Plugins 〉JSON Fetcher
Developer
Nagasudhir
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
JSON Fetcher
  • Overview
  • Installation
  • Change log
  • Related content
Grafana API Backend Datasource Plugin
  • This is a Grafana Data Source Plugin for getting data from HTTP API
  • User inputs in the query editor can be customized by setting JSON schema in the datasource configuration page
  • Now end user can create queries in query editor without understanding JSON
  • Alerts are also supported since it is a backend datasource plugin
Plugin installation
Create JSON schema for query payload
  • You can generate JSON schema from example query payload JSON here
Example JSON schema
  • Paste the following in the Query schema text box of the json-backend datasource settings screen
    "description": "Query Schema",
    "properties": {
        "fetchCached": {
            "default": true,
            "description": "Whether cached data fetching is ok",
            "title": "Fetch Cached?",
            "type": "boolean"
        "measId": {
            "default": "",
            "description": "Measurement ID",
            "maxLength": 20,
            "minLength": 15,
            "title": "Measurement ID",
            "type": "string"
        "samplingSecs": {
            "default": 60,
            "description": "Sampling Freq. in secs",
            "multipleOf": 2,
            "title": "Sampling Freq (in secs)",
            "type": "integer"
        "samplingType": {
            "default": "snap",
            "enum": [
                "snap",
                "average",
                "max",
                "min",
                "sum"
            "title": "Sampling Type",
            "type": "string"
    "title": "Query Editor GUI",
    "type": "object"
  • The grafana query editor for this datasource will look like the following
  • It can be seen in the query inspector that the JSON payload is generated from user inputs and request is sent
End points to be implemented by the API
  • The plugin requires these endpoints to be implemented by the API server
  • API server should listen for GET requests at / and return 200 OK status code as a health check endpoint implementation
  • API server should listen for POST requests at / to respond to queries with data. The POST request body will contain the query information like series name, start and end timestamps, query payload etc. The response should have timestamps and values for a single series.
  • A sample API request that will sent to API server by grafana can be like
    "RefID": "A",
    "QueryType": "",
    "MaxDataPoints": 974,
    "Interval": 60000000000,
    "TimeRange": {
        "From": "2022-10-08T00:00:00+05:30",
        "To": "2022-10-08T14:44:09.586+05:30"
    "JSON": {
        "refId": "A",
        "alias": "abcd",
        "payload": "{\"fetchCached\":true,\"measId\":\"abcd\",\"samplingType\":\"snap\",\"samplingSecs\":60}",
        "bucketAggs": [
                "field": "@timestamp",
                "id": "2",
                "settings": {
                    "interval": "auto"
                "type": "date_histogram"
        "datasource": "JSON Fetcher",
        "datasourceId": 10,
        "intervalMs": 60000,
        "maxDataPoints": 974,
        "metrics": [
                "id": "1",
                "type": "count"
        "query": "",
        "timeField": "@timestamp"
  • A sample API response can be like
    "frames":[
            "columns":[
                {"name": "@timestamp", "values": [1665216413748, 1665219977028], "labels": null},
                {"name": "abcd", "values": [5, 10], "labels": null}
The times in response should be UNIX epoch timestamps in seconds
Data flow
Developer Documentation
Developer documentation can be found here
Installing JSON Fetcher on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install JSON Fetcher from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
