Plugins 〉TrackMap
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
TrackMap
- Overview
- Installation
- Change log
- Related content
TrackMap Panel for Grafana
A panel for Grafana that visualizes GPS points as a line on an interactive map.
Features
- Places a dot on the map at the current time as you mouse over other panels.
- Zoom to a range of points by drawing a box by shift-clicking and dragging.
- Multiple map backgrounds: OpenStreetMap, OpenTopoMap, and Satellite imagery.
- Track and dot colors can be customized in the options tab.
Configuration
The plugin requires latitude and longitude measurements provided as numbers in two separate fields. These can be formatted as "Time series" or "Table" data by Grafana. The order of the data returned by the query is required (latitude, then longitude) since the labels and tag names are not used.
For example, the following query has been tested using InfluxDB as a data source in the case where
the latitude
and longitude
series are stored in the location
measurement:
SELECT median("latitude"), median("longitude") FROM "location" WHERE $timeFilter GROUP BY time($__interval)
Because the plugin only cares about getting 2 series of data, it's also possible to use MySQL/MariaDB as a data source by using 2 queries like so:
A: SELECT "latitude" as value, $__time(timestamp) FROM "location" WHERE $__timeFilter(timestamp) ORDER BY timestamp ASC
B: SELECT "longitude" as value, $__time(timestamp) FROM "location" WHERE $__timeFilter(timestamp) ORDER BY timestamp ASC
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing TrackMap on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install TrackMap from the commandline:
grafana-cli plugins install
Changelog
3.0.2
- Fix project metadata (no functional changes)
3.0.1
- Fix issues rendering multiple maps (@nsass24)
3.0.0
- Rewrite in React
- Add option to provide a custom tile URL template
- Breaking changes:
- Replaced Eniro Seamap with OpenSeaMap
- All options will be reset to default
2.1.4
- Fix broken license link and update required Grafana version
2.1.3
- Add handling of new
DataHoverEvent
- Add Eniro Seamap
- Fix certain hover events not existing in Grafana 7.x.x
2.1.2
- Automate releases with GitHub Actions
2.1.1
- Handle display of lines that cross the antimeridian
- Add support for new hover events
- Ignore coordinates of
(0, 0)
2.1.0
- Add option to zoom with mouse wheel
- Add default layer option
- Fix issue with toggling autozoom with an empty map
- Fix issue with zooming to a region with no points in it
- Add option to disable the layer changer
- Fix rendering the panel to a screenshot
2.0.4
- Fix issues related to resizing the panel
- Add support for snapshots
- Add basic debug logging
2.0.3
- Change project icon
2.0.2
- Fix screenshot display in Grafana
2.0.1
- Include README in build files
2.0.0
- Fix map not expanding when resizing the panel
- Restructure to follow Grafana conventions/requirements
- Update build process
1.1.0
- Add option to disable auto-zoom
1.0.1
- Relax Grafana version restriction
1.0.0
- Initial release
