Plugins 〉Pareto Chart
Developer
Isa Ozler
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Pareto Chart
  • Overview
  • Installation
  • Related content
Grafana Pareto Panel Plugin
Edit Panel
This plugin provides you the ability to draw a Pareto chart with RDB and TimeSeries databases.
Features
  • Setting a custom background color to the tooltip overlay
  • Configurable vital few and trivial many lines
  • Pan and zoom for detailed info without changing date range
  • Set decimals count on displayed values
  • Specify bar spacing
  • Quickly copy bar data to clipboard simply by clicking on the bar
  • Option to show/hide bar values on default
  • Style graphs to need
TimeSeries (InfluxDB) dashboard impression
Dashboard impression
MySQL Example
Provide the defects which could be "categories" (type string) for example and a frequency value cummulatives/counts (type number).
| Defects | Counts | | :-: | :-: | | Error 1 | 10 | | Error 2 | 4 | | Error 3 | 1 | | ... | ... |
Example Query
SELECT _label_, _count_, ...
FROM _table_
Installing Pareto Chart on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Pareto Chart from the commandline:
grafana-cli plugins install
