Build a custom panel option editor
The Grafana plugin platform comes with a range of editors that allow your users to customize a panel. The standard editors cover the most common types of options, such as text input and boolean switches. If you don't find the editor you're looking for, you can build your own.
Panel option editor basics​
The simplest editor is a React component that accepts two props:
value: the current value of the optiononChange: updates the option's value
The editor in the example below lets the user toggle a boolean value by clicking a button:
import React from 'react';
import { Button } from '@grafana/ui';
import { StandardEditorProps } from '@grafana/data';
export const SimpleEditor = ({ value, onChange }: StandardEditorProps<boolean>) => {
return <Button onClick={() => onChange(!value)}>{value ? 'Disable' : 'Enable'}</Button>;
To use a custom panel option editor, use the addCustomEditor on the OptionsUIBuilder object in your module.ts file and set the editor property to the name of your custom editor component.
export const plugin = new PanelPlugin<SimpleOptions>(SimplePanel).setPanelOptions((builder) => {
return builder.addCustomEditor({
path: 'label',
editor: SimpleEditor,
Add settings to your panel option editor​
You can use your custom editor to customize multiple possible settings. To add settings to your editor, set the second template variable of StandardEditorProps to an interface that contains the settings you want to configure. Access the editor settings through the item prop.
Here's an example of an editor that populates a drop-down with a range of numbers. The Settings interface defines the range of the from and to properties.
interface Settings {
to: number;
type Props = StandardEditorProps<number, Settings>;
export const SimpleEditor = ({ item, value, onChange }: Props) => {
const options: Array<SelectableValue<number>> = [];
// Default values
const from = item.settings?.from ?? 1;
const to = item.settings?.to ?? 10;
for (let i = from; i <= to; i++) {
options.push({
label: i.toString(),
value: i,
return <Select options={options} value={value} onChange={(selectableValue) => onChange(selectableValue.value)} />;
You can now configure the editor for each option by configuring the settings property to call addCustomEditor:
path: 'index',
settings: {
to: 10,
Use query results in your panel option editor​
Option editors can access the results from the last query. This lets you update your editor dynamically based on the data returned by the data source.
The editor context is available through the context prop. The data frames returned by the data source are available under context.data.
export const SimpleEditor = ({ item, value, onChange, context }: StandardEditorProps<string>) => {
const options: SelectableValue<string>[] = [];
if (context.data) {
const frames = context.data;
for (let i = 0; i < frames.length; i++) {
options.push({
label: frames[i].name,
value: frames[i].name,
