Plugins 〉Matomo Tracker
Developer
Thiago Arrais
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Matomo Tracker
  • Overview
  • Installation
  • Change log
  • Related content
Matomo Tracking Panel
Like a tracking pixel, but it is a Grafana Panel.
This panel allows Grafana dashboard usage to be tracked using Matomo. It does only tracking and has minimal visible presence.
This is independently developed. It is not an official Matomo product, and is not affiliated with, or sponsored by, Matomo.
Requirements
Compatible with Grafana 7.x
Installation
Install by using grafana-cli
grafana-cli plugins install thiagoarrais-matomotracking-panel
Usage
Include only one panel per dashboard that should be tracked. Use the configuration editor to set the URL for your Matomo instance and your site ID.
The panel does not have any visible UI. We suggest that it should be resized to a minimal.
Credits
Sponsored by Serpro
Installing Matomo Tracker on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Matomo Tracker from the commandline:
Change Log
All notable changes to this project will be documented in this file.
v1.0.0
Initial Release
