Plugins 〉PerfCurve
PerfCurve
Grafana Plugin PerfCurve
Overview
PerfCurve is a grafana panel plugin to plot operation point of rotating machine, such as pump, compressor and etc., on a canvas with its performance curves. You can draw multiple performance curves on the canvas only by giving sample points on the performance curve. The panel plugin connects sample points smoothly.
Important notes !!
Select the plugin version in accordance with the following rule.
- For Grafana >= 8.X.X, use version >= 1.5.X
- For Grafana >= 7.4.X, use version >= 1.4.X
- For Grafana <= 7.3.X, use version <= 1.3.X
Getting started
Axes
Specify Min., Max., Label, Unit and Decimals of X-axis amd Y-axis.
Static curve
Add performance curves to the canvas by specifying sample points in comma separated value format.
The number of values in X input box and Y input Box shall be same.
Natural curves are drawn based on the sample points.
Dynamic curve (Advanced)
In case performance curve data is availble in database, they can be used to draw peformance curve which dynamically move based on the data. (Example of query is written for InfluxDB datasource.)
Operation points
Set field names for X box and Y box to plot operating points.
Set Label, Color and Point Radius, too.
Table format is recommended as query option.
Sample with TestData DB
Refer to the attached sample input with TestData DB. TestData DB is available as default, if you add TestaData DB to data source.
Sample of Panel JSON:
"id": 23763571993,
"gridPos": {
"h": 9,
"w": 12,
"x": 0,
"y": 0
"type": "sskgo-perfcurve-panel",
"title": "Panel Title",
"pluginVersion": "7.5.6",
"targets": [
"alias": "Field X",
"csvWave": {
"timeStep": 60,
"valuesCSV": "0,0,2,2,1,1"
"lines": 10,
"points": [],
"pulseWave": {
"offCount": 3,
"offValue": 1,
"onCount": 3,
"onValue": 2,
"timeStep": 60
"refId": "A",
"scenarioId": "csv_metric_values",
"stream": {
"bands": 1,
"noise": 2.2,
"speed": 250,
"spread": 3.5,
"type": "signal"
"stringInput": "30"
"alias": "Field Y",
"csvWave": {
"timeStep": 60,
"hide": false,
"lines": 10,
"points": [],
"pulseWave": {
"offCount": 3,
"offValue": 1,
"onCount": 3,
"onValue": 2,
"timeStep": 60
"refId": "B",
"stream": {
"bands": 1,
"noise": 2.2,
"speed": 250,
"spread": 3.5,
"type": "signal"
"stringInput": "50"
"refId": "C",
"alias": "Curve X1",
"csvWave": {
"timeStep": 60,
"hide": false,
"lines": 10,
"points": [],
"pulseWave": {
"offCount": 3,
"offValue": 1,
"onCount": 3,
"onValue": 2,
"timeStep": 60
"stream": {
"bands": 1,
"noise": 2.2,
"speed": 250,
"spread": 3.5,
"type": "signal"
"stringInput": "10, 10"
"refId": "D",
"alias": "Curve Y1",
"csvWave": {
"timeStep": 60,
"hide": false,
"lines": 10,
"points": [],
"pulseWave": {
"offCount": 3,
"offValue": 1,
"onCount": 3,
"onValue": 2,
"timeStep": 60
"stream": {
"bands": 1,
"noise": 2.2,
"speed": 250,
"spread": 3.5,
"type": "signal"
"stringInput": "70, 65"
"refId": "E",
"alias": "Curve X2",
"csvWave": {
"timeStep": 60,
"hide": false,
"lines": 10,
"points": [],
"pulseWave": {
"offCount": 3,
"offValue": 1,
"onCount": 3,
"onValue": 2,
"timeStep": 60
"stream": {
"bands": 1,
"noise": 2.2,
"speed": 250,
"spread": 3.5,
"type": "signal"
"stringInput": "20, 20"
"refId": "F",
"alias": "Curve Y2",
"csvWave": {
"timeStep": 60,
"hide": false,
"lines": 10,
"points": [],
"pulseWave": {
"offCount": 3,
"offValue": 1,
"onCount": 3,
"onValue": 2,
"timeStep": 60
"stream": {
"bands": 1,
"noise": 2.2,
"speed": 250,
"spread": 3.5,
"type": "signal"
"stringInput": "68,63"
"options": {
"xAxis": {
"minValue": 0,
"maxValue": 60,
"label": "Flowrate"
"yAxis": {
"minValue": 0,
"maxValue": 100,
"label": "Pressure"
"performanceCurveData": [
"color": "rgba(136, 136, 136, 0.6)",
"performCurveX": "10,20,30,40,50",
"performCurveY": "80,78,72,62,48"
"dynamicPerfCurve": [
"fieldGroup": [
"xField": "Curve X1",
"yField": "Curve Y1"
"xField": "Curve X2",
"yField": "Curve Y2"
"color": "#FADE2A"
"plotSetting": [
"color": "#F2495C",
"label": "Label Name",
"xField": "Field X",
"yField": "Field Y"
"pointRadius": 4
"timeFrom": null,
"timeShift": null,
"datasource": null
