Plugins 〉Clock
Clock
Clock Panel Plugin for Grafana
The Clock Panel shows either the current time or a countdown/countup. It updates every second.
You can use the Clock Panel to display the time in another office, or to track a count-down or count-up to an important event.
Plugin options
Options
Mode:
The default mode is Time. If you want to use countdown mode, then set the End Time to start the count-down. If you want to use countup mode, then set the Begin Time to start the count-up.
Clock Type:
To display time choose between the following formats: 24 Hour, 12 Hour, or Custom.
Timezone:
Timezones are supplied by the moment timezone library. You can specify your Timezone or leave it as default to moment's guess using your computer's settings.
Timezone is also used to calculate countdown deadline in countdown mode.
Locale:
Locales for date-formatting are supplied by the moment library. You can specify your Locale or leave it as default to moment's guess using your computer's settings.
End Time (Countdown mode):
Used in conjunction with mode when set to countdown. Choose a date and time to count down to.
This field also supports dashboard (constant) variables (e.g.
${countdown_target}) to dynamically set the countdown deadline for the Dashboard.End Text (Countdown mode):
The text to show when the countdown ends. E.g. LIFTOFF
Begin Time (Countup mode):
Used in conjunction with mode when set to countup. Choose a date and time to count up from.
Begin Text (Countup mode):
The text to show before the countup starts. E.g. LIFTOFF
Date/Time formatting options:
Customize the font size, weight and date/time formatting with this setting.
If second ticking annoys you then change the time format to HH:mm (for the 24-hour clock) or h:mm (for the 12-hour clock), or see the full list of formatting options.
Font Monospace:
Enable monospace font for consistent character width and alignment.
Description Settings:
Configure descriptive text to display alongside the time:
- Source: Choose between three options:
- None: No descriptive text will be displayed
- Input: Display static text that you enter manually
- Query: Display dynamic text retrieved from a datasource query
- Description Text: Manual text input (only available when using Input source)
- Font Size/Weight: Customize description text appearance
Show Date:
Toggle date visibility alongside the time.
Date Format:
Customize date formatting using moment.js patterns.
Date Locale:
Set locale for date formatting.
Date Font Size/Weight:
Customize date text appearance.
Timezone Display Options:
Control timezone display:
- Show Timezone: Toggle timezone visibility
- Display Format: Choose between different timezone display formats:
- Normal: Shows full timezone name (e.g. "America/New_York", "UTC")
- Name + Offset: Shows timezone name with offset and abbreviation on separate lines (e.g. "America/New_York" with "(-05:00 EST)" below)
- Offset + Abbreviation: Shows ISO 8601 offset with abbreviation (e.g. "-05:00 EST", "+00:00 UTC")
- Offset: Shows only the ISO 8601 offset (e.g. "-05:00", "+00:00")
- Abbreviation: Shows only the timezone abbreviation (e.g. "EST", "UTC", "PST")
- Font Size/Weight: Customize timezone text appearance
Query Configuration (for Countdown/Countup modes):
When using datasource queries for target times:
- Calculation Method: Choose how to select datetime from multiple query results:
- Countdown: Last, Last*, First, First*, Min, Max, Min Future (*excludes null/NaN values)
- Countup: Last, Last*, First, First*, Min, Max, Max Past (*excludes null/NaN values)
- Field Selection: Specify which field contains datetime values
- Error Handling: Configure "No Value Text" and "Invalid Value Text" for query errors
Background Color:
Choose a background color for the clock with the color picker.
Refresh
Refresh:
Choose between "Every second" (default) or "With the dashboard".
When set to "With the dashboard", the clock is paused and only updated when the dashboard refreshes. The clock will show the timestamp for the last refresh.
Screenshots
Troubleshooting Query Errors
Issue
If you see a red triangle error in the top-left corner of the panel it's likely because:
- You selected a datasource but there are no actual queries for your clock configuration
- The selected datasource has an empty or invalid query that produces an error
Solution
- Delete the query from the Query tab to remove the error
- Use the "Grafana" datasource as an alternative that won't generate errors even when not actively used
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Clock on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Clock from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Change Log
3.2.1
- Fixes React unique child key error
3.2.0
- Add
Digitalclock style
3.1.0
- The Clock panel is now available in the following languages:
- English (en-US)
- Čeština (cs-CZ)
- Deutsch (de-DE)
- Español (es-ES)
- Français (fr-FR)
- Magyar (hu-HU)
- Bahasa Indonesia (id-ID)
- Italiano (it-IT)
- 日本語 (ja-JP)
- 한국어 (ko-KR)
- Nederlands (nl-NL)
- Polski (pl-PL)
- Português Brasileiro (pt-BR)
- Português (pt-PT)
- Русский (ru-RU)
- Svenska (sv-SE)
- Türkçe (tr-TR)
- 中文(简体)(zh-Hans)
- 中文(繁體)(zh-Hant)
3.0.1
- Fixes #408
3.0.0
- Add translation support for EN, ES an DE. ES an DE translations will be available in later versions.
- Upgrade to flat ESLint config
- Drop support for Grafana 8.x.x
- Changed package manager from
yarntonpm
2.1.8
- Improves migration handling for non-query panels to eliminate error message display
[2.1.7]
- Handles migration for non-query clock panels to eliminate error message display
- Fixes #186
- Fixes #189
- Cleans up any legacy (angular) settings in top level of panel json
- Adds tests for migrations
[2.1.2]
- Improving wrapping of the panel elements to be more responsive to different panel sizes https://github.com/grafana/clock-panel/pull/117
- Fixing a placeholder for the font size field https://github.com/grafana/clock-panel/pull/116
[2.1.1]
- Migrate to create-plugin instead of toolkit
- Small typo fixes
- Bump grafana packages / dependencies
[2.1.0]
- Added support to set timezone from template variable
[2.0.0]
- Prevent clock panel from crashing Grafana 9.x.x
- Drop support for Grafana 7.x.x
[1.3.1]
- Fixes error on AMG related to dependency imports
[1.3.0]
- Added support for count up mode
- Added support for template variables in count down/up time setting.
[1.2.0]
- Support local for date formats
- Support refresh with dashboard time
- Added dependency on Grafana 7.4+
[1.1.1]
- Improved background
[1.1.0]
- Support for Grafana 7+
- Built with @grafana/toolkit
v1.0.3
- Adds support for displaying timezones
v1.0.1
- Updates Lodash dependency to fix security warning
v1.0.0
- Dashboard sync/refresh feature - can show timestamp for last dashboard refresh.
- Tech - converted to TypeScript and Webpack.
v0.0.9
- Fixes bug with default properties not getting deep cloned #20
v0.0.8
- Remove extraneous comma when 1 second left in the countdown. PR from @linkslice
