends the Webpack config provided by create-plugin
2. Merge the Grafana config with your custom config
Use the following webpack-merge command:
import type { Configuration } from 'webpack';
import { merge } from 'webpack-merge';
import grafanaConfig from './.config/webpack/webpack.config';
const config = async (env): Promise<Configuration> => {
const baseConfig = await grafanaConfig(env);
return merge(baseConfig, {
// Add custom config here...
output: {
asyncChunks: true,
export default config;
The following alternative customization excludes "libs" via rules in addition to "node_modules". It also provides fallbacks that are no longer present in Webpack v5.
import { mergeWithRules } from 'webpack-merge';
const config = async (env: any): Promise<Configuration> => {
const customConfig = {
module: {
rules: [
exclude: /(node_modules|libs)/,
resolve: {
fallback: {
crypto: require.resolve('crypto-browserify'),
fs: false,
path: require.resolve('path-browserify'),
stream: require.resolve('stream-browserify'),
util: require.resolve('util'),
return mergeWithRules({
module: {
rules: {
exclude: 'replace',
})(baseConfig, customConfig);
3. Update the package.json
to use the new Webpack config
Update the scripts
in the package.json
to use the extended Webpack configuration:
-"build": "webpack -c ./.config/webpack/webpack.config.ts --env production",
+"build": "webpack -c ./webpack.config.ts --env production",
-"dev": "webpack -w -c ./.config/webpack/webpack.config.ts --env development",
+"dev": "webpack -w -c ./webpack.config.ts --env development",
