Plugins 〉Scanner
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Scanner
- Overview
- Installation
- Change log
- Related content
Scanner
Query the Scanner API to search through logs in object storage at high speed.
Introduction
Scanner is a SIEM that is designed from the ground up for cloud scale. It analyzes your logs in S3 cloud storage in-place, and using a novel indexing system, it provides your team with lightning fast search for threat hunting and detections. Ingest terabytes of logs per day at low cost.
Since Scanner is designed for cloud storage and serverless compute, log ingestion is 80-90% less expensive than other tools. You are no longer forced to choose which log sources to drop and which to keep. You can cover them all.
For more information on Scanner, see Scanner.dev.
Getting Started
To configure the plugin to send queries to Scanner, provide the API URL of your Scanner instance and an API key in the config editor.
To locate your API URL, navigate to Settings > API Keys
in Scanner.
You can use an existing API key or create a new API key.
Documentation
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Scanner on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Scanner from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0
Initial release.
