Plugins 〉GitHub
Developer
Grafana Labs
Data Source
grafana
GitHub
Documentation →
Grafana GitHub data source
The GitHub data source plugin for Grafana lets you to query the GitHub API in Grafana so you can visualize your GitHub repositories and projects.
Documentation
For the plugin documentation, visit plugin documentation website
Video Tutorial
Watch this video to learn more about setting up the Grafana GitHub data source plugin:
GitHub data source plugin | Visualize GitHub using Grafana | Tutorial
[!TIP]
With Grafana Play, you can explore and see how it works, learning from practical examples to accelerate your development. This feature can be seen on GitHub data source plugin demo.
GitHub API V4 (GraphQL)
This data source uses the githubv4 package, which is under active development.
Private data source connect - Only for Grafana Cloud users.
Establishes a private, secured connection between a Grafana Cloud stack and data sources within a private network. Use the drop-down to locate the PDC URL. For setup instructions, refer to Private data source connect (PDC) and Configure PDC. Click Manage private data source connect to open your PDC connection page and view your configuration details.
Frequently Asked Questions
  • Why does it sometimes take up to 5 minutes for my new pull request / new issue / new commit to show up?
We have aggressive caching enabled due to GitHub's rate limiting policies. When selecting a time range like "Last hour", a combination of the queries for each panel and the time range is cached temporarily.
  • Why are there two selection options for Pull Requests and Issue times when creating annotations?
There are two times that affect an annotation:
  • The time range of the dashboard or panel
  • The time that should be used to display the event on the graph
The first selection is used to filter the events that display on the graph. For example, if you select "closed at", only events that were "closed" in your dashboard's time range will be displayed on the graph.
The second selection is used to determine where on the graph the event should be displayed.
Typically, these will be the same, however there are some cases where you may want them to be different.
Installing GitHub on Grafana Cloud:
Change Log
2.4.1
🐛 Update create-plugin configs 🐛 Fixed the broken E2E tests with updated plugin-e2e package
2.4.0
Minor Changes
🚀 Add support for PDC
Patch Changes
🐛 Fix empty results in Workflows query type. Added nil check for CreatedAt/UpdatedAt timestamps and added "None" option to Time Field dropdown (default) to return all workflows without time filtering.
2.3.0
🚀 Add UpdatedAt time field to pull request queries
🐛 Add runStartedAt field for workflow runs query response
2.2.0
🚀 Adds support for Pull Request Review queries
⚙️ Bump form-data from 4.0.0 to 4.0.4 (#490)
⚙️ Add alternate "rate limit exceeded" error handling (#494)
🐛 Remove <base target="_blank"> from readme (#497)
⚙️ Bump @grafana/create-plugin configuration to 5.25.8 (#496)
2.1.7
🐛 Return assignees with issues queries
2.1.6
🐛 Documentation links will open in a new tab 🐛 Removed unused annotations method (replaced with new annotations support in #196) 🐛 Fixes error parsing app id / client id through provisioning via environment variables. Fixes #477 🐛 Replaced the deprecated setVariableQueryEditor with CustomVariableSupport
2.1.5
🐛 Update golang-jwt/jwt dependency to v4.5.2 🐛 Get default http transport from plugin-sdk-go
[2.1.4]
  • Fix - Workflow runs - date filter now filters by time
  • Fix - Panic in project query
  • Security - Bump prismjs to 1.30.0
[2.1.3]
  • Fix - Add mutex protection to prevent data races in datasource cache
  • Chore - Add validation for package types
[2.1.2]
  • Fix - GitHub enterprise url missing /api/v3
[2.1.1]
  • Fix - GitHub enterprise url wrong with app authentication
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go to 0.268.1
[2.1.0]
  • Feature - Add a new query to retrieve Workflow runs
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go to 0.266.0
  • Chore - Bump dompurify to 3.2.4
[2.0.2]
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go to 0.265.0
[2.0.1]
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go from 0.260.3 to 0.261.0
[2.0.0]
  • Chore: Plugin now requires Grafana 10.4.8 or newer
[1.9.2]
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go from 0.255.0 to 0.258.0
  • Chore - Update uplot dependency to 1.6.31
[1.9.1]
  • Docs - Add video tutorial to the README
  • Docs - Update documentation for permissions and provisioning
  • Docs - Update documentation plugin setup
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go from 0.252.0 to 0.255.0
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go from 0.251.0 to 0.252.0
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go from 0.250.0 to 0.251.0
[1.9.0]
  • Feature - Add support for GitHub App authentication
  • Fix - Fix error source for saml error and limit error
  • Fix - Hide package types that are not supported by the GraphQL API
  • Chore - Update spelling of GitHub
  • Chore - Bump github.com/grafana/grafana-plugin-sdk-go from 0.247.0 to 0.250.0
