Plugins 〉ServiceNow Cloud Observability
Developer
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
commercial
  • Overview
  • Installation
  • Change log
  • Related content
Dashboard powered by ServiceNow Cloud Observability data
Instantly visualize ServiceNow Cloud Observability data in Grafana
The ServiceNow Cloud Observability (formerly known as Lightstep) data source plugin is the easiest way to pull ServiceNow Cloud Observability data directly into Grafana dashboards.
  • Visualize it either in isolation (one data source) or blend it with other data sources.
  • Discover correlations and covariances across all your data in minutes.
  • Jump directly into ServiceNow Cloud Observability for further investigations.
Installation instructions
Installing ServiceNow Cloud Observability on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install ServiceNow Cloud Observability from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
Releases are documented on the Github Releases page.
