Plugins 〉Indoor Map
Developer
Tailos
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Indoor Map
  • Overview
  • Installation
  • Change log
  • Related content
Grafana Plugin: Map Panel
Visualize image files for indoor maps.
Overview / Introduction
Panel that visualizes an indoor map (collection of layers of spatial data using the same frame of reference).
Installing Indoor Map on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Indoor Map from the commandline:
grafana-cli plugins install
Changelog
1.0.0 (Unreleased)
Initial release.
