Plugins 〉hackerone-datasource
Developer
Sven Grossmann
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
  • Overview
  • Installation
  • Change log
  • Related content
HackerOne Datasource for Grafana
This is a backend datasource to get data about payouts, earnings and reports from HackerOne.
Installing hackerone-datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install hackerone-datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.4
  • setup release version
1.0.1 (Unreleased)
  • add reports without bounties
1.0.0 (Unreleased)
Initial release.
