Plugins 〉Cognite Data Fusion
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Cognite Data Fusion
- Overview
- Installation
- Change log
- Related content
Cognite Data Source for Grafana
Grafana datasource for Cognite Data Fusion.
Features
- Easily create graphs with timeseries from Cognite Data Fusion
- Perform custom queries to filter for specific timeseries
- Use variables to create templated dashboards
- Add event annotations to graphs
- Apply custom functions to timeseries
Installation
The easiest way to install this plugin is to follow the installation instructions on this page.
Documentation
To learn more about the connector please visit our documentation
Feedback
If you find any bugs, or have any suggestions, please visit support portal.
Development
See here.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Cognite Data Fusion on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Cognite Data Fusion from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Releases
This article documents the ongoing improvements we're making to the Cognite Data Source for Grafana.
4.2.1 - November 28th, 2024
Bug fixes
- Upgrade plugin dependencies to fix CVEs
4.2.0 - June 17th, 2024
Features
- Adds time zone support for aggregated time series, the user can select the timezone using the Grafana time range options.
4.1.3 - May 7th, 2024
Bug fixes
- Fixed performance issue with parser which occurs when a fairly long custom time series query is used.
4.1.2 - March 14th, 2024
Bug fixes
- Fixed an issue with Events resource timestamp columns where it was previously displayed in epoch format and now it is displayed in human-readable format
4.1.1 - February 14th, 2024
Bug fixes
- Fixed an issue with the custom query where floats with more than 7 digits after the decimal point were causing syntax error
4.1.0 - February 7th, 2024
Features
- Added new time series property
unitExternalId
- Added support to filter time series by
unitExternalId
andunitQuantity
in custom queries - Added support to query data points with unit conversion in custom queries
- Small UI improvement to the query field in the custom query tab
Bug fixes
- Patched plugin dependencies to fix deprecation errors
4.0.1 - November 7th, 2023
Bug fixes
- Patched regressions introduced after the migration to React:
- Events table
activeAtTime
filter is now working as before - Annotations filters are applied correctly as before
- Added back hints and examples for annotation query
- Events table
- Multiple dependencies have been updated to fix security vulnerabilities
4.0.0 - October 12th, 2023
Features
- Migrate Annotation editor from Angular to React
- Bumped minimum Grafana version requirement to v10
- Events are returned in dataframe format
3.1.0 - May 10th, 2023
Features
- Added support for the new version of CDF Data Models (GraphQL)
- Added an option to sort Events table
3.0.1 - April 3rd, 2023
- Fixed the wording for the CDF host paramether in the plugin configuration
3.0.0 - November 21st, 2022
- The connector dependencies has been updated and the connector now requires Grafana v8 or later.
- Flexible Data Modelling is now added as a preview feature. You need enable it on the data source settings. The plugin will visualize tables and time series which has been modelled in Cognite's new Flexible Data Model
- Extraction Pipelines is added as a preview feature. You can now see the latest status of your extraction pipelines and runs inside Grafana.
- Advanced filtering of events now also supports aggregates.
- Variables created with an asset-query can now return
externalId
andname
as value in addition toid
. This is useful when using a variable inside FDM graphQl query.
2.6.0 - August 4th, 2022
Kubernetes grafana operator support
- The connector now supports being used with the Kubernetes
Grafana operator as
the
GrafanaDataSource CRD.
In the operator you specify the Cognite project in
defaultProject
parameter and the API URL as theclusterUrl
parameter. In the operator you can specify a data source using the syntax below:
datasources:
- access: proxy
editable: false
isDefault: true
jsonData:
clusterUrl: westeurope-1.cognitedata.com # other examples are api.cognitedata.com, az-eastus-1.cognitedata.com etc
defaultProject: <cdf-project>
oauthPassThru: true
type: cognitedata-datasource
Advanced filter support for events (alpha)
- Advanced filtering support for events have been added as separate input box in the events tab. Enable this in the data source settings.
- API documentation
Relationships updates
- All drop downs in the relationships tab are now sorted and searchable
2.5.0 - June 1, 2022
Relationships support
- The connector now supports the CDF relationships resource type. Read more about relationships at Relationships documentation.
- With relationships support you can now fetch time series based on relationships in the "Time series from asset" tab. Relationships can be filtered on data set, labels and active relationships based on the time filter selected in Grafana.
