Plugins 〉Mock
Mock
Grafana Mock datasource plugin
:warning: This datasource plugin is in beta. It is designed for validating various grafana compatibility issues. Don't use it in any production environments.
Grafana mock datasource plugin is an utility datasource plugin useful for grafana developers and grafana plugin developers. This plugin is used debug/simulate various scenarios related to plugins.
Develop locally
- Clone the repo
git clone https://github.com/grafana/mock-datasouceandcd mock-datasource - Install dependencies
yarn install - Build the frontend
yarn build( oryarn devto watch frontend changes ) - Build the backend
mage -v - Run the plugin locally
docker compose uporGRAFANA_VERSION=10.4.8 docker compose upto specify the grafana version
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Mock on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Data Source
Use the grafana-cli tool to install Mock from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Changelog
v0.2.5 - 2025-12-01
- ⚙️ Chore: Update grafana config and dependencies
v0.2.4 - 2025-05-09
- ⚙️ Chore: Update prismjs dependency to version 1.30.0
- ⚙️ Chore: Update backend dependencies
v0.2.3 - 2025-03-19
- Empty release to trigger the release workflow
v0.2.2 - 2025-03-19
- ⚙️ Chore: Updated frontend dependencies
v0.2.1 - 2025-03-18
- ⚙️ Chore: Updated backend dependencies
v0.2.0 - 2025-01-10
- 🐛 Bug fix: Fixed the broken backend code
- ⚙️ Chore: Added github actions scripts for CI & CD
- ⚙️ Chore: Added playwright E2E test infra
- ⚙️ Chore: Updated backend tracing and logging with traceId and spanId
- ⚙️ Chore: Updated plugin dev configuration
- ⚙️ Chore: Minimum required grafana version updated to 10.4.x
v0.1.9 - 2024-09-18
- ⚙️ Chore: Updated dependencies
v0.1.8 - 2024-09-12
v0.1.7 - 2024-03-06
- ⚙️ Chore: Updated golang version to 1.22.1
- ⚙️ Chore: Updated plugin SDK to v0.212.0 from v0.162.0
- ⚙️ Chore: Updated create-plugin configuration
yarn create @grafana/plugin update
v0.1.6 - 2023-12-20
v0.1.5 - 2023-06-02
- ⚙️ Chore: adding distributed tracing support
- ⚙️ Chore: Updated grafana plugin SDK from
v0.159.0tov0.162.0
v0.1.4 - 2023-04-19
- ⚙️ Chore: Backend binaries are now compiled with
golang:1.20.3which contain security fixes - ⚙️ Chore: Backend grafana SDK dependencies are updated
v0.1.3 - 2023-04-19
- 🚀 Feature: Added support for typeVersion property in frame meta
- ⚙️ Chore: Grafana plugin SDK updated to v0.148.0
- ⚙️ Chore: Backend compiled with latest go version 1.19.5
- ⚙️ Chore: Migrated build process from @grafana/toolkit to @grafana/create-plugin
v0.1.2 - 2022-12-13
- ⚙️ Chore: Backend compiled with latest go version 1.19.4
- ⚙️ Chore: Grafana plugin SDK updated to v0.145.0
v0.1.1 - 2022-11-11
- 🚀 Feature: Raw frame editor now supports custom status codes and error messages
- 🚀 Feature: Enabled annotations editor
- ⚙️ Chore: Backend compiled with latest go version 1.19.3
- ⚙️ Chore: Grafana plugin SDK updated to v0.142.0
v0.1.0 - 2022-10-20
- 🚀 Feature: Initial version
