Error handling
This guide explains how to handle errors in panel plugins and provides suggestions for common scenarios.
Provide usable defaults​
Allow the user to learn your panel plugin in small steps. Provide a useful default configuration so that:
- The user can get started right away.
- You can avoid unnecessary error messages.
For example, by selecting the first field of an expected type, the panel can display a visualization without any user configuration. If a user explicitly selects a field, then use that one. Otherwise, default to the first field of type string:
const numberField = frame.fields.find((field) =>
options.numberFieldName ? field.name === options.numberFieldName : field.type === FieldType.number
Display error messages​
To display an error message to the user, throw an Error with the message you want to display:
throw new Error('An error occurred');
Grafana displays the error message in the top-left corner of the panel:
We recommend that you avoid displaying overly technical error messages to the user. If you want to let technical users report an error, consider logging it to the console instead.
try {
failingFunction();
} catch (err) {
console.error(err);
throw new Error('Something went wrong');
Grafana displays the exception message in the UI as written, so use grammatically correct sentences. For more information, refer to the documentation style guide.
Common error scenarios​
Here are some examples of situations where you might want to display an error to the user.
Invalid query response​
Users have full freedom when they create data source queries for panels. If your panel plugin requires a specific format for the query response, then use the panel canvas to guide the user.
if (!numberField) {
throw new Error('Query result is missing a number field');
if (frame.length === 0) {
throw new Error('Query returned an empty result');