- A new relationships tab has been added which can be used to utilize Grafana's Node Graph visualization plugin, or a new (alpha) custom visualization plugin which can be found at cognite-grafana-relationships-visualization
Templates support (preview)
- A new templates tab has been added which support the CDF templates feature (preview). Enable this in the data source settings.
- Using templates with Grafana will allow you to dynamically scale your dashboards when adding equipment.
- Documentation: https://docs.cognite.com/dev/concepts/resource_types/templates
2.4.0 - August 20, 2021
Features
- OAuth 2.0 client credentials grant flow to authenticate and authorize against CDF.
2.3.0 - June 1, 2021
Features
- Ability to link variables so that the value of one variable can be used as an input to another.
2.2.0 - April 6, 2021
Features
- Tabular representation of events data.
- Event annotation query shows unfinished events by default.
- Support for OAuth authentication with CDF.
- Option to fetch only the latest data point for the time series.
2.1.1 - November 23, 2020
Bug fixes:
- Support variables in
time series by asset
query. In version 2.1.0$variable
used as anAsset tag
worked for earlier created dashboards, but it was impossible to create a new panel with the same capability.
2.1.0 - November 19, 2020
- The data source requires Grafana version
7.0.6
or above. - Time series are now saved to dashboards by their
externalId
where possible. This allows you to switch between CDF projects that contain time series with matchingexternalIds
. - Support for synthetic time series alignment.
- Rewrote data source GUI to React.
- Updated CDF logo to match light/dark theme.
2.0.1 - August 25, 2020
Bug fixes:
[Custom query] Option to display legend label as a plain text instead of expression
Example for query:
ts{id=1} + ts{id=2} + 1
:- User label
custom name
results incustom name
label. (No specific timeseries referenced in the label) - User label
{{name}}
results intimeseries_name_1 + timeseries_name_2 + 1
label. (This works the same way as before)
- User label
[Custom query] Improved error handling
- HTTP 500 errors messages are visible from the GUI
[Custom query] Default granularity falls back to 1 second if shorter value is provided
- Previously, selecting a time span less than 10 minutes resulted in a HTTP 400 error.
2.0.0 - June 29, 2020
General improvements
- A new query language inspired by PromQL and compatible with synthetic time series in CDF. Learn more.
- Support for all filtering capabilities available in CDF API v1 for the respective resource types (assets, events, times series).
- Any future filtering capabilities added to CDF API v1 will be automatically supported by the data source (filters are passed directly to CDF).
- Query expressions resulting in errors now displays error messages in the UI.
- Regular expressions filtering can be used as part of the Query expression. The Filter field has been removed.
- Supports CDF API v1, with no dependency to older API versions.
- New documentation section for the connector, covering installation and administration, upgrades, feature documentation and getting started information.
- Compatibility with Grafana 7.0. Learn more about the new capabilities here.
Time series and custom queries
- You can now access time series that don't have the
legacyName
attribute populated with the data source. - Setting
Root Asset
in the Custom query tab is no longer required. This filter has been removed from the UI and is now available as part of a custom query expression. For example:ts{rootAssetIds=[12335453, 3455566]}
. - Custom query aggregation requests are less likely to trigger rate limiting in CDF API.
- Functions:
- Support for string time series through the new
map
function allows you to convert string values to numeric values which can then be plotted by Grafana. For example:map(ts{externalId='pump_29'}, ['OPEN', 'CLOSED'], [1, 0], -1)
. - Use the
on_error
function to gain control over query calculations resolving with errors, such as division by 0. The function allows you to set a default value for individual data points that resolved with errors. Without theon_error
function, the chart shows empty space in those places. Example:on_error(1/ts{externalId='canBeZero'}, 0)
. - Variable length functions:
max(x1, x2, ...)
,min(...)
,avg(...)
