Plugins 〉JSON API
Developer
Grafana Labs
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
grafana
JSON API
Documentation →
JSON API data source for Grafana
(NOTE: this plugin is now in maintenance mode, no new features will be added. We recommend using the Infinity data source plugin instead)
The Grafana JSON Datasource plugin empowers you to seamlessly integrate JSON data into Grafana. JSON is a versatile and widely used data format, and with this plugin, you can easily transform your JSON data into meaningful visualizations within Grafana dashboards.
Documentation
For comprehensive instructions on setting up and configuring the Grafana JSON API Datasource, please consult our official documentation.
Maintenance: Now the plugin is being maintained by Grafana Labs. Big thanks to Marcus Olsson for the awesome work!
Installing JSON API on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install JSON API from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v1.3.22 - 2025-02-05
  • ⚙️ Chore: Update workflows
  • ⚙️ Chore: Migrate to playwright for e2e tests
v1.3.21 - 2025-01-09
  • ⚙️ Fix: Enhance URL safety checks by sanitizing urls first.
v1.3.20 - 2024-11-28
  • 🛡️ Security: Update jsonpath-plus to version 10.2.0
  • 🛡️ Security: Update cross-spawn to version 7.0.5
v1.3.19 - 2024-10-29
  • 🛡️ Security: Update jsonpath-plus to version 10.1.0
  • 🛡️ Security: Update uplot to version 1.6.31
v1.3.18 - 2024-10-18
  • 🛡️ Security: Update jsonpath-plus to version 10.0.6
  • 🛡️ Security: Bump dompurify from 3.1.0 to 3.1.6
  • 🛡️ Security: Bump path-to-regexp from 1.8.0 to 1.9.0
v1.3.17 - 2024-09-03
  • 🛡️ Security: Bump micromatch from 4.0.5 to 4.0.8
  • 🛡️ Security: Bump webpack from 5.86.0 to 5.94.0
  • 🛡️ Security: Bump fast-loops from 1.1.3 to 1.1.4
  • 🛡️ Security: Bump ws from 8.14.2 to 8.17.1
  • 🛡️ Security: Bump braces from 3.0.2 to 3.0.3
v1.3.16 - 2024-06-13
  • ⚙️ Fix: Consider \ (backslash) characters in allowed url checks.
v1.3.15 - 2024-05-14
  • ⚙️ Chore: Updated documentation
v1.3.14 - 2024-04-15
  • ⚙️ Chore: Update dependencies
v1.3.13 - 2024-04-04
v1.3.12 - 2024-02-14
  • ⚙️ Chore: Maintenance
v1.3.11 - 2024-02-14
  • 🛡️ Security: Add more robust URL handling, do not allow '/../' in the URL, only allow GET and POST methods ( CVE-2023-5123 )
v1.3.10 - 2023-12-20
v1.3.9 - 2023-11-21
  • ⚙️ Chore: Update configuration page to follow best practices
  • ⚙️ Chore: Remove legacy form styles
  • ⚙️ Chore: Update readme and documentation
  • ⚙️ Chore: Added lint github workflow
v1.3.8 - 2023-10-19
v1.3.7 - 2023-10-18
  • ⚙️ Chore: Migrate to create-plugin
  • ⚙️ Chore: Add feature tracking
v1.3.6 - 2023-05-30
  • ⚙️ Chore: Docs update
v1.3.5 - 2023-04-05
  • 🛡️ Security: Recently, A third party researcher (Alessio Della Libera of Snyk Research Team) discovered and privately disclosed to us a stored XSS vulnerability in the Grafana-maintained marcusolsson-json-datasource plugin also known as “JSON API plugin” .
Users with the editor role could perform a stored XSS attack against other viewers, editors, and administrators by including a specially crafted javascript statement in the field extractor in queries to the marcusolsson-json-datasource plugin. This resulted in XSS against anyone viewing a panel configured to query the datasource with a malicious query.
This vulnerability worked because the marcusolsson-json-datasource plugin uses the jsonpath-plus library to evaluate editor-supplied jsonpath expressions. In its default configuration (which we used), this library is an XSS vector, as the JSONPath spec allows for embedded subexpressions, which jsonpath-plus implements as arbitrary javascript expressions.
In order to mitigate this vulnerability, we now supply a configuration parameter to jsonpath-plus which forbids the evaluation of subexpressions; it is important to note that this change may break existing JSONPath queries that rely on filter or eval expressions.
If your dashboards currently rely on JSONPath queries containing subexpressions, there are a few potential migration paths:
  1. For simple queries that use subexpressions for indexing/slicing, it may be possible to rewrite the query without a subexpressions for instance [(@.length-1)] can also be represented as [:-1].
  2. For more complex queries, we suggest switching to the jsonata language, which the plugin also supports. This language has similar features to JSONPath, including support for filter expressions (called “predicates” in the documentation).
