Plugins 〉Destiny Datasource
Destiny Datasource
Destiny Data source
Fetches activity history for players from Destiny 2 using the Bungie.net API.
- Lists activity history for single player.
- Can return history for all characters, or specific characters
- Can filter activity history by activity mode
Data returned for each activity:
- Character played
- Activity details (activity name, PvP map, and 'directory activity')
- Specific activity (e.g. map for PvP)
- Start and end times, and activity duration
- Time character was in the activity (e.g. if joined in progress)
- PGCR ID
- Whether activity was successfully completed or not
- Whether character won or lost
Setup
This data source plugin requires a developer API key from Bungie.net:
- Log into bungie.net
- Visit www.bungie.net/en/Application/Create
- Fill in the fields. It's not particuarly important for most of the values:
- Application Name: a familiar name for you to refer to this API key
- Website: Doesn't matter - example.com is fine
- OAuth Client Type: "Not applicable"
- Redirect URL: leave blank
- Origin Header: leave blank
- Once created, the page will list the API Key. Copy and use this when configuring this Data source in Grafana.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Destiny Datasource on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install Destiny Datasource from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
