Plugins 〉Hexmap
Hexmap
Hexmap for Grafana
Important: As of July 2022, I'm no longer actively maintaining this plugin. If this plugin has been useful to you, consider switching to the Polystat panel.
A Grafana panel plugin for hexagonal tiling of data.
Configuration
This section lists the available configuration options.
Panel options
Dimensions
| Option | Description |
| Color by | Field to use for color. Defaults to the first number field. You can set the color scheme under the Fields tab. |
| Size by | Field to use for size. If empty, all hexagons will be the same size. |
| Group by | Field to group by. |
| Labels | Fields to use as labels in the tooltip. |
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Install on Grafana Cloud
Plugins can be installed directly from within your Grafana instance or automated using the Cloud API or Terraform.
Learn more about plugin installationMarketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Get this plugin
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install Hexmap from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
0.3.3 (2022-06-28)
Update for Grafana 9.0.
0.3.2 (2021-11-19)
Enhancements
- Upgrade dependencies
0.3.1 (2021-09-05)
Bug fixes
- Fix Data Links for Grafana 8.0
0.3.0 (2021-03-01)
Enhancements
- Hide group label when there's only one group (#2)
- Add Labels option to add extra information to the tooltip (#2)
- Remove the Value dimension. The only real use for the value dimension was to display a metric in the tooltip. The Labels dimension is more versatile.
0.2.0 (2021-02-17)
Enhancements
- Make dimensions clearable
- Add fallback panel for unsupported Grafana versions
- Add wizard for configuring the query
Bug fixes
- Size by field fails in 7.4
0.1.0
Initial release. Not fit for production use.