  3. If changing your existing queries isn’t feasible, the community plugin “Infinity” supports JSONPath expressions, including filters and subexpressions if used with the backend parser option. Please note that Infinity is community supported plugin.
v1.3.4 - 2023-04-04
  • ⚙️ Chore: docs update
v1.3.3 - 2023-03-20
  • ⚙️ Chore: dependencies update
  • ⚙️ Chore: spellcheck added
v1.3.2 - 2022-10-14
Full changelog
  • Fixed the broken docs and links
v1.3.1 - 2022-01-24
Full changelog
Enhancements
  • Append suffix to param key to uniquify duplicate param keys #232 (thanks @rejohnst!)
  • Added grafana global variables when doing a query using jsonata #223 (thanks @amng!)
Bug fixes
  • Certain strings incorrectly identified as dates #202
v1.3.0 - 2021-09-03
Full changelog
Enhancements
  • Add support for JSONata (#114), a query language similar to JSONPath with support for transformations.
Bug fixes
  • Cannot read property 'filter' of undefined (#156)
v1.2.1 - 2021-06-18
Full changelog
Enhancements
  • Update dependencies, docs, and metadata
v1.2.0 - 2021-05-18
Full changelog
Enhancements
  • Adding $isoFrom() and $isoTo() macros (#115) (thanks @jirkafajfr!)
  • Using JSON.stringify instead of toString for object types in parseValue (#111) (thanks @Totalus!)
Bug fixes
v1.1.1 - 2021-04-17
Full changelog
Enhancements
  • Improve editor styling
Bug fixes
  • 🐛 Fix: Fix issue where wrong fields were used when grouping
  • Add variable support for aliases
v1.1.0 - 2021-04-15
Full changelog
This release introduces an Experimental tab to the query editor. This will be used to let users try out features while they're being developed. Each feature has a link the the GitHub issue where you can share you feedback, before the feature is considered stable.
Enhancements
  • Extend variables support to options
  • Don't detect time fields from Unix epoch (#82)
  • Add params to cache key (#85)
  • Add support for field aliases
  • Add Experimental section to query editor to test features under development
  • Experimental: Group query results by field (#36)
  • Experimental: Set display name for metric fields (#36)
  • Experimental: Set optional label for variables (#79)
Bug fixes
  • Ignore hidden queries (#83)
  • New queries don't use default values
v1.0.1 - 2021-03-05
Full changelog
Enhancements
  • Add annotation support
Bug fixes
  • Can't connect to API when URL contains encoded slash (#59)
v1.0.0 - 2021-03-04
Full changelog
No noteworthy features or bug fixes in this release. Mostly metadata updates.
v0.10.1 - 2021-02-27
Full changelog
Bug fixes
  • Undefined cache duration isn't handled
  • Query editor tries to update read only property
v0.10.0 - 2021-02-19
Full changelog
Enhancements
  • Add auto-completion to JSON Path queries
v0.9.2 - 2021-02-03
Full changelog
Bug fixes
  • Variable queries fail with error (#48)
v0.9.1 - 2021-02-01
Full changelog
Bug fixes
  • Cannot read property 'toString' of null (#46)
v0.9.0 - 2021-02-01
Full changelog
BREAKING CHANGE: Query parameters set by the query editor no longer overrides the data source config, to match how headers are handled in the Grafana proxy. This establishes the convention that any configuration made by an administrator should have higher priority.
IMPORTANT: This release contains many new changes that touches several aspects of the plugin. Make sure that you back up your dashboards before updating your plugin.
This release introduces a new query editor that gives more control of the request.
  • Support for both GET and POST methods
  • Support for request bodies (when using POST)
  • Support for headers
It introduces a new key value editor for query parameters and headers, as well as a Monaco-based editor for editing the request body with syntax highlighting.
This release deprecates the queryString property in the query model, in favor of the new params. The query string config should be backwards-compatible (and forward-compatible) with previous versions, but make sure to back up your dashboard before upgrading.
v0.8.0 - 2021-01-08
Full changelog
Enhancements
  • Use the refId as the series name
  • Add type configuration for queries (#37)
Bug fixes
  • Grafana Explore gets stuck when adding a second query (#31)
  • Multiple data source queries overwrite each other
v0.7.1 - 2020-12-07
Full changelog
Bug fixes
  • Falsy values are returned as NaN (#25)
v0.7.0 - 2020-12-04
Full changelog
Enhancements
  • Add support for custom paths (#24)
  • Add epoch time macros (#22)
  • Migrate to new form components. This bumps the minimum required Grafana version to 7.3.0
Bug fixes
  • Template variable chaining is not working (#23)
  • Cannot read property 'length' of null (#21)
v0.6.4 - 2020-11-30
Full changelog
Bug fixes
  • Fixes an issue where custom query parameters defined in the data source are flipped.
v0.6.3 - 2020-11-27
Full changelog
Enhancements
  • Updated @grafana dependencies from ^7.0.0 to ^7.3.0
  • Improved release process using the new GitHub workflows for Grafana plugins
