Plugins 〉Groonga
Developer
Amiya
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Data Source
community
Groonga
  • Overview
  • Installation
  • Related content
Grafana Groonga Data Source Plugin
CI
View report data from Groonga in your Grafana.
Install the Data Source
Use the new grafana-cli tool to install groonga-datasource from the commandline:
grafana-cli plugins install groonga-datasource
The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins if you installed the grafana package.
Configure the Data Source
Accessed from the Grafana main menu, newly installed data sources can be added immediately within the Data Sources section. Next, click the Add data source button in the upper right. The data source will be available for selection in the Type select box. To see a list of installed data sources, click the Plugins item in the main menu. Both core data sources and installed data sources will appear. Select Groonga-datasource and enter the Name, URL, Default table name, and Default field name in the displayed setting screen.
How to try
You can use docker-compose to try groonga-datasource. Here is a command line to try groonga-datasource 1.0.4:
GF_GROONGA_DATASOURCE_DIR=/tmp/groonga-datasource \
  GF_INSTALL_PLUGINS="https://github.com/groonga/grafana-datasource-plugin-groonga/releases/download/1.0.4/groonga-datasource-1.0.4.zip;groonga-datasource" \
  docker-compose up garafana
You can find Grafana at http://localhost:3000/ .
You can login as the admin user with admin for password.
You can find "Groonga" datasource at the bottom of http://localhost:3000/datasources/new . You can use the following parameters to use the test Groonga server that has some test data:
  • Name: Groonga
  • HTTP
    • URL: http://groonga:10041/
  • Groonga Details
    • Default table name: Logs
    • Default time field name: timestamp
You can use the Groonga datasource in a panel with the following parameters:
  • Table Name: Logs
You can see visualized data in the test Groonga server.
Usage
  • Table Name: target table name.
  • Time field: the key time field for the table.
  • Output columns: output columns by csv format. (ex: timefield,value1,value2)
  • limit num: number of output records. default value is 10.
  • Filter string: filtering string according to Groonga's script syntax.
  • Sort columns: sort key columns by csv format. (ex: timefield,value1,-value2)
    • If you want to use descending order, add - at the beginning.)
If you want to perform aggregation processing, specify the following.
  • Key columns: Aggregate key columns by csv format.
  • Type: data aggregation method(count/sum/max/min/avg).
  • Target: column to be aggregated.
  • Interval: Interval when aggregation is performed for each fixed period.
Note:
  • If you want to aggregate every certain period in the graph panel, Interval is required.
  • Aggregated time is stored in a column called AGGTIME and can be used in Key columns and Output columns.
  • If you want to display aggregated values, specify a special column name in Output columns.
Aggregation methodSpecial column name
count_nsubrecs
sum_sum
max_max
min_min
avg_avg
Limitations:
  • If multiple queries are used, the settings of the first query will be valid except for the aggregated items.
License
Apache License 2.0, see LICENSE.
Installing Groonga on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Groonga from the commandline:
2. Configure the Data Source
