Run Grafana behind a reverse proxy
Grafana Labs Team
By Grafana Labs Team
Last update on December 30, 2025
Advanced
Introduction
In this tutorial, you’ll configure Grafana to run behind a reverse proxy.
When running Grafana behind a proxy, you need to configure the domain name to let Grafana know how to render links and redirects correctly.
  • In the Grafana configuration file, change server.domain to the domain name you’ll be using:
Bash
[server]
domain = example.com
  • Restart Grafana for the changes to take effect.
Configure reverse proxy
Configure nginx
nginx is a high performance load balancer, web server, and reverse proxy.
  • In your nginx configuration file inside the http section, add the following:
nginx
# This is required to proxy Grafana Live WebSocket connections.
map $http_upgrade $connection_upgrade {
  default upgrade;
  '' close;
upstream grafana {
  server localhost:3000;
server {
  listen 80;
  root /usr/share/nginx/html;
  index index.html index.htm;
  location / {
    proxy_set_header Host $host;
    proxy_pass http://grafana;
  # Proxy Grafana Live WebSocket connections.
  location /api/live/ {
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection $connection_upgrade;
  • Reload the nginx configuration.
  • Navigate to port 80 on the machine nginx is running on. You’re greeted by the Grafana login page.
For Grafana Live which uses WebSocket connections you may have to raise the nginx value for worker_connections option which is 512 by default. The default value limits the number of possible concurrent connections with Grafana Live.
Also, be aware that the preceding configuration only works when the proxy_pass value for location / is a literal string. If you want to use a variable here, you must instead use a rewrite rule. For more information, refer to the GitHub issue #18299.
To configure nginx to serve Grafana under a sub path, update the location block:
nginx
  default upgrade;
  '' close;
upstream grafana {
server {
  listen 80;
  root /usr/share/nginx/www;
  location /grafana/ {
  location /grafana/api/live/ {
Add a rewrite rule to each location block:
 rewrite  ^/grafana/(.*)  /$1 break;
Note
If nginx is performing TLS termination, then you must set the root_url and protocol configuration accordingly. If you’re serving Grafana from https://example.com/grafana/ then the root_url is https://example.com/grafana/ or https://%(domain)s/grafana/ with the corresponding domain configuration value set to example.com in the server section of the Grafana configuration file. Set protocol to http.
Configure HAProxy
To configure HAProxy to serve Grafana under a sub path:
Bash
frontend http-in
  bind *:80
  use_backend grafana_backend if { path /grafana } or { path_beg /grafana/ }
  server grafana localhost:3000
  # Requires haproxy >= 1.6
  http-request set-path %[path,regsub(^/grafana/?,/)]
  # Works for haproxy < 1.6
  # reqrep ^([^\ ]*\ /)grafana[/]?(.*) \1\2
Configure IIS
Note
To use IIS, you must have the URL Rewrite module installed.
To configure IIS to serve Grafana under a sub path, create an Inbound Rule for the parent website in IIS Manager with the following settings:
  • pattern: grafana(/)?(.*)
  • check the Ignore case checkbox
  • rewrite URL set to http://localhost:3000/{R:2}
  • check the Append query string checkbox
  • check the Stop processing of subsequent rules checkbox
This is the rewrite rule that’s generated in the web.config:
xml
  <rewrite>
      <rules>
          <rule name="Grafana" enabled="true" stopProcessing="true">
              <match url="grafana(/)?(.*)" />
              <action type="Rewrite" url="http://localhost:3000/{R:2}" logRewrittenUrl="false" />
          </rule>
      </rules>
  </rewrite>
For more detailed instruction, refer to the tutorial on IIS URL Rewrites.
Configure Apache
To use Apache as a proxy, ensure its proper installation and configuration.
  1. Ensure that the Apache proxy module mod_proxy is installed and enabled. To enable, run the following commands:
Bash
a2enmod proxy
a2enmod proxy_http
  1. To configure the proxy, edit the site configuration file. To do so, inside the <VirtualHost> section, add the following code:
Bash
  ProxyPreserveHost on
  ProxyPass / http://your_grafana_server:3000
  ProxyPassReverse / http://your_grafana_server:3000
  1. Finally, restart Apache for the settings to take effect.
After you’ve restarted, navigate to your Apache server on port 80 and you will be redirected to Grafana.
To configure Grafana hosted in a sub path, replace the sub path with the following code (assuming your Grafana instance is on the sub path your_path):
Bash
  ProxyPass /your_path http://your_grafana_server:3000
  ProxyPassReverse /your_path http://your_grafana_server:3000
  ProxyPass / http://your_grafana_server:3000/your_path
  ProxyPassReverse / http://192.168.250.5:3000/your_path
Note that the lines containing your_path must come before the lines referencing root path (/) in order for this to work correctly.
Configure Traefik
Traefik Cloud Native application proxy.
Using the Docker provider and the following labels configures the router and service for a domain or subdomain routing.
YAML
labels:
  traefik.http.routers.grafana.rule: Host(`grafana.example.com`)
  traefik.http.services.grafana.loadbalancer.server.port: 3000
To deploy on a sub path:
YAML
labels:
  traefik.http.routers.grafana.rule: Host(`example.com`) && PathPrefix(`/grafana`)
Examples using the file provider.
YAML
http:
  routers:
    grafana:
      service: grafana
  services:
    grafana:
      loadBalancer:
        servers:
          - url: http://192.168.30.10:3000
YAML
http:
  routers:
    grafana:
      service: grafana
  services:
    grafana:
      loadBalancer:
        servers:
Alternative for serving Grafana under a sub path
Note
You only need this if you don’t handle the sub path serving via your reverse proxy configuration.
If you don’t want or can’t use the reverse proxy to handle serving Grafana from a sub path, you can set the configuration variable serve_from_sub_path to true.
  1. Include the sub path at the end of the root_url.
  2. Set serve_from_sub_path to true:
Bash
[server]
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
serve_from_sub_path = true
