Plugins 〉Organisations
Organisations
Organisations Panel Plugin for Grafana
This is a panel plugin for Grafana. It shows all organizations that user belongs to as navigable link buttons.
To understand what is a plugin, read the Grafana's documentation about plugins.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Organisations on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Organisations from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.4.0 2022-08-24
Changed from Angular.js panel to React panel
1.3.0 2020-12-10
Last Angular.js version
