Plugins 〉Oracle Database
Developer
Grafana Labs
Data Source
grafana
Enterprise
Oracle Database
Documentation →
How to configure the Oracle Database plugin
Instantly visualize Oracle data in Grafana
The Oracle data source plugin is the easiest way to pull Oracle data directly into Grafana dashboards.
  • Visualize it either in isolation (one database) or blend it with other data sources.
  • Discover correlations and covariances across all your data in minutes.
Installing Oracle Database on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Oracle Database from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
v2.10.6 - 2025-02-17
  • ⚙️ Chore: Improve error logging
v2.10.5 - 2025-02-04
  • ⚙️ Chore: Update frontend dependencies
v2.10.4 - 2025-01-10
  • ⚙️ Chore: Update backend dependencies
v2.10.3 - 2025-01-06
  • ⚙️ Chore: update backend dependencies
v2.10.2 - 2024-12-30
  • 🐛 Fix: Refactor database connector to avoid data races
v2.10.1 - 2024-12-18
  • ⚙️ Chore: Update backend driver
v2.10.0 - 2024-12-18
  • 🐛 Fix: Add timeout to health + query
v2.9.2 - 2024-12-18
v2.9.1- 2024-12-17
v2.9.0 - 2024-12-16
  • 🚀 Feature: Move environment variables into config page
v2.8.13 - 2024-11-12
  • ⚙️ Chore: Updated backend dependencies
v2.8.12 - 2024-10-03
  • ⚙️ Chore: Minimal supported Grafana version is now 10.4.8
v2.8.11 - 2024-09-23
v2.8.10 - 2024-08-30
v2.8.9 - 2024-08-30
  • ⚙️ Chore: add logging on timezone load failures
v2.8.8 - 2024-08-02
  • 🐛 Fix: refactor db connections cache locking to prevent cases when it's always locked
v2.8.7 - 2024-07-22
  • ⚙️ Chore: Add logging in case cached connection verification fails
v2.8.6 - 2024-07-19
  • ⚙️ Chore: Update backend dependencies and add more debug logging
v2.8.5 - 2024-06-19
v2.8.4 - 2024-06-13
  • 🐛 Fix: Fix response format when no rows are returned
v2.8.3 - 2024-04-05
  • 🐛 Fix: Fix broken PDC
v2.8.2 - 2024-03-18
  • ⚙️ Chore: Backend binaries are now compiled with Go version 1.22.1
v2.8.1 - 2024-03-18
v2.8.0 - 2024-02-29
  • ⚙️ Chore: add error source
v2.7.1 - 2023-11-16
  • 📝 Documentation: Updates to Oracle data source documentation breaking it into topics
v2.7.0 - 2023-11-01
  • ⚙️ Chore: Update backend and frontend dependencies
  • ⚙️ Chore: Minimum required Grafana runtime version is now 9.5.13
v2.6.4 - 2023-09-07
  • 🐛 Fix: Fix bug causing configuration page not working in some cases
v2.6.3 - 2023-08-25
  • ⚙️ Chore: Remove "Generated SQL" button from the query editor as it duplicates the functionality of the query inspector
v2.6.2 - 2023-08-24
  • ⚙️ Chore: add debug container
v2.6.1 - 2023-08-23
  • ⚙️ Chore: e2e test support
v2.6.0 - 2023-06-09
  • ⚙️ Chore: Configuration page UI and UX overhaul
v2.5.1 - 2023-06-08
  • ⚙️ Chore: backend libs updated with golang:1.20.5
v2.5.0 - 2023-05-31
v2.4.6 - 2023-05-23
  • ⚙️ Chore: Fixes a bug with the QueryEditor onBlur event so it fires the correct onChange prop
v2.4.5 - 2023-05-05
  • ⚙️ Chore: Updating Dockerfiles to use Go version 1.20.4 which contains security fixes
v2.4.4 - 2023-05-03
  • ⚙️ Chore: Backend binaries are now compiled with Go version 1.20.4 which contains security fixes
v2.4.3 - 2023-04-19
  • ⚙️ Chore: Backend binaries are now compiled with Go version 1.20.3 which contains security fixes
  • ⚙️ Chore: Minimum required Grafana runtime version is now 8.4.7
v2.4.2 - 2023-04-19
  • ⚙️ Chore: Backend dependencies updated
v2.4.1 - 2023-03-30
  • ⚙️ Chore: Remove unused images in screenshots folder
v2.4.0 - 2023-03-28
  • 🚀 Feature: Prevent from using kerberos when TNSNames option is disabled
  • 🚀 Feature: Prevent from running query on editor blur
  • 🐛 Fix: Fix Generated SQL in code Editor
  • 📝 Documentation: Fix formatting and cleanup in docs
v2.3.0 - 2023-02-10
  • 🚀 Feature: Data source config page improvements
v2.2.8 - 2022-12-15
  • ⚙️ Chore: Backend binaries are now compiled with Go 1.19.4
v2.2.7 - 2022-11-01
  • backend binaries are compiled with go 1.19.3
v2.2.6 - 2022-10-14
  • follow-up on obfuscate password input: replace input field with SecretInput from @grafana/ui
  • update dependencies to v8.4.7
  • update docs
v2.2.5 - 2022-10-14
  • obfuscate password input in datasource setting
  • update docs
v2.2.4 - 2022-10-05
  • Update the feature for response data size
v2.2.3 - 2022-09-28
  • Update docs
v2.2.2 - 2022-09-28
  • User can define query response data size with environment variable GF_PLUGINS_ORACLE_DATASOURCE_MAX_RESPONSE_SIZE
  • Update DEV_GUIDE.md for ARM64 developers
v2.2.1 - 2022-09-06
  • ⚙️ Chore: Add back the format selector in the query editor
v2.2.0 - 2022-07-22
  • ⚙️ Chore: update linux amd64 oracle client to 21.6
v2.1.3 - 2022-06-09
  • 🐛 Fix: set exec permissions
v2.1.2 - 2022-05-17
  • Fix libs for rhel/centos 7.x
v2.1.1 - 2022-05-17
  • Add libs for rhel/centos 7.x
v2.1.0 - 2022-05-05
  • Reduce size of Linux zip
v2.0.9 - 2022-03-03
  • Re-implement timezone translation
v2.0.8 - 2022-01-13
  • Adds error message that warns user when response message size is larger than 16Mb
  • Adds the option to compile back-end for ARM64 processors
v2.0.7 - 2022-01-10
  • ⚙️ Chore: Update Licensing
v2.0.6 - 2021-08-10
  • Adds documentation for RHEL 8 libnsl dependency
  • Fixes an issue where hidden queries were still being executed
  • Fixes an issue where queries with just whitespace (empty) were being executed.
