Plugins 〉CSV
Developer
Grafana Labs
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
grafana
CSV
Documentation →
CSV data source for Grafana
(NOTE: this plugin is now in maintenance mode, no new features will be added. We recommend using the Infinity data source plugin instead. If you want to get started quickly with CSV and Grafana, please read How to Visualize CSV Data with Grafana, which uses the recommended approach.)
The Grafana CSV Datasource plugin is designed to load CSV data into Grafana, expanding your capabilities to visualize and analyze data stored in CSV (Comma-Separated Values) format. Whether you have log files, historical data, or other datasets in CSV format, this plugin streamlines the process of integrating this data into your Grafana dashboards.
Documentation
For comprehensive instructions on setting up and configuring the Grafana CSV Datasource, please consult our official documentation.
Maintenance: Now the plugin is being maintained by Grafana Labs. Big thanks to Marcus Olsson for the awesome work!
Installing CSV on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install CSV from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v0.6.23 - 2025-02-07
  • Update documentation about the deprecation
v0.6.22 - 2025-01-17
  • 🛡️ Security: golang.org/x/net from 0.30.0 to 0.33.0
  • 🛡️ Security: Update grafana-plugin-sdk-go to 0.263.0
  • 🛡️ Security: Build and publish pipelines uses latest go lang version 1.23.5 which includes security fixes to the crypto/x509 and net/http packages ( CVE-2024-45341 and CVE-2024-45336 ). More details can be found here
v0.6.21 - 2024-10-30
  • 🛡️ Security: Update uplot to 1.6.31
v0.6.20 - 2024-10-18
  • 🛡️ Security: Update grafana-plugin-sdk-go to 0.255
  • 🛡️ Security: Bump dompurify from 3.1.0 to 3.1.6
  • 🛡️ Security: Bump path-to-regexp from 1.8.0 to 1.9.0
v0.6.19 - 2024-09-03
  • 🛡️ Security: Bump micromatch from 4.0.5 to 4.0.8
  • 🛡️ Security: Bump webpack from 5.86.0 to 5.94.0
  • 🛡️ Security: Bump fast-loops from 1.1.3 to 1.1.4
  • 🛡️ Security: Bump ws from 8.14.2 to 8.17.1
  • 🛡️ Security: Bump braces from 3.0.2 to 3.0.3
v0.6.18 - 2024-05-14
  • ⚙️ Chore: Updated the eslint-plugin-prettier dependency
v0.6.17 - 2024-04-18
  • ⚙️ Chore: Bump grafana-plugin-sdk-go from v0.220.0 to v0.225.0
  • ⚙️ Chore: Updated grafana frontend runtime dependencies
v0.6.16 - 2024-04-08
  • ⚙️ Chore: Bump grafana-plugin-sdk-go from v0.197.0 to v0.220.0
v0.6.15 - 2024-03-07
  • ⚙️ Chore: Build with go 1.22
v0.6.14 - 2024-02-14
  • ⚙️ Chore: Maintenance
v0.6.13 - 2024-02-14
  • 🛡️ Security: More robust URL handling: disallow changing the configured hostname in the query editor ( CVE-2023-5122 )
v0.6.12 - 2023-12-19
v0.6.11 - 2023-11-21
  • Feature: Update configuration page to follow best practices
  • ⚙️ Chore: Upgrade grafana-plugin-sdk-go to latest
  • ⚙️ Chore: Added lint github workflow
  • ⚙️ Chore: Update legacy form styling
  • ⚙️ Chore: Update readme and documentation
v0.6.10 - 2023-10-24
  • 🐛 Fix: More robust local file mode handling
v0.6.9 - 2023-10-19
  • 🐛 Fix: Correct query field behavior on older Grafana versions
  • ⚙️ Chore: Upgrade dependencies
v0.6.8 - 2023-10-18
v0.6.7 - 2023-10-09
  • Added feature tracking
v0.6.6 - 2023-08-23
  • 🐛 Fix: Consistently apply field names
v0.6.5 - 2023-05-03
  • ⚙️ Chore: backend binaries are now compiled with go 1.20.4
v0.6.4 - 2023-04-19
  • ⚙️ Chore: backend binaries are now compiled with go 1.20.3
v0.6.3 - 2021-12-03
  • ⚙️ Chore: backend binaries are now compiled with go 1.19.3
  • ⚙️ Chore: frontend npm dependencies updated
  • ⚙️ Chore: added spellcheck
v0.6.2 - 2021-10-14
Full changelog
  • Fixed the broken docs and links
v0.6.1 - 2021-06-22
Full changelog
Bug fixes
  • allow_local_mode accepts any value
v0.6.0 - 2021-06-21
Full changelog
Enhancements
  • Disable local mode by default. To use local mode, allow it in your grafana.ini:
    [plugin.marcusolsson-csv-datasource]
    allow_local_mode = true
v0.5.0 - 2021-03-21
Full changelog
Enhancements
  • Improved query editor with support for HTTP params, headers, and body.
  • Add support for relative paths (#69)
  • Add support for decimal separators (#43)
  • EXPERIMENTAL: Add support for regular expressions in field names (#68). Must be enabled in the Experimental tab in the query editor.
Bug fixes
  • BREAKING: Remove default Accept header (#56). If your data source expects Accept: text/csv on the request, you now need to add it yourself in the Params tab.
v0.4.1 - 2021-03-21
Full changelog
Bug fixes
  • Wrong data format is detected
v0.4.0 - 2021-03-21
Full changelog
Enhancements
  • Add support for annotation queries
  • Add support for variables queries (#30)
  • Upgrade @grafana/* packages
  • Upgrade Grafana Go SDK
v0.3.3 - 2021-02-05
Full changelog
Bug fixes
  • Default to HTTP if no storage type has been set
v0.3.2 - 2021-02-03
Full changelog
Bug fixes
  • Allow lazy quotes (#17)
v0.3.1
Full changelog
Enhancements
  • Update grafana-plugin-sdk-go to v0.83.0
Bug fixes
  • Ignore empty custom HTTP headers
  • 🐛 Fix: duplicate JSON tag for TLS skip verify
v0.3.0
Full changelog
Enhancements
  • Add ARM support (#13)
Bug fixes
  • Windows: Paths with backslashes don't work (#14)
v0.2.0
Full changelog
Enhancements
  • Add support for local CSV files (#6)
  • Add a default Accept header for text/csv
v0.1.0
Initial release. Not fit for production use.
