Plugins 〉Website Navigation
Website Navigation
Website Navigation
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Website Navigation on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Website Navigation from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
[1.1.0] - 2025-06-01
✨ Added
🌍 Full Internationalization Support
- Added complete i18n support with English and Chinese languages
- Automatic language detection from Grafana user settings and browser preferences
- Localized panel options, link editor interface, and error messages
- Real-time language switching capability
- Persistent language preferences with graceful fallbacks
🎨 Enhanced Theme Support
- Improved visual styling for better theme integration
- Enhanced contrast and readability across different themes
🔧 New Configuration Options
- Added font size customization (8-32px range)
- Configurable link width settings
- Enhanced display options for better customization
📋 Link Management Improvements
- Added sort field for custom ordering of links and groups
- Groups are now sorted by the highest sort value within the group
- Links within groups are sorted in descending order by sort value
- Improved link editor interface with better usability
🔒 Security
- Role-Based Access Control
- Implemented permission checking for links based on user roles (Admin, Editor, Viewer)
- Links are filtered based on current user's permissions
- Secure handling of user data from Grafana context
🐛 Fixed
- Improved error handling for permission checks
- Better fallback mechanisms for missing user information
- Enhanced stability when accessing Grafana user context
🛠️ Technical Improvements
- Updated to Grafana 11.5.3+ compatibility
- Enhanced TypeScript types and interfaces
- Improved code organization and maintainability
- Added comprehensive error handling and logging
📚 Documentation
- Added detailed internationalization documentation
- Improved README with usage examples and configuration guide
- Enhanced code comments and documentation
[1.0.0] - 2023-12-01
✨ Initial Release
Core Navigation Panel
- Display website navigation links in customizable panels
- Support for grouping links by categories
- Multiple display themes (default and box themes)
- Show/hide options for group names and link icons
Basic Configuration
- Navigation data configuration through panel options
- Link URL and title customization
- Target window options (same window or new tab)
- Group-based organization of links
Developer Features
- Built with React and TypeScript
- Webpack-based build system
- Jest testing framework
- ESLint code quality tools
- Docker development environment
Plugin Architecture
- Standard Grafana panel plugin structure
- Plugin signing support for distribution
- Apache 2.0 license
🔧 Technical Stack
- React 18.2.0
- Grafana Data/UI/Runtime APIs
- TypeScript 5.5.4
- Webpack 5 build system
- Node.js 18+ support
