Plugins 〉Firestore
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Firestore
- Overview
- Installation
- Change log
- Related content
Firestore
Google Firestore Data Source Plugin for Grafana.
Grafana Firestore Data Source Plugin enables integrating data on Firestore on to Grafana dashboards.
It uses FireQL to capture user query that translated to issue queries on Firestore and construct results.
FireQL is a Go library to query Google Firestore database using SQL syntax.
Features
- Use Google Firestore as a data source for Grafana dashboards
- Configure Firestore data source with GCP
Project Id
andService Account
for authentication - Store
Service Account
data source configuration in Grafana encrypted storage Secure JSON Data - Query Firestore collections and path to collections
- Auto detect data types:
string
,number
,boolean
,json
,time.Time
- Query selected fields from the collection
- Order query results
- Limit query results
- Query Collection Groups
Firestore data source configuration
Using datasource
Migration instructions from version <=0.1.0
to 0.2.0
Starting from version 0.2.0
firestore datasource plugin started using FireQL
, a SQL query language to query collections on Google Firestore. Util 0.1
version it was just collection ID that can configured in the query section, where as starting from 0.2.0
, it is query editor.
For example, if you have collection test_collection
configured in v0.1
, you have to change it to select * from test_collection
in v0.2.0
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Firestore on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Firestore from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