  • Chore - Bump path-to-regexp from 1.8.0 to 1.9.0
[1.8.2]
  • Chore - Bump grafana-plugin-sdk-go to v0.247.0
[1.8.1]
  • Chore - Bump micromatch from 4.0.5 to 4.0.8
  • Chore - Bump webpack from 5.91.0 to 5.94.0
  • Chore - Bump grafana-plugin-sdk-go to v0.245.0
[1.8.0]
  • Feature - Add additional user field to results in Pull Request query
  • Chore - Update documentation, new and updated documentation available on official website
[1.7.4]
[1.7.3]
  • Fix - Fix error in Packages query where no package type was initially selected
  • Chore - Bump grafana-plugin-sdk-go to v0.241.0
  • Chore - Mark downstream errors
[1.7.2]
  • Chore - Bump grafana-plugin-sdk-go to v0.240.0
[1.7.1]
  • Chore - Add provisioning folder to .gitignore
  • Chore - Add error source to error response
[1.7.0]
  • Feature - Add updated_at field to results in Issue query
  • Feature - Add UpdatedAt field to query options in Issue query
  • Fix - Fix error when response has data with empty array in templating
  • Fix - Fix per page limit to 100 in Workflows query as it is max supported value
  • Fix - Remove query input in Vulnerabilities query as API does not support it
  • Chore - Move e2e from cypress to playwright
  • Chore - Update dependencies
[1.6.0]
  • Feature - Add message field to Commit query
  • Feature - Add name field to Workflow status query
  • Fix - Variable editor to support all query types
[1.5.7]
[1.5.6]
  • Chore - Build with go 1.22.2
  • Chore - Bump grafana-plugin-sdk-go to v0.220.0 (latest)
  • Bug Fix - Prevent partial queries running on change of query type
[1.5.5]
  • Fix - Make health check faster by using github-datasource repository instead of grafana
[1.5.4]
  • Chore - Bump grafana-plugin-sdk-go to v0.198.0 (latest)
  • Bug Fix - Fix tag queries to return commits as well
  • Bug Fix - Fix for resetting URL in the config page
[1.5.3]
  • Chore - Bump grafana-plugin-sdk-go to latest
  • Chore - Added lint GitHub workflow
  • Chore - Remove legacy form styling
[1.5.2]
  • BugFix - Fix config page backwards compatibility with Grafana < 10.1
[1.5.1] - 2023-10-10
  • Feature - Update configuration page
  • Chore - Update feature tracking usage to improve performance
[1.5.0] - 2023-09-13
  • Feature - Issues Query: Allow repo to be optional
[1.4.7] - 2023-08-03
  • Feature - Add ability to query Workflow and Workflow usage
[1.4.6] - 2023-07-14
  • Bugfix - Fixed a bug where disabled queries were still being executed
[1.4.5] - 2023-05-04
  • Chore - Backend binaries are now compiled with golang 1.20.4
[1.4.4] - 2023-04-19
  • Chore - Updated go version to 1.20
[1.4.3] - 2023-03-07
  • Chore - Update grafana-plugin-sdk-go to v0.155.0 to fix The content of this plugin does not match its signature error
[1.4.2] - 2023-03-06
  • Chore - Migrate to create plugin and upgrade dependencies
[1.4.1] - 2023-03-01
  • Feature - Added RepositoryVulnerabilityAlertState field to Vulnerabilities query
[1.4.0] - 2023-02-03
  • Feature - Added stargazers query type
  • Chore - Minor documentation updates
[1.3.3] - 2023-01-09
  • Chore - Removed angular dependency: migrated annotation editor
[1.3.2] - next
  • Feature Added $__toDay() macro support
[1.3.1] 2022-12-21
  • Chore - Updated go version to latest (1.19.4)
  • Chore - Updated backend grafana dependencies
  • Chore - Added spellcheck
[1.3.0] 2022-11-3
  • Feature - GitHub projects - query items, user projects
  • Chore - Updated build to use go 1.19.3
[1.2.0] 2022-10-20
[1.1.0] - next
  • Updated grafana minimum runtime required to 8.4.7
[1.0.15] 2022-05-05
  • Fix variable interpolation
[1.0.14] 2022-04-25
  • Added a $__multiVar() macro support
[1.0.13] 2021-12-01
  • Fixed a bug where dashboard variables could not be set properly
[1.0.12] 2021-12-01
  • Added refId in annotation queries
[1.0.11] 2021-05-17
  • Added repository fields to the responses
[1.0.10] 2021-04-01
  • Fixed issue where some time values were being rendered incorrectly
[1.0.9] 2021-04-01
  • Fixed issue where dashboard path was not incorrect
[1.0.8] 2020-12-10
  • Fixed issue where screenshots were not rendering on grafana.com (thanks @mjseaman)
[1.0.7] 2020-12-07
  • Added Tags to the list of queryable resources in the AnnotationsQueryEditor ( thanks @nazzzzz)
[1.0.6] 2020-09-24
  • Added a message to the healthcheck success status (thanks @vladimirdotk)
  • Added URL option for GitHub Enterprise Users (thanks @bmike78)
[1.0.5] 2020-09-15
  • Added Pull Request ID (Number), URL, and Repository name to pull request responses ( fixes #60 )
  • Added the ability to search for all Pull Requests in an organization using the org: search term ( fixes #61 )
  • Removed limit from repository list ( fixes #59 )
[1.0.3] 2020-09-11
  • Add the ability to disable time field filtering for pull requests ( fixes #57 )
[1.0.1] 2020-09-11
  • Add the ability to query repositories for variables ( fixes #52 )
  • Fix scoped variables for repeating panels ( fixes #51 )
  • The default time field for pull requests (Closed At) is now being displayed instead of an empty dropdown
[1.0.0] 2020-09-10
  • Initial release
