Plugins 〉Percentage Trend
Percentage Trend
Grafana Percent Trend Stat Panel
A panel plugin for Grafana >= 8.1.0 which computes and displays percent with trend compared to a previous value in a stat style big value manner.
Configuration allows to display the percentage value compared to the base value plain or interpret the percentage change as difference ("trend") with a colored (green/red) triangle symbol to see the trend evolution easily.
The idea for this plugin panel was inspired by an article about Embedded Analytics.
This plugin is reviewed by Grafana engineers and released on GrafanaLabs, see Plugins -> Panel (Community): Percentage Trend
Install
Download the latest release (named
nikosc-percenttrend-panel-<version>.zip) and unzip it in your grafana plugin folder.
Usage
Query two metrics, remember field names, which have to be specified in the next step
Select the field names of the query results and use them to display your percentage trend
More resources
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Percentage Trend on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Percentage Trend from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.8 (2024-01-23)
- Show percentage value if base value (ie. from previous time range) is not available.
1.0.7 (2022-11-06)
- Fixed prefix in case of negative percentage trend
1.0.6 (2022-10-25)
- Support locale unit for percentage value (thanks @itsnull12)
- Allow to specify number of decimals displayed for percentage value
- Improved display in case no previous ("base") value available instead of infinity
- Improved display of stagnation (= 0% difference to base value)
1.0.5 (2022-10-19)
- Allow to invert colorization of trend (thanks @jammiemil)
1.0.4 (2022-10-07)
- Turned screenshot images from README from relative to absolute URLs
- Submission to Grafana Community
1.0.3 (2022-10-05)
- Checked backward compatibility, set from 7.0.0 to 8.1.0
- Improved check for existence of referred data frames (kudos to Esteban)
1.0.2 (2022-10-04)
- Avoid usage of deprecated UI theme and style setup
- Fixed bug when using pixel to specify percentage value size
1.0.1 (2022-09-30)
- Added logo
1.0.0 (2022-09-29)
- Initial release
