Plugins 〉Flowhook Webhooks Datasource
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
- Overview
- Installation
- Change log
- Related content
Flowhook Datasource for Grafana
Flowhook consumes webhook payloads and maps and routes them into your Grafana Logs panel. The Flowhook service runs on Heroku, is free and does not require any signup.
NOTE: Note this plugin is currently experimental.
What is Grafana Data Source Plugin?
The plugin connects to the Flowhook service via websockets and forwards all incoming webhook events to the standard Grafana Logs panel. In order to pick the right data you map payloads with JsonPath selectors (Jayway implementation).
Create a Flowhook
Head over to https://flowhook.herokuapp.com/ and follow the instructions to create a new Flowhook. Copy the ID and configure your plugin datasource to use it.
Test the Flowhook
Now trigger a couple of webhooks and watch the contents emerge in the Logs panel or Explorer.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Flowhook Webhooks Datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Flowhook Webhooks Datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
