Add features for Explore queries
Explore allows you to make ad-hoc queries without having to use a dashboard. This is useful when you want to troubleshoot or learn more about the data. Your data source supports Explore by default and uses the existing query editor.
This guide explains how to extend functionality for Explore queries in a data source plugin.
Add an Explore-specific query editor​
To extend the Explore functionality for your data source, define an Explore-specific query editor.
Create a file
ExploreQueryEditor.tsxin thesrcdirectory of your plugin, with content similar to this:src/ExploreQueryEditor.tsximport React from 'react';import { QueryEditorProps } from '@grafana/data';import { QueryField } from '@grafana/ui';import { DataSource } from './DataSource';import { MyQuery, MyDataSourceOptions } from './types';type Props = QueryEditorProps<DataSource, MyQuery, MyDataSourceOptions>;export default (props: Props) => {return <h2>My Explore-specific query editor</h2>;}; -
Modify your base query editor in
QueryEditor.tsxto render the Explore-specific query editor. For example:src/QueryEditor.tsx// [...]import { CoreApp } from '@grafana/data';import ExploreQueryEditor from './ExploreQueryEditor';type Props = QueryEditorProps<DataSource, MyQuery, MyDataSourceOptions>;export default (props: Props) => {const { app } = props;switch (app) {case CoreApp.Explore:return <ExploreQueryEditor {...props} />;default:return <div>My base query editor</div>;}};
Select a preferred visualization type​
By default, Explore identifies your returned data (time series, logs, or something else) and creates the right type of visualization.
However, if you want a custom visualization, you can add a hint to your returned data frame by setting the meta attribute to preferredVisualisationType.
Construct a data frame with specific metadata like this:
const firstResult = createDataFrame({
fields: [...],
meta: {
preferredVisualisationType: 'logs',
For possible options, refer to PreferredVisualisationType.
