Plugins 〉mapbox-panel
The mapbox-panel plugin has been deprecated and is no longer maintained.
mapbox-panel
Mapbox Panel plugin
Introduction
Let's consider a time-series with geospatial data, for example:
| datetime | latitude | longitude |
| 2020-11-23 13:27:02 | 52.375 | 4.89865 |
| 2020-11-23 13:27:02 | 52.3725 | 4.90977 |
| 2020-11-23 13:27:02 | 52.3193 | 5.13439 |
| 2020-11-23 13:27:02 | 52.4427 | 5.54845 |
| 2020-11-23 13:27:02 | 50.7302 | 2.4198 |
| 2020-11-23 15:12:49 | 47.0571 | 15.4308 |
| 2020-11-23 15:12:49 | 47.1479 | 15.7725 |
| 2020-11-23 15:12:49 | 46.7176 | 15.6473 |
| 2020-11-23 15:12:49 | 47.2397 | 18.8275 |
Querying this data from Grafana together with this plugin will allow you to dynamically display parts of this data on a Mapbox map:
Future ideas
- Custom styling.
- Mapbox Studio API key + style integration.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing mapbox-panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install mapbox-panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
