Plugins 〉Shoreline
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Shoreline
- Overview
- Installation
- Change log
- Related content
Shoreline data source for Grafana
The Shoreline data source plugin allows you to create in-depth Grafana dashboards powered by Shoreline's fleetwide resource and metric query capabilities.
For detailed instructions on how to use the plugin on Grafana Cloud or locally, please checkout the documentation.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Shoreline on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Shoreline from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.2.0
- Refactor code with latest Grafana features
- Update minimum required Grafana version to
9.x
1.1.0
- Add support for
metric_metadata_query
as variable query - Add support for custom HTTP settings when configuring data source
- Add documentation and examples in plugin README
- Fix bug where checkbox setting for custom query doesn't always get saved
1.0.0
Initial release.
