Plugins 〉Satellite Visualizer
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
- Overview
- Installation
- Change log
- Related content
A satellite visualization panel plugin for Grafana based on CesiumJS.
Settings
- Set
Access token
with a Cesium ion access token (security best practices). - (optional) Set
Asset ID
with ID of the glTF asset stored in Cesium ion.
Data
This plugin needs a data series with 8 columns:
Column # | Description |
1 | Time |
2 | Longitude (deg ) / x_ECI (m ) / x_ECEF (m ) |
3 | Latitude (deg ) / y_ECI (m ) / y_ECEF (m ) |
4 | Altitude (m ) / z_ECI (m ) / z_ECEF (m ) |
5-8 | Orientation in inertial frame (x, y, z, s quaternion) |
References
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Satellite Visualizer on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Satellite Visualizer from the commandline:
grafana-cli plugins install
Changelog
1.0.0 (Unreleased)
Initial release.
