Rising interest in OpenTelemetry
Awareness, interest, and adoption of OpenTelemetry grew fast over the past three years. This is reflected in a wide range of metrics. For example, the number of monthly web searches for OpenTelemetry doubled over the past 12 months. The OpenTelemetry Collector, the component that is used for receiving, processing, and exporting data, receives 45% of the top eight OpenTelemetry-related searches, with “instrumentation” (APIs for infrastructure and app instrumentation) receiving 17%.
Top search terms related to OpenTelemetry
100% increase in web searches year over year
Exploring the top 3 OpenTelemetry search terms
1. Collector
Setting up the Collector and instrumenting the application code and infrastructure are the two critical pre-conditions for achieving optimal observability. For instance, OpenTelemetry provides libraries for instrumenting SQL databases, such as PostgreSQL, MySQL, and Microsoft SQL Server, to collect telemetry data. To instrument a database, you need to connect to the database using the API provided by OpenTelemetry. To simplify this process for developers, OpenTelemetry offers instrumentation libraries for auto-instrumentation and for manual instrumentation. While auto-instrumentation does not require code changes, it does not offer the same level of granular control over the telemetry data output that developers can achieve through manual instrumentation. For example, the auto-instrumentation library for a database query captures the query type, duration, and basic error information, while manual instrumentation can deliver the actual SQL statement, variables, affected rows, and numerous custom metrics, such as cache hits or execution time for different parts of the query. The technology spotlight table below provides ten examples of how automatically extracted data can differ from telemetry data extracted by developers adding instrumentation code.
OpenTelemetry Collector web searches
Topic | Description |
1. OpenTelemetry receivers | Integration involves configuring receivers to collect telemetry data from various sources, ensuring compatibility with different cloud environments and data formats. |
2. OpenTelemetry exporters | Focuses on setting up exporters to send collected data to various backends or analysis tools, adapting to different output requirements. |
3. Container runtimes | Requires ensuring that OpenTelemetry can effectively gather data from containers, considering the nuances of the specific runtime environment. |
4. Kubernetes container orchestration | Involves integrating with Kubernetes to monitor and trace containerized applications and orchestration processes effectively. |
5. Different programming languages | Entails ensuring OpenTelemetry SDKs are compatible and efficient across various programming languages used in the cloud environment. |
6. Prometheus metrics for Kubernetes | Integration requires compatibility with Prometheus for collecting and exporting metrics, particularly in Kubernetes environments. |
7. Grafana dashboards | Involves configuring OpenTelemetry to export data in a format that can be visualized effectively in Grafana dashboards. |
8. Public cloud infrastructure | Requires adapting OpenTelemetry to work seamlessly with services and features that public cloud providers offer. |
9. Code repositories | Involves ensuring that telemetry data from code repositories is effectively captured and integrated into the monitoring system. |
10. Traditional observability | Requires integrating OpenTelemetry with existing observability platforms, ensuring seamless data collection and analysis. |
11. Service mesh | Involves configuring OpenTelemetry to monitor and trace service-to-service communication within a service mesh architecture. |
12. Kafka message bus | Requires setting up OpenTelemetry to effectively monitor and trace the flow of messages through Kafka message buses. |
2. Instrumentation
OpenTelemetry Instrumentation web searches
1. Development languages | Instrumentation must be compatible with all major development languages to ensure that telemetry data can be captured regardless of the programming language used. This includes languages like Java, Python, Go, JavaScript/Node.js, and .NET. |
2. Database technologies | Instrumentation must cover various database technologies, allowing for monitoring and collection of metrics and queries from SQL and NoSQL databases alike, such as PostgreSQL, MongoDB, Cassandra, and others. |
3. Kubernetes | Instrumentation should be able to integrate with the Kubernetes container scheduler to collect metrics and logs at the container and orchestration layers, providing visibility into deployments, pods, and services. |
4. GitHub | Instrumentation should be capable of tracking changes and events within the GitHub source code repository, enabling analysis of code commits, pull requests, and other repository-related activities. |
5. AWS SDK | Instrumentation requires support for the AWS SDK to facilitate the collection of telemetry data from applications utilizing AWS services, thus allowing for enhanced monitoring of cloud resources and interactions. |
6. Message Bus | Instrumentation must also encompass message bus technologies, such as Kafka, RabbitMQ, and ActiveMQ, to monitor and collect data on message throughput, latency, and processing, essential for understanding system communication and performance. |
Topic map based on OpenTelemetry Google trends
3. Exporter
OpenTelemetry Exporter web searches
1. Key export targets | Nodes such as Jaeger, Prometheus, Loki, Elastic, Datadog, Tempo, CloudWatch, and Zipkin are directly connected to the OpenTelemetry Exporter node, suggesting that users are frequently searching for how to export telemetry data to these specific backends. This reflects the need for interoperability between OpenTelemetry and various observability platforms. |
2. Programming languages | Nodes like Python and Node.js indicate that users are interested in how to implement OpenTelemetry exporters in these programming languages. This highlights the demand for language-specific guidance in integrating OpenTelemetry into diverse application stacks. |
3. Export types | Terms like logs, metrics, and trace are connected to the central node, which implies that users are looking for information on exporting these specific types of telemetry data. Understanding the nuances of each data type is crucial for effective monitoring and analysis. |
4. Cloud services | Nodes such as AWS CloudWatch and Azure Monitor show that there is interest in exporting telemetry data to cloud service providers. This points to the growing trend of cloud native applications and the need for seamless cloud integrations. |
5. Configuration and customization | The presence of nodes like configuration, custom, and application suggests that users are looking for ways to configure and customize their OpenTelemetry exporters. Tailoring the exporter settings is essential for optimizing data collection to suit specific operational requirements. |
6. OTLP | The OTLP (OpenTelemetry Protocol) nodes are connected to the central OpenTelemetry Exporter node, indicating searches related to the protocol used for exporting telemetry data. OTLP is a key protocol within the OpenTelemetry project, designed for high-performance and vendor-neutral data transmission, which is crucial for users looking to standardize telemetry data export across different systems and platforms. |
OpenTelemetry Exporter topic map based on Google Trends
OpenTelemetry spotlight: Auto-instrumentation vs. manual instrumentation
As a general rule, auto-instrumentation libraries are a great starting point for establishing basic observability because they deliver telemetry data without developer involvement. Developers can then add manual instrumentation as needed based on their requirements to better understand app performance, user experience, and health.
