Plugins 〉Compact Hostmap Panel
Developer
zestairlove
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
  • Overview
  • Installation
  • Change log
  • Related content
Compact Hostmap Panel for Grafana
Grafana Panel Plugin to easily understand the host's system metric at a glance
Screenshot_2022-05-20_16-59-14
Supported Datasources
  • promethues
  • elasticsearch
tested.
Supports Grafana plugin interface data frames, groupBy each frame based on name || field's config.displayName || config.displayNameFromDS field's key.
Screenshot_2022-05-20_18-24-46 Screenshot_2022-05-20_18-25-13
ETC
HostItem is rendered in response to panel size, and Color Threshold is mapped to the largest value.
Screenshot_2022-05-20_18-23-49
Installing Compact Hostmap Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Compact Hostmap Panel from the commandline:
grafana-cli plugins install
Changelog
0.9.0 (Unreleased)
Initial release.