v2.0.4 - 2021-04-12
  • ⚙️ Chore: Update SDK
v2.0.2 - 2020-10-09
  • Fixed signed plugin issue
v2.0.1 - 2020-10-06
  • Fixed configuration editor to allow tnsname and kerberos options to be selected during manual setup
  • Adjusted configuration editor entry field sizes
v2.0.2 - 2020-10-09
v2.0.1 - 2020-10-06
v2.0.0 - 2020-10-01
  • Compatible with Grafana v7.1+
Key Features:
  • Conversion to dataframes for easier use with different visualizations and data transformations
  • Updated to use InstantClient v19, supporting stcp connections
  • Query editor now uses monaco for syntax
Bugfixes:
  • Connection cache will expire idle connections to prevent slow responses
Note: Time Zone support not included in v2.0.0, to be added in next minor release. All connections and results are processed as UTC.
v1.2.2 - 2020-08-28
  • Fix for kerberos authentication error output
v1.2.1 - 2020-08-19
  • NEW: Support for TNSNAMES and Kerberos Authentication
  • Fix for issue #133 (redact message on connection error)
  • Fix field comparisons for Annotation Queries
  • Increase max message size to 16MB
v1.2.0 - 2020-05-15
  • Now compatible with Grafana v7.0.0
  • Now grafana-cli installable
v1.1.7 - 2020-03-27
  • Fix for Edge Browser
v1.1.6 - 2020-03-25
  • New fill options for macros (intervals now the same as other sql datasources)
  • New timezone configuration setting for datasource (default is UTC)
  • 🐛 Fix: removed auto-quoting of time columns in macros
v1.1.5 - 2020-02-13
  • Better handling of macro $__timeGroup
  • Implements fill options for $__timeGroup similar to other sql datasources
  • Upgrade build to go-1.13.7
  • Converted to go mod
  • Additional test coverage
v1.1.4 - 2020-02-05
  • Connection pool size is now working
  • Profiling setting now working
  • Fix for backend crash when nil values are return
  • Fix for locking issue causing backend to hang
  • Fix quoting issues
  • Implement braces for macros
  • Now allows sql statements inside macros
v1.1.3 - 2019-12-18
  • GF_PLUGINS_ORACLE_DATASOURCE_POOLSIZE can be used to increase/decrease the size of the connection pool with Oracle. The new default is 50
v1.1.2 - 2019-11-04
  • GF_PLUGINS_PROFILER must be set to "oracle-datasource" to enable profiling. default is false.
v1.1.1 - 2019-09-20
  • Remove connection string output from debug mode
  • Refactor to clean up go lint warnings
v1.1.0 - 2019-07-20
  • Fixes panic of backend plugin on windows
  • Update to all package dependencies
v1.0.9 - 2019-06-10
  • Return message when query results are too large
  • Prevent crash due to attempting too large response
  • Additional handling of nullable columns
  • Updated packages
v1.0.8 - 2019-05-15
  • Now handles nullable column for value field when transforming to timeseries
v1.0.7 - 2019-05-09
  • lower query cache TTL to 60 seconds
  • fix leak due to deferred close inside loop
  • reuse fingerprint vs recalculating (small performance gain)
  • detect errors iterating rows
  • add more debug output
  • updated vendored packages
v1.0.6 - 2019-04-25
  • Now provides info level log line when type is not matched
  • Added additional data types
    • converts to type FLOAT: SQLT_INT, SQLT_UIN, SQLT_FLT, SQLT_VNU, SQLT_LNG, SQLT_BFLOAT, SQLT_BDOUBLE
    • converts to type STRING: SQLT_STR, SQLT_LVC, SQLT_VST, SQLT_VBI, SQLT_LBI, SQLT_LVB
    • converts to type DATE: SQLT_DATE
    • converts to type BYTES: SQLT_FILE
  • 🐛 Fix: when a query returns no results (and data types as a part of the results), the types are not cached to allow future queries with results update the cache
v1.0.5 - 2019-04-08
  • gRPC: hardcode message size to 16MB vs 4MB
  • enable alerting
v1.0.4 - 2019-03-29
  • Plugin now links oracle libraries from plugin directory, no need for installation externally on system (linux only, windows requires install)
v1.0.3 - 2019-03-18
  • Support additional field type SQLT_NUME
  • Better type conversions
  • Add quoted time field to variable interpolation
v1.0.2 - 2019-03-04
  • Update golang dependencies
v1.0.1 - 2019-02-05
Fixed
#13
  • High CPU utilization issue fix via short-term cache of column types
  • Connection errors fixed by testing cached connections before returning to caller
v0.0.1 - 2018-05-09
Initial Release
