Plugins 〉Comparison Panel
Dependencies
Grafana
Developer
Last updated
Register today! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Comparison Panel
- Overview
- Installation
- Change log
- Related content
Comparison Panel
The Comparison panel is meant to display the difference of a current set of values and
the set of values right before, with the same time range.
When the current time range is for example from now-5m
to now
, the previous time range
(the one to compare with) should be now-10m
to now-5m
. To achieve this easily, use
the ${__range}
variable for current and offset ${__range}
for previous values as seen
in the table below.
Required query names and queries (queries are exemplary)
Query name | query |
total-filtered | increase(application_total{status="success"}[${__range}]) |
total-right-filtered | increase(application_total{status="timeout"}[${__range}]) |
previous-filtered | increase(application_total{status="success"}[${__range}] offset ${__range}) |
previous-right-filtered | increase(application_total{status="timeout"}[${__range}] offset ${__range}) |
The query names are mandatory.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Comparison Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Comparison Panel from the commandline:
grafana-cli plugins install
Changelog
1.0.0 (Unreleased)
Initial release.