Topic telemetry element | Auto-instrumentation output | Manual instrumentation output |
1. HTTP request | Captures method, URL, status code, and duration | Captures method, URL, status code, and duration, plus custom headers, payload size, and user-specific attributes |
2. Database query | Captures query type, duration, and basic error information | Captures detailed query statement, bind variables, rows affected, and custom metrics, like cache hits |
3. Application start time | Captures the timestamp when the application starts | Captures application version, environment details, and custom initialization parameters |
4. Exception handling | Captures exception type and stack trace | Captures exception context, user impact, custom error codes, and remediation steps taken |
5. User authentication | Captures authentication success or failure and method (e.g., OAuth, SAML) | Captures user roles, session duration, and custom security checks |
6. External API call | Captures endpoint, status code, and duration | Captures endpoint, status code, payload, API version, and custom headers |
7. Cache access | Captures cache hit or miss and access time | Captures cache hit rate, eviction count, and custom cache performance metrics |
8. Message queue processing | Captures message size and processing time | Captures message metadata, processing logic path, and custom message handling metrics |
9. Batch job execution | Captures job start and end time, and success or failure | Captures job parameters, intermediate states, custom progress metrics, and resource usage |
10. Custom business logic execution | May not capture unless it interacts with instrumented libraries or frameworks | Captures specific function execution time, business transaction details, and custom business outcome metrics |
OpenTelemetry as part of the cloud native app stack
The network graph, based on a complete analysis of all 311 official sessions from the KubeCon 2023 conference in Chicago, illustrates the interconnected nature of various observability topics, with OpenTelemetry at the nexus of numerous key areas, such as service, metrics, and tracing. The proximity and connections between OpenTelemetry and other critical performance and deployment considerations like load balancing, performance, and analytics, reinforce its centrality to the Kubernetes space. This correlation suggests that OpenTelemetry is not just a standalone topic, but is deeply integrated with a range of practices and technologies that are essential for the effective functioning of Kubernetes applications.
The connection between eBPF (extended Berkeley Packet Filter) and OpenTelemetry, as seen in the charts, is particularly noteworthy. eBPF appears as the third-most important topic in the bar chart, indicating a high level of interest and relevance in the context of Kubernetes observability. Given eBPF’s capabilities for providing low-level system tracing and network traffic monitoring without modifying the kernel or installing additional modules, it is a powerful tool for observability. When integrated with OpenTelemetry, eBPF can enhance the telemetry data collected, allowing for more sophisticated and fine- grained observability solutions. This pairing enables developers and operators to not only observe their systems with minimal performance overhead, but also to gather insights at a granular level that eBPF provides, thereby significantly improving the observability and troubleshooting of Kubernetes applications.
The charts suggest that the synergy between eBPF and OpenTelemetry is recognized by the community as a valuable combination for achieving deeper system visibility and advanced performance analysis.
Top 10 observability topics at KubeCON 2023 in Chicago
Top 10 OpenTelemetry topics across Subreddits: The Good, the Bad, and the Ugly
Leveraging the GPT-4 large language model (LLM) to extract the 10 key themes across 1,000 posts from all 221 Subreddits that discuss OpenTelemetry, we find that “limitations and challenges” is the No. 1 topic.
Top 25 Subreddits discussing OpenTelemetry
This is not surprising since a) OpenTelemetry is still a new platform with a currently rapid adoption rate and b) professionals often post to Reddit to seek advice or even vent their displeasure. Keeping this in mind, there are still many interesting and productive lessons we can learn by analyzing the 10 key topics gleaned from the 1,000 posts we analyzed.