. - The
power
function has been renamed topow
. - These functions are no longer supported:
acos
,asin
,atan
,ceil
,celing
,cot
,degrees
,floor
,log
,log2
,log10
,radians
,sign
,tan
,atan2
,mod
,truncate
,rand
,crc32
,conv
,div
- These aggregates are no longer supported by custom queries:
max
,min
,count
,sum
,continuousVariance
,discreteVariance
,totalVariation
. - Short names for aggregation functions are no longer supported. Use full names
instead:
average
,interpolation
,stepInterpolation
. - The
timeseries{options}
function has been renamed tots{options}
. - Filtering:
- New options:
isString=false
,externalId='my_id'
,id=123
,externalIdPrefix='my_'
- Relate to asset tree with:
assetSubtreeIds=[{id=754173880412890},{externalId="23-TE-96148"}]
,assetIds=[123, 234]
,assetExternalIds=['pump_1', 'pump_2']
,rootAssetIds=[123, 234]
- New range filters for create and updated time:
createdTime={min=0, max= 1593018651}
,lastUpdatedTime={min=1493018651, max= 1593018651}
- Select time series based on dataSet membership:
dataSetIds=[{externalId='Prediction Model A'},{id=123}]
path
is no longer supported- See the full list of
supported filters
for the
ts{}
expression.
- New options:
Annotations
- New filters:
assetExternalIds
,rootAssetIds
,dataSetIds
,externalIdPrefix
,source
. - Find active events in range with the
activeAtTime
filter. IfendTime
is null, the event is active fromstartTime
onwards. TheactiveAtTime
filter will match all events that are active at some point frommin
tomax
. Example:activeAtTime={min=1591018651, max= 1593018651}
. description
supports only regular expression operators=~
, and!=
.minStartTime
/maxStartTime
has been replaced by thestartTime={min=0, max= 1593018651}
filter.minEndTime
/maxEndTime
has been replaced by theendTime={min=0, max= 1593018651}
filter, enabling you to also filter for events without theendTime
set:endTime={isNull=true}
.minCreatedTime
/maxCreatedTime
has been replaced by thecreatedTime={min=0, max= 1593018651}
filter.minLastUpdatedTime
/maxLastUpdatedTime
has been replaced by thelastUpdatedTime={min=0, max= 1593018651}
filter.assetSubtrees
has been replaced by theassetSubtreeIds=[{id=754173880412890},{externalId="23-TE-96148"}]
filter which introduces support forId
/ExternalId
input.- These filters are no longer supported:
sort
,dir
,limit
,offset
,sourceId
. - See the full list of
supported filters
for the
events{}
expression.
Templating
- New filters:
parentIds
,parentExternalIds
,rootIds
,dataSetIds
,externalIdPrefix
,root
. - The
description
field supports only regular expression operators=~
, and!=
. - Select assets based on label:
labels={contains={externalId="pump"}}
,labels={containsAny=[{externalId="pump_type_A"},{externalId="pump_type_B"}]}
,labels={containsAll=[{externalId="pump"},{externalId="rust_detected"}]}
assetSubtrees
/ExternalId
inputs.minCreatedTime
/maxCreatedTime
/maxLastUpdatedTime
has been replaced by thelastUpdatedTime={min=1592222651, max= 1593018651}
filters.- These options are no longer supported:
query
,sort
,dir
,offset
,boostname
,path
,depth
,sourceId
supported filters for
the
assets{}
expression.
Other
The Cognite Data Source for Grafana 2.0.0 is compatible with CDF API v1.
Cognite Data Source for Grafana 2.0.0 is not backward compatible with dashboards created using older versions of the connector. Follow the steps in the upgrade guide to upgrade your existing installation.
1.0.1 - May 27, 2019
- Rename Cognite Data Platform to Cognite Data Fusion.
- Allowing for templating variables to be used anywhere in custom queries.
- Allowing for the base url to be modified when adding a new data source.
Other
The Cognite Data Source for Grafana 1.0.1 is compatible with CDF API 0.5.
1.0.0 - March 26, 2019
- Fixing templating so that repeated panels/rows work properly.
- Changing checkboxes to Grafana checkboxes and adding Select All option.
- Fixing data source configuration to verify the project name.
- Breaking change:
function=
inside oftimeseries{ ... }
no longer works for custom queries. Instead, functions are now applied outside oftimeseries{}[]
such as:(timeseries{description=~".*TEMP.*"}[avg] - 32) * 5/9
sum(timeseries{name=~".*VALUE"}[count,1d])
max(timeseries{metadata.on="True"}[count,5m]) - min(timeseries{metadata.on="True"}[count,5m])
Other
The Cognite Data Source for Grafana 1.0.0 is compatible with CDF API 0.5
