Plugins 〉Akvorado
Developer
ovhcloud
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
Akvorado
  • Overview
  • Installation
  • Change log
  • Related content
Akvorado
Akvorado netflow data source using akvorado api
Introduction
This plugin aim to allow user to display akvorado data directly in Grafana. example1 example2
Requirements
List any requirements or dependencies they may need to run the plugin.
Getting Started
In Grafana:
  • Add new data source
  • Akvorado
  • Add new Akvorado data source
Building queries
Queries can be built using pre-configured parameters.
Query parameters
  • Type of query:
    • sankey
      • When using sankey at least two dimension must be used
    • timeseries
  • Unit
    • l3bps
    • pps
  • Dimension
    • Multiselect list: values are fetch from the back end
  • Limit: number of returned result
    • The number of return result is in fact limit +1 where +1 is the value "other" showing the aggregation of all other values
  • Filters: expression to filter result
    • The field is autocomplete and lint based on syntax checker
Query examples
Visualize the top 10 traffic per Source BGP AS for Ingress traffic, in bytes per second (pps) example1.png
Visualize the Top 10 Source BGP AS and Exporter Site for Ingress traffic, in packets per second (pps) example2.png
Contributing
If you want to contribute feel free to open a PR in this repo
Installing Akvorado on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Akvorado from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