1. Adoption and Utilization in Production: Organizations are seeking to move their OpenTelemetry deployments from an experimental status into production. OpenTelemetry aims to become the standard for how telemetry data is gathered, processed, and exported across infrastructure and applications in the data center, the cloud, and at the edge. Adopting one standard for observability across teams enables organizations to save on costs and resources, streamline their monitoring processes, and reduce the complexity associated with managing multiple observability tools. This standardization also facilitates better collaboration and knowledge sharing among teams, leading to more efficient problem-solving and a more cohesive understanding of system performance across the entire organization. Moreover, with a unified approach, organizations can leverage deeper insights and more meaningful data correlations, thereby improving decision-making and operational agility in a rapidly evolving technological landscape.
2. Distributed tracing and instrumentation: Active discussion focus on distributed tracing in microservices, emphasizing proper instrumentation, integration with different backends, and trace data optimization. Solutions for trace propagation in contexts like Amazon SQS are also explored. These discussions are pivotal for enhancing performance monitoring and debugging in complex distributed systems.
3. Vendor adaptation and comparison: OpenTelemetry’s vendor-agnostic nature is a major strength. Discussions involve how different observability platforms integrate with OpenTelemetry, offering flexibility and varied choices for developers. This adaptability empowers organizations to customize their observability stacks according to their specific needs.
4. Community support and resource sharing: The community actively shares tutorials, blog posts, and documentation alongside community calls and meetups, fostering a collaborative learning environment. This culture of sharing not only accelerates the adoption of OpenTelemetry, but also enriches the collective knowledge base.
5. Testing strategies: Exploration of testing methods for OpenTelemetry and instrumented systems, including black-box and trace-based approaches, to ensure reliable releases and maintainability. These strategies are crucial for maintaining high-quality standards in software releases and continuous deployment pipelines.
6. Limitations and challenges: Communication of limitations and the need for improvements in areas like metric export configuration, logging integration, and trace data management. Addressing these challenges is key to enhancing the scalability and reliability of OpenTelemetry in large-scale environments.
7. OpenTelemetry’s capabilities and growth: Outlining OpenTelemetry’s capabilities in collecting traces, logs, and metrics, and noting its growth and industry recognition. Its evolving nature and industry adoption make it a cornerstone technology in the future of cloud native observability.
8. Integration and usability: Emphasis on OpenTelemetry as a comprehensive open source framework that standardizes telemetry across languages and supports various backend services, enhancing observability and monitoring. This integration capability is crucial for ensuring seamless observability across polyglot application environments.
9. Practical application and deployment: Demonstrating real-world uses in production environments, with effective integration with tools like Kubernetes and Istio, showcasing its practical value in technical operations. These real-world implementations highlight OpenTelemetry’s role in simplifying complex observability challenges in modern infrastructures.
10. Educational resources and community involvement: Highlighting the demand for educational content and community engagement to navigate the complexity of OpenTelemetry and contribute to its development and refinement. The active participation of the community is instrumental in driving the continuous evolution and usability of OpenTelemetry.
Top 10 OpenTelemetry topics on Reddit
The analysis of the top ten OpenTelemetry discussions on Reddit reveals that enterprises are actively navigating the complexities of integrating this new software platform. Despite the enthusiasm, the transition is challenging due to limited production experience and insufficient documentation. Moreover, the novelty of some parts of the codebase adds to the difficulty. The full potential of OpenTelemetry is realized only when it is deeply integrated with existing enterprise systems, which is a nuanced process that organizations are currently working to master.
Business perspective
The word cloud (below) derived from the Hacker News forum discussions (1,350 posts) about OpenTelemetry offers insights into the interests and priorities of Hacker News participants, including technologists, entrepreneurs, and investors. The prominence of terms like tracing and metrics reflects a keen interest in the technical aspects of monitoring and managing cloud native applications. This focus is particularly relevant for investors and tech leaders who are looking to understand the operational health and performance of software systems, since these are critical factors in risk assessment and decision-making for technology investments.
Top 10 OpenTelemetry-related topics on Hacker News
The inclusion of specific technologies, such as Kubernetes, Datadog, Java, Python, and AWS in the word cloud, indicates that the discussions are grounded in real-world applications and integrations. This suggests that the Hacker News community is not only interested in the theoretical aspects of OpenTelemetry, but also in its practical implementation across various platforms and languages. For higher-level tech individuals and investors, this translates into a rich source of information on how OpenTelemetry can be leveraged to enhance observability within the technology stacks they are using or considering for investment.
100% increase YoY in Hacker News posts related to OpenTelemetry
Lastly, the presence of terms like open source, community, support, and integration highlights the collaborative nature of the OpenTelemetry project and its ecosystem. This underscores the value of community-driven innovation and the potential for long-term sustainability and support for the technology. The term collector points to specific discussions about the OpenTelemetry Collector, which is of interest to those looking to understand the technical underpinnings and capabilities of the project. Overall, the word cloud suggests that the Hacker News forum is a hub for high-level discourse on OpenTelemetry, offering insights that are valuable to both the technical and investment-oriented members of the community.
