Plugins 〉Yugabyte
Developer
Grafana Labs
Data Source
grafana
Yugabyte
Documentation →
Yugabyte data source
The Yugabyte data source plugin allows you to seamlessly connect Grafana to your YugabyteDB instances, enabling rich visualization and monitoring of your YugabyteDB data.
Documentation
For detailed documentation on the Yugabyte data source plugin, including advanced configuration, query syntax, and troubleshooting, please refer to the official documentation.
Contributing
We welcome contributions to the Yugabyte data source plugin! If you encounter any issues or have feature requests, please open an issue in the github repository.
Installing Yugabyte on Grafana Cloud:
Changelog
2.0.1
🐛 Update dependency versions
2.0.0
Feature: Set minimum supported Grafana version to 11.6.0
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.284.0
Chore: Bump frontend dependencies
1.2.0
Feature: PDC frontend support
1.1.0
Feature: PDC support
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.277.1
1.0.0
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.274.0
Chore: Build with Go 1.24
0.1.7-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.265.0
0.1.6-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.261.0
0.1.5-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.260.1
Chore: Bump cross-spawn to 7.0.6
Chore: Change grafana/experimental to grafana/plugin-ui
0.1.4-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.258.0
Chore: Bump uplot to 1.6.31
0.1.3-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.251.0
Chore: Bump path-to-regexp from 1.8.0 to 1.9.0
0.1.2-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.245.0
Chore: Bump micromatch from 4.0.7 to 4.0.8
Chore: Bump webpack from 5.86.0 to 5.94.0
0.1.1-preview
Chore: Update to github.com/grafana/sqlds/v4 v4.1.0
Chore: Update to github.com/grafana/grafana-plugin-sdk-go v0.242.0
Chore: Bump fast-loops from 1.1.3 to 1.1.4
Docs: Set minimum supported Grafana version to 10.4.5
0.1.0-preview
Feature: Initial release - Unlock the potential of your data with our new data source for Grafana!
