Plugins 〉Google Sheets
Google Sheets
Google Sheets data source
Visualize your Google Spreadsheets in Grafana!
Documentation
For the plugin documentation, visit plugin documentation website.
Video Tutorial
Watch this video to learn more about setting up the Grafana Google Sheets data source plugin:
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on Google Sheets data source plugin demo.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Google Sheets on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Google Sheets from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
2. Configure the Data Source
Change Log
2.2.1
🐛 Bump github.com/grafana/grafana-google-sdk-go to 0.4.2
2.2.0
- Add support for filtering in template variables
2.1.0
- Add template variables functionality
2.0.3
- Bump
github.com/grafana/grafana-plugin-sdk-goto 0.277.1 - Docs and configuration page updated with inline docs
2.0.2
- Update frontend dependencies
- Built with go 1.24
2.0.1
- Update documentation
- Bump
github.com/grafana/grafana-plugin-sdk-goto 0.263.0
2.0.0
- Plugin now requires Grafana 10.4.8 or newer
1.2.18
- Backend dependencies update
- Readme changes
- Replace @grafana/experimental with @grafana/plugin-ui (#294)
1.2.17
- Improve data source documentation
- Fix error source for various http errors
- Bump
cross-spawnto 7.0.6 - Bump
github.com/grafana/grafana-plugin-sdk-goto 0.259.2
1.2.16
- Bump
uplotto 1.6.31 - Bump
github.com/grafana/grafana-plugin-sdk-gofrom 0.251.0 to 0.258.0
1.2.15
- New documentation on grafana.com #255
1.2.14
- Bump
path-to-regexpfrom 1.8.0 to 1.9.0 #268 - Bump
github.com/grafana/grafana-plugin-sdk-gofrom 0.250.0 to 0.251.0. #275
1.2.13
- Update
github.com/grafana/grafana-plugin-sdk-gotov0.248.0 - Add logging for response size
- Fix error source for invalid JWT information
1.2.12
- Update
github.com/grafana/grafana-plugin-sdk-gotov0.245.0 - Bump micromatch from 4.0.7 to 4.0.8
- Bump webpack from 5.92.0 to 5.94.0
- Improve efficiency when processing response
- Fix timeout error source
- Add the make docs procedure
1.2.11
- Update
github.com/grafana/grafana-plugin-sdk-gotov0.241.0 - Fix context canceled errors to be marked as downstream
1.2.10
- Improve handling of unknown non-api errors
- Add error source to error responses
1.2.9
- Fix showing of correct percentages values
- Upgrade dependencies
1.2.8
1.2.7
1.2.6
- Build with go 1.22
- Configuration help: Add additional instruction to enable Google Sheets API
1.2.5
- Upgrade grafana-plugin-sdk-go to latest
- Added lint github workflow
- Remove legacy form styles
1.2.4
- Added feature tracking
1.2.3
- Make sure we don't mutate the options object in the config page. This prevents crashes that occurred intermittently.
1.2.2
- Handle error messages more gracefully
v1.2.0
- Refactored authentication to use grafana google sdks. With this change you can now use GCE authentication with google sheets.
There was a change in the plugin configuration. Please take a look at the provisioning example in the documentation. The change is backward compatible so you can still use the old configuration.
v1.1.8
- Chore: Backend binaries are now compiled with golang 1.20.4
v1.1.7
- Chore: Update to Golang 1.20
v1.1.6
- Fix: Don't panic when the user selects a range of empty cells.
v1.1.5
- Chore: Update to Golang 1.19 #160
v1.1.4
- Fix: deprecated link variant button for v9
v1.1.3
- Bump grafana dependencies to 8.3.4
v1.1.2
- Change release pipeline
v1.1.1
- Targeting Grafana 8.1+
- Documentation and link fixes
- Add explicit explanation to the auth constraint
v1.1.0
- Targeting Grafana 7.2+
- Adding support for annotations
- Include arm builds
v1.0.0
- Works with Grafana 7+
- Avoid crashing on unknown timezone (#69)
- improved support for formula values
- supports template variables
v0.9.0
- First official release (grafana 6.7)
v0.1.0
- Initial Release (preview)
